RTEMS 6.1-rc2
appl-config.h File Reference
This header file documents the application configuration options. More...
#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
 This configuration option is a boolean feature define.
#define CONFIGURE_BDBUF_BUFFER_MAX_SIZE
 This configuration option is an integer define.
#define CONFIGURE_BDBUF_BUFFER_MIN_SIZE
#define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE
#define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
#define CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
#define CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
#define CONFIGURE_BDBUF_TASK_STACK_SIZE
#define CONFIGURE_SWAPOUT_BLOCK_HOLD
#define CONFIGURE_SWAPOUT_SWAP_PERIOD
#define CONFIGURE_SWAPOUT_TASK_PRIORITY
#define CONFIGURE_SWAPOUT_WORKER_TASKS
#define CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
#define CONFIGURE_MAXIMUM_BARRIERS
#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES
#define CONFIGURE_MAXIMUM_PARTITIONS
#define CONFIGURE_MAXIMUM_PERIODS
#define CONFIGURE_MAXIMUM_PORTS
#define CONFIGURE_MAXIMUM_REGIONS
#define CONFIGURE_MAXIMUM_SEMAPHORES
#define CONFIGURE_MAXIMUM_TASKS
#define CONFIGURE_MAXIMUM_TIMERS
#define CONFIGURE_MAXIMUM_USER_EXTENSIONS
#define CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE
#define CONFIGURE_INIT_TASK_ARGUMENTS
#define CONFIGURE_INIT_TASK_ATTRIBUTES
#define CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
#define CONFIGURE_INIT_TASK_ENTRY_POINT
 This configuration option is an initializer define.
#define CONFIGURE_INIT_TASK_INITIAL_MODES
#define CONFIGURE_INIT_TASK_NAME
#define CONFIGURE_INIT_TASK_PRIORITY
#define CONFIGURE_INIT_TASK_STACK_SIZE
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_EXTRA_DRIVERS
#define CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
#define CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
#define CONFIGURE_ATA_DRIVER_TASK_PRIORITY
#define CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
#define CONFIGURE_MAXIMUM_DRIVERS
#define CONFIGURE_RECORD_EXTENSIONS_ENABLED
#define CONFIGURE_RECORD_FATAL_DUMP_BASE64
#define CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB
#define CONFIGURE_RECORD_INTERRUPTS_ENABLED
#define CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
#define CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR
#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
#define CONFIGURE_FILESYSTEM_ALL
#define CONFIGURE_FILESYSTEM_DOSFS
#define CONFIGURE_FILESYSTEM_FTPFS
#define CONFIGURE_FILESYSTEM_IMFS
#define CONFIGURE_FILESYSTEM_JFFS2
#define CONFIGURE_FILESYSTEM_NFS
#define CONFIGURE_FILESYSTEM_RFS
#define CONFIGURE_FILESYSTEM_TFTPFS
#define CONFIGURE_IMFS_DISABLE_CHMOD
#define CONFIGURE_IMFS_DISABLE_CHOWN
#define CONFIGURE_IMFS_DISABLE_LINK
#define CONFIGURE_IMFS_DISABLE_MKNOD
#define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
#define CONFIGURE_IMFS_DISABLE_MKNOD_FILE
#define CONFIGURE_IMFS_DISABLE_MOUNT
#define CONFIGURE_IMFS_DISABLE_READDIR
#define CONFIGURE_IMFS_DISABLE_READLINK
#define CONFIGURE_IMFS_DISABLE_RENAME
#define CONFIGURE_IMFS_DISABLE_RMNOD
#define CONFIGURE_IMFS_DISABLE_SYMLINK
#define CONFIGURE_IMFS_DISABLE_UNMOUNT
#define CONFIGURE_IMFS_DISABLE_UTIME
#define CONFIGURE_IMFS_ENABLE_MKFIFO
#define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
#define CONFIGURE_JFFS2_DELAYED_WRITE_TASK_PRIORITY
#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
#define CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
#define CONFIGURE_DIRTY_MEMORY
#define CONFIGURE_DISABLE_BSP_SETTINGS
#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
#define CONFIGURE_EXECUTIVE_RAM_SIZE
#define CONFIGURE_EXTRA_TASK_STACKS
#define CONFIGURE_INITIAL_EXTENSIONS
#define CONFIGURE_INTERRUPT_STACK_SIZE
#define CONFIGURE_MALLOC_DIRTY
#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
#define CONFIGURE_MAXIMUM_PROCESSORS
#define CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
#define CONFIGURE_MAXIMUM_THREAD_NAME_SIZE
#define CONFIGURE_MEMORY_OVERHEAD
#define CONFIGURE_MESSAGE_BUFFER_MEMORY
#define CONFIGURE_MICROSECONDS_PER_TICK
#define CONFIGURE_MINIMUM_TASK_STACK_SIZE
#define CONFIGURE_STACK_CHECKER_ENABLED
#define CONFIGURE_TICKS_PER_TIMESLICE
#define CONFIGURE_UNIFIED_WORK_AREAS
#define CONFIGURE_UNLIMITED_ALLOCATION_SIZE
#define CONFIGURE_UNLIMITED_OBJECTS
#define CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION
#define CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
#define CONFIGURE_IDLE_TASK_BODY
#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
#define CONFIGURE_IDLE_TASK_STACK_SIZE
#define CONFIGURE_IDLE_TASK_STORAGE_SIZE
#define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
#define CONFIGURE_MP_APPLICATION
#define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
#define CONFIGURE_MP_MAXIMUM_NODES
#define CONFIGURE_MP_MAXIMUM_PROXIES
#define CONFIGURE_MP_MPCI_TABLE_POINTER
#define CONFIGURE_MP_NODE_NUMBER
#define CONFIGURE_MAXIMUM_POSIX_KEYS
#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
#define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
#define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
#define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
#define CONFIGURE_MAXIMUM_POSIX_SHMS
#define CONFIGURE_MAXIMUM_POSIX_THREADS
#define CONFIGURE_MAXIMUM_POSIX_TIMERS
#define CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
#define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
#define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
#define CONFIGURE_POSIX_INIT_THREAD_TABLE
#define CONFIGURE_CBS_MAXIMUM_SERVERS
#define CONFIGURE_MAXIMUM_PRIORITY
#define CONFIGURE_SCHEDULER_ASSIGNMENTS
#define CONFIGURE_SCHEDULER_CBS
#define CONFIGURE_SCHEDULER_EDF
#define CONFIGURE_SCHEDULER_EDF_SMP
#define CONFIGURE_SCHEDULER_NAME
#define CONFIGURE_SCHEDULER_PRIORITY
#define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
#define CONFIGURE_SCHEDULER_PRIORITY_SMP
#define CONFIGURE_SCHEDULER_SIMPLE
#define CONFIGURE_SCHEDULER_SIMPLE_SMP
#define CONFIGURE_SCHEDULER_STRONG_APA
#define CONFIGURE_SCHEDULER_TABLE_ENTRIES
#define CONFIGURE_SCHEDULER_USER
#define CONFIGURE_TASK_STACK_ALLOCATOR
#define CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
#define CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE
#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT
#define CONFIGURE_TASK_STACK_DEALLOCATOR
#define CONFIGURE_TASK_STACK_FROM_ALLOCATOR
