RTEMS 6.1-rc1
Example CPU Architecture Support. More...
Modules | |
CPUEndian | |
CPUEndian. | |
Example Assembler Support | |
Management | |
Management. | |
Processor Dependent Bitfield Manipulation | |
Processor Dependent Context Management | |
Destroys the context of the thread. | |
Processor Dependent Interrupt Management | |
struct | CPU_Per_CPU_control |
The CPU specific per-CPU control. More... | |
#define | CPU_PER_CPU_CONTROL_SIZE 0 |
The size of the CPU specific per-CPU control. More... | |
#define | CPU_THREAD_LOCAL_STORAGE_VARIANT 10 |
Defines the thread-local storage (TLS) variant. More... | |
#define | _CPU_Get_current_per_CPU_control() ( _CPU_Per_CPU_current ) |
Optional method to obtain the per-CPU control of the current processor. More... | |
#define | _CPU_Get_thread_executing() ( _CPU_Per_CPU_current->executing ) |
Optional method to get the executing thread. More... | |
register struct Per_CPU_Control *_CPU_Per_CPU_current | asm ("rX") |
Special register pointing to the per-CPU control of the current processor. More... | |
RTEMS_NO_RETURN void | _CPU_Fatal_halt (uint32_t source, CPU_Uint32ptr error) |
void | _CPU_Context_volatile_clobber (uintptr_t pattern) |
void | _CPU_Context_validate (uintptr_t pattern) |
#define _CPU_Get_current_per_CPU_control | ( | ) | ( _CPU_Per_CPU_current ) |
This is optional. Not every CPU port needs this. It is only an optional optimization variant. In case this macro is undefined, the default implementation using the current processor index will be used.
#define _CPU_Get_thread_executing | ( | ) | ( _CPU_Per_CPU_current->executing ) |
This is optional. Not every CPU port needs this. It is only an optional optimization variant. In case this macro is undefined, the default implementation uses the per-CPU information and the current processor index to get the executing thread.
#define CPU_PER_CPU_CONTROL_SIZE 0 |
This define must be visible to assember files since it is used to derive structure offsets.
#define CPU_THREAD_LOCAL_STORAGE_VARIANT 10 |
Use one of the following values:
10: The architecture uses Variant I and the TLS offsets emitted by the linker neglect the TCB (examples: nios2, m68k, microblaze, powerpc, riscv). The thread pointer directly references the thread-local data area.
11: The architecture uses Variant I and the TLS offsets emitted by the linker take the TCB into account (examples: arm, aarch64). The thread pointer references the TCB.
20: The architecture uses Variant II (examples: i386, sparc).
RTEMS_NO_RETURN void _CPU_Fatal_halt | ( | uint32_t | source, |
CPU_Uint32ptr | error | ||
This routine copies _error into a known place – typically a stack location or a register, optionally disables interrupts, and halts/stops the CPU.
Port Specific Information:
XXX document implementation including references if appropriate
COPYRIGHT (c) 2016. On-Line Applications Research Corporation (OAR).
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
register struct Per_CPU_Control *_CPU_Per_CPU_current asm | ( | "rX" | ) |
