RTEMS 6.1-rc1
Modules | Files | Data Structures | Macros | Typedefs | Functions
ARM Architecture Support. More...
 AArch32 System Registers
 This group provides functions to read and write the AArch32 system registers.
 ARM Assembler Support
 ARM Assembler Support.
 ARM Co-Processor 15 Support
 ARM co-processor 15 (CP15) support.
 ARM Paravirtualization Support
 PMSAv8-32 Support
 This group provides support functions to manage an Arm PMSAv8-32 (Protected Memory System Architecture) based Memory Protection Unit (MPU).
file  __aeabi_read_tp.c
 This source file contains the implementation of __aeabi_read_tp().
file  __tls_get_addr.c
 This source file contains the implementation of __tls_get_addr().
file  arm-exception-default.c
 This source file contains the implementation of _ARM_Exception_default().
file  arm-exception-frame-print.c
 This source file contains the implementation of _CPU_Exception_frame_print().
file  armv4-sync-synchronize.c
 This source file contains the implementation of __sync_synchronize().
file  armv7-thread-idle.c
 This source file contains the implementation of _CPU_Thread_Idle_body().
file  armv7m-context-initialize.c
 This source file contains the implementation of _CPU_Context_Initialize().
file  armv7m-context-restore.c
 This source file contains the implementation of _CPU_Context_restore().
file  armv7m-context-switch.c
 This source file contains the implementation of _CPU_Context_switch().
file  armv7m-exception-default.c
 This source file contains the implementation of _ARMV7M_Exception_default().
file  armv7m-exception-handler-get.c
 This source file contains the implementation of _ARMV7M_Get_exception_handler().
file  armv7m-exception-handler-set.c
 This source file contains the implementation of _ARMV7M_Set_exception_handler().
file  armv7m-exception-priority-get.c
 This source file contains the implementation of _ARMV7M_Get_exception_priority().
file  armv7m-exception-priority-handler.c
 This source file contains the implementation of _ARMV7M_Set_exception_priority_and_handler().
file  armv7m-exception-priority-set.c
 This source file contains the implementation of _ARMV7M_Set_exception_priority().
file  armv7m-initialize.c
 This source file contains the implementation of _CPU_Initialize().
file  armv7m-isr-dispatch.c
 This source file contains the implementation of _ARMV7M_Thread_dispatch().
file  armv7m-isr-enter-leave.c
 This source file contains the implementation of _ARMV7M_Interrupt_service_enter() and _ARMV7M_Interrupt_service_leave().
file  armv7m-isr-level-get.c
 This source file contains the implementation of _CPU_ISR_Get_level().
file  armv7m-isr-level-set.c
 This source file contains the implementation of _CPU_ISR_Set_level().
file  armv7m-isr-vector-install.c
 This source file contains the implementation of _CPU_ISR_install_vector().
file  armv7m-multitasking-start-stop.c
 This source file contains the implementation of _ARMV7M_Start_multitasking().
file  cpu.c
 This source file contains static assertions to ensure the consistency of interfaces used in C and assembler and it contains the ARM-specific implementation of _CPU_Initialize(), _CPU_ISR_Get_level(), _CPU_ISR_Set_level(), _CPU_ISR_install_vector(), _CPU_Context_Initialize(), and _CPU_Fatal_halt().
file  arm.h
 This header file provides defines derived from ARM multilib defines.
file  armv4.h
 This header file provides interfaces of the ARMv4 architecture support.
file  armv7m.h
 This header file provides interfaces of the ARMv7-M architecture support.
file  cpu.h
 This header file defines implementation interfaces pertaining to the port of the executive to the ARM architecture.
file  cpu_asm.h
 ARM Assembler Support API.
file  cpuimpl.h
struct  Context_Control
 Thread register context. More...
struct  ARM_VFP_context
struct  CPU_Exception_frame
 The set of registers that specifies the complete processor state. More...
#define CPU_MODEL_NAME   "ARMv4"
#define ARM_MULTILIB_ARCH_V4
#define CPU_NAME   "ARM"
#define CPU_SIMPLE_VECTORED_INTERRUPTS   FALSE
#define CPU_ISR_PASSES_FRAME_POINTER   FALSE
#define CPU_HARDWARE_FP   FALSE
#define CPU_SOFTWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   FALSE
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   FALSE
#define CPU_ENABLE_ROBUST_THREAD_DISPATCH   TRUE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_CACHE_LINE_BYTES   32
#define CPU_STRUCTURE_ALIGNMENT   RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
#define CPU_MODES_INTERRUPT_MASK   0x1
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   0
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE
#define CPU_STACK_MINIMUM_SIZE   (1024 * 4)
#define CPU_SIZEOF_POINTER   4
#define CPU_ALIGNMENT   8
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   8
#define CPU_INTERRUPT_STACK_ALIGNMENT   CPU_CACHE_LINE_BYTES
#define CPU_USE_GENERIC_BITFIELD_CODE   TRUE
#define CPU_USE_LIBC_INIT_FINI_ARRAY   TRUE
#define CPU_MAXIMUM_PROCESSORS   32
#define ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET   44
#define ARM_EXCEPTION_FRAME_SIZE   80
#define ARM_EXCEPTION_FRAME_REGISTER_SP_OFFSET   52
#define ARM_EXCEPTION_FRAME_VFP_CONTEXT_OFFSET   72
#define ARM_VFP_CONTEXT_SIZE   264
#define _CPU_ISR_Disable(_isr_cookie)
#define _CPU_ISR_Enable(_isr_cookie)    arm_interrupt_enable( _isr_cookie )
#define _CPU_ISR_Flash(_isr_cookie)    arm_interrupt_flash( _isr_cookie )
#define _CPU_Context_Get_SP(_context)    (_context)->register_sp
#define _CPU_Context_Restart_self(_the_context)    _CPU_Context_restore( (_the_context) );
#define _CPU_Context_Initialize_fp(_destination)
#define CPU_PER_CPU_CONTROL_SIZE   0
#define CPU_THREAD_LOCAL_STORAGE_VARIANT   11
typedef void(* CPU_ISR_handler) (void)
typedef uint32_t CPU_Counter_ticks
typedef uintptr_t CPU_Uint32ptr
void _CPU_ISR_Set_level (uint32_t level)
 Sets the hardware interrupt level by the level value. More...
uint32_t _CPU_ISR_Get_level (void)
void _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
void _CPU_Initialize (void)
 CPU initialization. More...
void _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 CPU switch context.
RTEMS_NO_RETURN void _CPU_Context_switch_no_return (Context_Control *executing, Context_Control *heir)
RTEMS_NO_RETURN void _CPU_Context_restore (Context_Control *new_context)
uint32_t _CPU_Counter_frequency (void)
CPU_Counter_ticks _CPU_Counter_read (void)
void * _CPU_Thread_Idle_body (uintptr_t ignored)
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
void _ARM_Exception_default (CPU_Exception_frame *frame)
RTEMS_NO_RETURN void _CPU_Fatal_halt (uint32_t source, CPU_Uint32ptr error)
void _CPU_Context_volatile_clobber (uintptr_t pattern)
void _CPU_Context_validate (uintptr_t pattern)
◆ _CPU_Context_Initialize_fp
#define _CPU_Context_Initialize_fp (   _destination)
Value:
do { \
*(*(_destination)) = _CPU_Null_fp_context; \
} while (0)
Context_Control_fp _CPU_Null_fp_context
◆ _CPU_ISR_Disable
#define _CPU_ISR_Disable (   _isr_cookie)
Value:
do { \
_isr_cookie = arm_interrupt_disable(); \
} while (0)
Typedef Documentation
◆ CPU_Uint32ptr
Type that can store a 32-bit integer or a pointer.
◆ _CPU_Fatal_halt()
RTEMS_NO_RETURN void _CPU_Fatal_halt ( uint32_t  source,
CPU_Uint32ptr  error
COPYRIGHT (c) 2016. On-Line Applications Research Corporation (OAR).
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
  1. Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
  2. Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
◆ _CPU_Initialize()
void _CPU_Initialize ( void  )
CPU initialization.
CPU initialization.
◆ _CPU_ISR_Set_level()
void _CPU_ISR_Set_level ( uint32_t  level)
Parameters
[in]levelfor or1k can only range over two values: 0 (enable interrupts) and 1 (disable interrupts). In future implementations if fast context switch is implemented, the level can range from 0 to 15.
See also
OpenRISC architecture manual.
