RTEMS 6.1-rc2
_pwm_input_capture_param Struct Reference
Structure is used to hold parameters to configure the capture capability of a signal pin. More...
#include <fsl_pwm.h>
bool captureInputSel
uint8_t edgeCompareValue
pwm_input_capture_edge_t edge0
pwm_input_capture_edge_t edge1
bool enableOneShotCapture
uint8_t fifoWatermark
Field Documentation
◆ captureInputSel
bool _pwm_input_capture_param::captureInputSel
true: Use the edge counter signal as source false: Use the raw input signal from the pin as source
◆ edge0
pwm_input_capture_edge_t _pwm_input_capture_param::edge0
Specify which edge causes a capture for input circuitry 0
◆ edge1
pwm_input_capture_edge_t _pwm_input_capture_param::edge1
Specify which edge causes a capture for input circuitry 1
◆ edgeCompareValue
uint8_t _pwm_input_capture_param::edgeCompareValue
Compare value, used only if edge counter is used as source
◆ enableOneShotCapture
bool _pwm_input_capture_param::enableOneShotCapture
true: Use one-shot capture mode; false: Use free-running capture mode
◆ fifoWatermark
uint8_t _pwm_input_capture_param::fifoWatermark
Watermark level for capture FIFO. The capture flags in the status register will set if the word count in the FIFO is greater than this watermark level
