RTEMS 6.1-rc2
#define | CONFIGURE_MAXIMUM_POSIX_KEYS |
This configuration option is an integer define. | |
#define | CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS |
#define | CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES |
#define | CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS |
#define | CONFIGURE_MAXIMUM_POSIX_SEMAPHORES |
#define | CONFIGURE_MAXIMUM_POSIX_SHMS |
#define | CONFIGURE_MAXIMUM_POSIX_THREADS |
#define | CONFIGURE_MAXIMUM_POSIX_TIMERS |
#define | CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE |
This section describes configuration options related to the POSIX API. Most POSIX API objects are available by default since RTEMS 5.1. The queued signals and timers are only available if RTEMS was built with the enable POSIX build configuration option.
#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS |
The value of this configuration option defines the maximum number of key value pairs used by POSIX API Keys that can be concurrently active.
The following constraints apply to this configuration option:
This object class can be configured in unlimited allocation mode, see Unlimited Objects.
A key value pair is created by pthread_setspecific() if the value is not NULL, otherwise it is deleted.
#define CONFIGURE_MAXIMUM_POSIX_KEYS |
The value of this configuration option defines the maximum number of POSIX API Keys that can be concurrently active.
#define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES |
The value of this configuration option defines the maximum number of POSIX API Message Queues that can be concurrently active.
<rtems/confdefs.h>
does not overflow an integer of type uintptr_t.#define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS |
The value of this configuration option defines the maximum number of POSIX API Queued Signals that can be concurrently active.
<rtems/confdefs.h>
does not overflow an integer of type uintptr_t.RTEMS_POSIX_API = True
build configuration option). Otherwise a compile time error in the configuration file will occur. Unlimited objects are not available for queued signals.
Queued signals are only available if RTEMS was built with the POSIX API build configuration option enabled.
#define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES |
The value of this configuration option defines the maximum number of POSIX API Named Semaphores that can be concurrently active.
<rtems/confdefs.h>
does not overflow an integer of type uintptr_t.This object class can be configured in unlimited allocation mode, see Unlimited Objects.
Named semaphores are created with sem_open(). Semaphores initialized with sem_init() are not affected by this configuration option since the storage space for these semaphores is user-provided.
#define CONFIGURE_MAXIMUM_POSIX_SHMS |
The value of this configuration option defines the maximum number of POSIX API Shared Memory objects that can be concurrently active.
<rtems/confdefs.h>
does not overflow an integer of type uintptr_t.#define CONFIGURE_MAXIMUM_POSIX_THREADS |
The value of this configuration option defines the maximum number of POSIX API Threads that can be concurrently active.
<rtems/confdefs.h>
does not overflow an integer of type uintptr_t. This object class can be configured in unlimited allocation mode, see Unlimited Objects.
This calculations for the required memory in the RTEMS Workspace for threads assume that each thread has a minimum stack size and has floating point support enabled. The configuration option CONFIGURE_EXTRA_TASK_STACKS is used to specify thread stack requirements above the minimum size required.
The maximum number of Classic API Tasks is specified by CONFIGURE_MAXIMUM_TASKS.
All POSIX threads have floating point enabled.
#define CONFIGURE_MAXIMUM_POSIX_TIMERS |
The value of this configuration option defines the maximum number of POSIX API Timers that can be concurrently active.
build configuration option). Otherwise a compile time error in the configuration file will occur. This object class can be configured in unlimited allocation mode, see Unlimited Objects.
Timers are only available if RTEMS was built with the POSIX API build configuration option enabled.
#define CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE |
The value of this configuration option defines the minimum stack size in bytes for every POSIX thread in the system.
<rtems/confdefs.h>
