RTEMS 6.1-rc2
appl-config.h
2
11/*
12 * Copyright (C) 2019, 2023 embedded brains GmbH & Co. KG
13 * Copyright (C) 2010 Gedare Bloom
14 * Copyright (C) 1988, 2023 On-Line Applications Research Corporation (OAR)
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38/*
39 * This file is part of the RTEMS quality process and was automatically
40 * generated. If you find something that needs to be fixed or
41 * worded better please post a report or patch to an RTEMS mailing list
42 * or raise a bug report:
43 *
44 * https://www.rtems.org/bugs.html
45 *
46 * For information on updating and regenerating please refer to the How-To
47 * section in the Software Requirements Engineering chapter of the
48 * RTEMS Software Engineering manual. The manual is provided as a part of
49 * a release. For development sources please refer to the online
50 * documentation at:
51 *
52 * https://docs.rtems.org
53 */
54
61/* Generated from spec:/acfg/if/group-bdbuf */
62
75/* Generated from spec:/acfg/if/appl-needs-libblock */
76
94#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
95
96/* Generated from spec:/acfg/if/bdbuf-buffer-max-size */
97
120#define CONFIGURE_BDBUF_BUFFER_MAX_SIZE
121
122/* Generated from spec:/acfg/if/bdbuf-buffer-min-size */
123
146#define CONFIGURE_BDBUF_BUFFER_MIN_SIZE
147
148/* Generated from spec:/acfg/if/bdbuf-cache-memory-size */
149
172#define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE
173
174/* Generated from spec:/acfg/if/bdbuf-max-read-ahead-blocks */
175
203#define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
204
205/* Generated from spec:/acfg/if/bdbuf-max-write-blocks */
206
229#define CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
230
231/* Generated from spec:/acfg/if/bdbuf-read-ahead-task-priority */
232
248#define CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
249
250/* Generated from spec:/acfg/if/bdbuf-task-stack-size */
251
280#define CONFIGURE_BDBUF_TASK_STACK_SIZE
281
282/* Generated from spec:/acfg/if/bdbuf-swapout-block-hold */
283
306#define CONFIGURE_SWAPOUT_BLOCK_HOLD
307
308/* Generated from spec:/acfg/if/bdbuf-swapout-swap-period */
309
332#define CONFIGURE_SWAPOUT_SWAP_PERIOD
333
334/* Generated from spec:/acfg/if/bdbuf-swapout-task-priority */
335
351#define CONFIGURE_SWAPOUT_TASK_PRIORITY
352
353/* Generated from spec:/acfg/if/bdbuf-swapout-worker-tasks */
354
377#define CONFIGURE_SWAPOUT_WORKER_TASKS
378
379/* Generated from spec:/acfg/if/bdbuf-swapout-worker-taskp-riority */
380
397#define CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
398
401/* Generated from spec:/acfg/if/group-classic */
402
413/* Generated from spec:/acfg/if/max-barriers */
414
451#define CONFIGURE_MAXIMUM_BARRIERS
452
453/* Generated from spec:/acfg/if/max-message-queues */
454
492#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES
493
494/* Generated from spec:/acfg/if/max-partitions */
495
532#define CONFIGURE_MAXIMUM_PARTITIONS
533
534/* Generated from spec:/acfg/if/max-periods */
535
572#define CONFIGURE_MAXIMUM_PERIODS
573
574/* Generated from spec:/acfg/if/max-ports */
575
612#define CONFIGURE_MAXIMUM_PORTS
613
614/* Generated from spec:/acfg/if/max-regions */
615
652#define CONFIGURE_MAXIMUM_REGIONS
653
654/* Generated from spec:/acfg/if/max-semaphores */
655
701#define CONFIGURE_MAXIMUM_SEMAPHORES
702
703/* Generated from spec:/acfg/if/max-tasks */
704
762#define CONFIGURE_MAXIMUM_TASKS
763
764/* Generated from spec:/acfg/if/max-timers */
765
802#define CONFIGURE_MAXIMUM_TIMERS
803
804/* Generated from spec:/acfg/if/max-user-extensions */
805
835#define CONFIGURE_MAXIMUM_USER_EXTENSIONS
836
837/* Generated from spec:/acfg/if/min-tasks-with-user-provided-storage */
838
868#define CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE
869
872/* Generated from spec:/acfg/if/group-classicinit */
873
886/* Generated from spec:/acfg/if/init-task-arguments */
887
903#define CONFIGURE_INIT_TASK_ARGUMENTS
904
905/* Generated from spec:/acfg/if/init-task-attributes */
906
921#define CONFIGURE_INIT_TASK_ATTRIBUTES
922
923/* Generated from spec:/acfg/if/init-task-construct-storage-size */
924
978#define CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
979
980/* Generated from spec:/acfg/if/init-task-entrypoint */
981
1001#define CONFIGURE_INIT_TASK_ENTRY_POINT
1002
1003/* Generated from spec:/acfg/if/init-task-initial-modes */
1004
1020#define CONFIGURE_INIT_TASK_INITIAL_MODES
1021
1022/* Generated from spec:/acfg/if/init-task-name */
1023
1042#define CONFIGURE_INIT_TASK_NAME
1043
1044/* Generated from spec:/acfg/if/init-task-priority */
1045
1062#define CONFIGURE_INIT_TASK_PRIORITY
1063
1064/* Generated from spec:/acfg/if/init-task-stack-size */
1065
1101#define CONFIGURE_INIT_TASK_STACK_SIZE
1102
1103/* Generated from spec:/acfg/if/rtems-init-tasks-table */
1104
1135#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
1136
1139/* Generated from spec:/acfg/if/group-devdrv */
1140
1153/* Generated from spec:/acfg/if/appl-does-not-need-clock-driver */
1154
1185#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
1186
1187/* Generated from spec:/acfg/if/appl-extra-drivers */
1188
1213#define CONFIGURE_APPLICATION_EXTRA_DRIVERS
1214
1215/* Generated from spec:/acfg/if/appl-needs-ata-driver */
1216
1237#define CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
1238
1239/* Generated from spec:/acfg/if/appl-needs-clock-driver */
1240
1270#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
1271
1272/* Generated from spec:/acfg/if/appl-needs-console-driver */
1273
1306#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
1307
1308/* Generated from spec:/acfg/if/appl-needs-framebuffer-driver */
1309
1331#define CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
1332
1333/* Generated from spec:/acfg/if/appl-needs-ide-driver */
1334
1355#define CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
1356
1357/* Generated from spec:/acfg/if/appl-needs-null-driver */
1358
1374#define CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
1375
1376/* Generated from spec:/acfg/if/appl-needs-rtc-driver */
1377
1399#define CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
1400
1401/* Generated from spec:/acfg/if/appl-needs-simple-console-driver */
1402
1439#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
1440
1441/* Generated from spec:/acfg/if/appl-needs-simple-task-console-driver */
1442
1488#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
1489
1490/* Generated from spec:/acfg/if/appl-needs-stub-driver */
1491
1508#define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
1509
1510/* Generated from spec:/acfg/if/appl-needs-timer-driver */
1511
1541#define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
1542
1543/* Generated from spec:/acfg/if/appl-needs-watchdog-driver */
1544
1566#define CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
1567
1568/* Generated from spec:/acfg/if/appl-needs-zero-driver */
1569
1585#define CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
1586
1587/* Generated from spec:/acfg/if/appl-prerequisite-drivers */
1588
1614#define CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
1615
1616/* Generated from spec:/acfg/if/ata-driver-task-priority */
1617
1637#define CONFIGURE_ATA_DRIVER_TASK_PRIORITY
1638
1639/* Generated from spec:/acfg/if/exception-to-signal-mapping */
1640
1662#define CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
1663
1664/* Generated from spec:/acfg/if/max-drivers */
1665
1736#define CONFIGURE_MAXIMUM_DRIVERS
1737
1740/* Generated from spec:/acfg/if/group-eventrecord */
1741
1753/* Generated from spec:/acfg/if/record-extensions-enabled */
1754
1776#define CONFIGURE_RECORD_EXTENSIONS_ENABLED
1777
1778/* Generated from spec:/acfg/if/record-fatal-dump-base64 */
1779
1805#define CONFIGURE_RECORD_FATAL_DUMP_BASE64
1806
1807/* Generated from spec:/acfg/if/record-fatal-dump-base64-zlib */
1808
1833#define CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB
1834
1835/* Generated from spec:/acfg/if/record-interrupts-enabled */
1836
1858#define CONFIGURE_RECORD_INTERRUPTS_ENABLED
1859
1860/* Generated from spec:/acfg/if/record-per-processor-items */
1861
1895#define CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
1896
1899/* Generated from spec:/acfg/if/group-face */
1900
1926/* Generated from spec:/acfg/if/posix-timer-face-behavior */
1927
1946#define CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR
1947
1950/* Generated from spec:/acfg/if/group-filesystem */
1951
2002/* Generated from spec:/acfg/if/appl-disable-filesystem */
2003
2022#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
2023
2024/* Generated from spec:/acfg/if/filesystem-all */
2025
2052#define CONFIGURE_FILESYSTEM_ALL
2053
2054/* Generated from spec:/acfg/if/filesystem-dosfs */
2055
2073#define CONFIGURE_FILESYSTEM_DOSFS
2074
2075/* Generated from spec:/acfg/if/filesystem-ftpfs */
2076
2090#define CONFIGURE_FILESYSTEM_FTPFS
2091
2092/* Generated from spec:/acfg/if/filesystem-imfs */
2093
2113#define CONFIGURE_FILESYSTEM_IMFS
2114
2115/* Generated from spec:/acfg/if/filesystem-jffs2 */
2116
2130#define CONFIGURE_FILESYSTEM_JFFS2
2131
2132/* Generated from spec:/acfg/if/filesystem-nfs */
2133
2147#define CONFIGURE_FILESYSTEM_NFS
2148
2149/* Generated from spec:/acfg/if/filesystem-rfs */
2150
2168#define CONFIGURE_FILESYSTEM_RFS
2169
2170/* Generated from spec:/acfg/if/filesystem-tftpfs */
2171
2185#define CONFIGURE_FILESYSTEM_TFTPFS
2186
2187/* Generated from spec:/acfg/if/imfs-disable-chmod */
2188
2201#define CONFIGURE_IMFS_DISABLE_CHMOD
2202
2203/* Generated from spec:/acfg/if/imfs-disable-chown */
2204
2217#define CONFIGURE_IMFS_DISABLE_CHOWN
2218
2219/* Generated from spec:/acfg/if/imfs-disable-link */
2220
2233#define CONFIGURE_IMFS_DISABLE_LINK
2234
2235/* Generated from spec:/acfg/if/imfs-disable-mknod */
2236
2249#define CONFIGURE_IMFS_DISABLE_MKNOD
2250
2251/* Generated from spec:/acfg/if/imfs-disable-mknod-device */
2252
2265#define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
2266
2267/* Generated from spec:/acfg/if/imfs-disable-mknod-file */
2268
2281#define CONFIGURE_IMFS_DISABLE_MKNOD_FILE
2282
2283/* Generated from spec:/acfg/if/imfs-disable-mount */
2284
2297#define CONFIGURE_IMFS_DISABLE_MOUNT
2298
2299/* Generated from spec:/acfg/if/imfs-disable-readdir */
2300
2314#define CONFIGURE_IMFS_DISABLE_READDIR
2315
2316/* Generated from spec:/acfg/if/imfs-disable-readlink */
2317
2330#define CONFIGURE_IMFS_DISABLE_READLINK
2331
2332/* Generated from spec:/acfg/if/imfs-disable-rename */
2333
2346#define CONFIGURE_IMFS_DISABLE_RENAME
2347
2348/* Generated from spec:/acfg/if/imfs-disable-rmnod */
2349
2362#define CONFIGURE_IMFS_DISABLE_RMNOD
2363
2364/* Generated from spec:/acfg/if/imfs-disable-symlink */
2365
2378#define CONFIGURE_IMFS_DISABLE_SYMLINK
2379
2380/* Generated from spec:/acfg/if/imfs-disable-unmount */
2381
2394#define CONFIGURE_IMFS_DISABLE_UNMOUNT
2395
2396/* Generated from spec:/acfg/if/imfs-disable-utime */
2397
2410#define CONFIGURE_IMFS_DISABLE_UTIME
2411
2412/* Generated from spec:/acfg/if/imfs-enable-mkfifo */
2413
2426#define CONFIGURE_IMFS_ENABLE_MKFIFO
2427
2428/* Generated from spec:/acfg/if/imfs-memfile-bytes-per-block */
2429
2476#define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
2477
2478/* Generated from spec:/acfg/if/jffs2-delayed-write-task-priority */
2479
2504#define CONFIGURE_JFFS2_DELAYED_WRITE_TASK_PRIORITY
2505
2506/* Generated from spec:/acfg/if/use-devfs-as-base-filesystem */
2507
2557#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
2558
2559/* Generated from spec:/acfg/if/use-miniimfs-as-base-filesystem */
2560
2595#define CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
2596
2599/* Generated from spec:/acfg/if/group-general */
2600
2612/* Generated from spec:/acfg/if/dirty-memory */
2613
2638#define CONFIGURE_DIRTY_MEMORY
2639
2640/* Generated from spec:/acfg/if/disable-bsp-settings */
2641
2671#define CONFIGURE_DISABLE_BSP_SETTINGS
2672
2673/* Generated from spec:/acfg/if/disable-newlib-reentrancy */
2674
2693#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
2694
2695/* Generated from spec:/acfg/if/executive-ram-size */
2696
2729#define CONFIGURE_EXECUTIVE_RAM_SIZE
2730
2731/* Generated from spec:/acfg/if/extra-task-stacks */
2732
2763#define CONFIGURE_EXTRA_TASK_STACKS
2764
2765/* Generated from spec:/acfg/if/init */
2766
2784#define CONFIGURE_INIT
2785
2786/* Generated from spec:/acfg/if/initial-extensions */
2787
2808#define CONFIGURE_INITIAL_EXTENSIONS
2809
2810/* Generated from spec:/acfg/if/interrupt-stack-size */
2811
2861#define CONFIGURE_INTERRUPT_STACK_SIZE
2862
2863/* Generated from spec:/acfg/if/malloc-dirty */
2864
2884#define CONFIGURE_MALLOC_DIRTY
2885
2886/* Generated from spec:/acfg/if/max-file-descriptors */
2887
2918#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
2919
2920/* Generated from spec:/acfg/if/max-processors */
2921
2957#define CONFIGURE_MAXIMUM_PROCESSORS
2958
2959/* Generated from spec:/acfg/if/max-thread-local-storage-size */
2960
3007#define CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
3008
3009/* Generated from spec:/acfg/if/max-thread-name-size */
3010
3048#define CONFIGURE_MAXIMUM_THREAD_NAME_SIZE
3049
3050/* Generated from spec:/acfg/if/memory-overhead */
3051
3088#define CONFIGURE_MEMORY_OVERHEAD
3089
3090/* Generated from spec:/acfg/if/message-buffer-memory */
3091
3168#define CONFIGURE_MESSAGE_BUFFER_MEMORY
3169
3170/* Generated from spec:/acfg/if/microseconds-per-tick */
3171
3220#define CONFIGURE_MICROSECONDS_PER_TICK
3221
3222/* Generated from spec:/acfg/if/min-task-stack-size */
3223
3271#define CONFIGURE_MINIMUM_TASK_STACK_SIZE
3272
3273/* Generated from spec:/acfg/if/stack-checker-enabled */
3274
3296#define CONFIGURE_STACK_CHECKER_ENABLED
3297
3298/* Generated from spec:/acfg/if/ticks-per-time-slice */
3299
3326#define CONFIGURE_TICKS_PER_TIMESLICE
3327
3328/* Generated from spec:/acfg/if/unified-work-areas */
3329
3355#define CONFIGURE_UNIFIED_WORK_AREAS
3356
3357/* Generated from spec:/acfg/if/unlimited-allocation-size */
3358
3387#define CONFIGURE_UNLIMITED_ALLOCATION_SIZE
3388
3389/* Generated from spec:/acfg/if/unlimited-objects */
3390
3415#define CONFIGURE_UNLIMITED_OBJECTS
3416
3417/* Generated from spec:/acfg/if/verbose-system-init */
3418
3435#define CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION
3436
3437/* Generated from spec:/acfg/if/zero-workspace-automatically */
3438
3458#define CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
3459
3462/* Generated from spec:/acfg/if/group-idle */
3463
3474/* Generated from spec:/acfg/if/idle-task-body */
3475
3508#define CONFIGURE_IDLE_TASK_BODY
3509
3510/* Generated from spec:/acfg/if/idle-task-init-appl */
3511
3556#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
3557
3558/* Generated from spec:/acfg/if/idle-task-stack-size */
3559
3592#define CONFIGURE_IDLE_TASK_STACK_SIZE
3593
3594/* Generated from spec:/acfg/if/idle-task-storage-size */
3595
3647#define CONFIGURE_IDLE_TASK_STORAGE_SIZE
3648
3651/* Generated from spec:/acfg/if/group-mpci */
3652
3670/* Generated from spec:/acfg/if/mp-extra-server-stack */
3671
3704#define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
3705
3706/* Generated from spec:/acfg/if/mp-appl */
3707
3727#define CONFIGURE_MP_APPLICATION
3728
3729/* Generated from spec:/acfg/if/mp-max-global-objects */
3730
3762#define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
3763
3764/* Generated from spec:/acfg/if/mp-max-nodes */
3765
3792#define CONFIGURE_MP_MAXIMUM_NODES
3793
3794/* Generated from spec:/acfg/if/mp-max-proxies */
3795
3830#define CONFIGURE_MP_MAXIMUM_PROXIES
3831
3832/* Generated from spec:/acfg/if/mp-mpci-table-pointer */
3833
3859#define CONFIGURE_MP_MPCI_TABLE_POINTER
3860
3861/* Generated from spec:/acfg/if/mp-node-number */
3862
3896#define CONFIGURE_MP_NODE_NUMBER
3897
3900/* Generated from spec:/acfg/if/group-posix */
3901
3915/* Generated from spec:/acfg/if/max-posix-keys */
3916
3953#define CONFIGURE_MAXIMUM_POSIX_KEYS
3954
3955/* Generated from spec:/acfg/if/max-posix-key-value-pairs */
3956
4000#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
4001
4002/* Generated from spec:/acfg/if/max-posix-message-queues */
4003
4046#define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
4047
4048/* Generated from spec:/acfg/if/max-posix-queued-signals */
4049
4091#define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
4092
4093/* Generated from spec:/acfg/if/max-posix-semaphores */
4094
4142#define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
4143
4144/* Generated from spec:/acfg/if/max-posix-shms */
4145
4187#define CONFIGURE_MAXIMUM_POSIX_SHMS
4188
4189/* Generated from spec:/acfg/if/max-posix-threads */
4190
4240#define CONFIGURE_MAXIMUM_POSIX_THREADS
4241
4242/* Generated from spec:/acfg/if/max-posix-timers */
4243
4290#define CONFIGURE_MAXIMUM_POSIX_TIMERS
4291
4292/* Generated from spec:/acfg/if/min-posix-thread-stack-size */
4293
4319#define CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
4320
4323/* Generated from spec:/acfg/if/group-posixinit */
4324
4337/* Generated from spec:/acfg/if/posix-init-thread-entry-point */
4338
4358#define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
4359
4360/* Generated from spec:/acfg/if/posix-init-thread-stack-size */
4361
4386#define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
4387
4388/* Generated from spec:/acfg/if/posix-init-thread-table */
4389
4421#define CONFIGURE_POSIX_INIT_THREAD_TABLE
4422
4425/* Generated from spec:/acfg/if/group-schedgeneral */
4426
4461/* Generated from spec:/acfg/if/cbs-max-servers */
4462
4493#define CONFIGURE_CBS_MAXIMUM_SERVERS
4494
4495/* Generated from spec:/acfg/if/max-priority */
4496
4553#define CONFIGURE_MAXIMUM_PRIORITY
4554
4555/* Generated from spec:/acfg/if/scheduler-assignments */
4556
4605#define CONFIGURE_SCHEDULER_ASSIGNMENTS
4606
4607/* Generated from spec:/acfg/if/scheduler-cbs */
4608
4634#define CONFIGURE_SCHEDULER_CBS
4635
4636/* Generated from spec:/acfg/if/scheduler-edf */
4637
4662#define CONFIGURE_SCHEDULER_EDF
4663
4664/* Generated from spec:/acfg/if/scheduler-edf-smp */
4665
4697#define CONFIGURE_SCHEDULER_EDF_SMP
4698
4699/* Generated from spec:/acfg/if/scheduler-name */
4700
4760#define CONFIGURE_SCHEDULER_NAME
4761
4762/* Generated from spec:/acfg/if/scheduler-priority */
4763
4794#define CONFIGURE_SCHEDULER_PRIORITY
4795
4796/* Generated from spec:/acfg/if/scheduler-priority-affinity-smp */
4797
4829#define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
4830
4831/* Generated from spec:/acfg/if/scheduler-priority-smp */
4832
4863#define CONFIGURE_SCHEDULER_PRIORITY_SMP
4864
4865/* Generated from spec:/acfg/if/scheduler-simple */
4866
4891#define CONFIGURE_SCHEDULER_SIMPLE
4892
4893/* Generated from spec:/acfg/if/scheduler-simple-smp */
4894
4922#define CONFIGURE_SCHEDULER_SIMPLE_SMP
4923
4924/* Generated from spec:/acfg/if/scheduler-strong-apa */
4925
4949#define CONFIGURE_SCHEDULER_STRONG_APA
4950
4951/* Generated from spec:/acfg/if/scheduler-table-entries */
4952
5014#define CONFIGURE_SCHEDULER_TABLE_ENTRIES
5015
5016/* Generated from spec:/acfg/if/scheduler-user */
5017
5059#define CONFIGURE_SCHEDULER_USER
5060
5063/* Generated from spec:/acfg/if/group-stackalloc */
5064
5080/* Generated from spec:/acfg/if/task-stack-allocator */
5081
5110#define CONFIGURE_TASK_STACK_ALLOCATOR
5111
5112/* Generated from spec:/acfg/if/task-stack-no-workspace */
5113
5130#define CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
5131
5132/* Generated from spec:/acfg/if/task-stack-allocator-for-idle */
5133
5180#define CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE
5181
5182/* Generated from spec:/acfg/if/task-stack-allocator-init */
5183
5213#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT
5214
5215/* Generated from spec:/acfg/if/task-stack-deallocator */
5216
5245#define CONFIGURE_TASK_STACK_DEALLOCATOR
5246
5247/* Generated from spec:/acfg/if/task-stack-from-alloc */
5248
5271#define CONFIGURE_TASK_STACK_FROM_ALLOCATOR
5272
