RTEMS 6.1-rc2
POSIX Initialization Thread Configuration
#define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
 This configuration option is an initializer define.
#define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
 This configuration option is an integer define.
#define CONFIGURE_POSIX_INIT_THREAD_TABLE
 This configuration option is a boolean feature define.
This section describes configuration options related to the POSIX initialization thread.
◆ CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
The value of this configuration option initializes the entry point of the POSIX API initialization thread.
Default Value
The default value is POSIX_Init.
Constraints
The value of the configuration option shall be defined to a valid function pointer of the type void *( *entry_point )( void * ).
Notes
The application shall provide the function referenced by this configuration option.
◆ CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
The value of this configuration option defines the thread stack size of the POSIX API initialization thread.
Default Value
The default value is CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE.
Constraints
The following constraints apply to this configuration option:
  • The value of the configuration option shall be greater than or equal to CONFIGURE_MINIMUM_TASK_STACK_SIZE.
  • The value of the configuration option shall be small enough so that the task stack space calculation carried out by <rtems/confdefs.h> does not overflow an integer of type uintptr_t.
◆ CONFIGURE_POSIX_INIT_THREAD_TABLE
In case this configuration option is defined, then exactly one POSIX initialization thread is configured.
Default Configuration
If this configuration option is undefined, then the described feature is not enabled.
Notes
The application shall define at least one of the following configuration options
otherwise a compile time error in the configuration file will occur.
If no Classic API initialization task is configured, then the POSIX API initialization thread performs the Global Construction.
