RTEMS 6.1-rc1
Data Structures | Macros | Typedefs
grpci2-regs.h File Reference
This header file defines the GRPCI2 register block interface. More...
#include <stdint.h>
struct  grpci2
 This structure defines the GRPCI2 register block memory map. More...
#define GRPCI2_CTRL_RE   0x80000000U
#define GRPCI2_CTRL_MR   0x40000000U
#define GRPCI2_CTRL_TR   0x20000000U
#define GRPCI2_CTRL_SI   0x8000000U
#define GRPCI2_CTRL_PE   0x4000000U
#define GRPCI2_CTRL_ER   0x2000000U
#define GRPCI2_CTRL_EI   0x1000000U
#define GRPCI2_CTRL_BUS_NUMBER_SHIFT   16
#define GRPCI2_CTRL_BUS_NUMBER_MASK   0xff0000U
#define GRPCI2_CTRL_BUS_NUMBER_GET(_reg)
#define GRPCI2_CTRL_BUS_NUMBER_SET(_reg, _val)
#define GRPCI2_CTRL_BUS_NUMBER(_val)
#define GRPCI2_CTRL_DFA   0x800U
#define GRPCI2_CTRL_IB   0x400U
#define GRPCI2_CTRL_CB   0x200U
#define GRPCI2_CTRL_DIF   0x100U
#define GRPCI2_CTRL_DEVICE_INT_MASK_SHIFT   4
#define GRPCI2_CTRL_DEVICE_INT_MASK_MASK   0xf0U
#define GRPCI2_CTRL_DEVICE_INT_MASK_GET(_reg)
#define GRPCI2_CTRL_DEVICE_INT_MASK_SET(_reg, _val)
#define GRPCI2_CTRL_DEVICE_INT_MASK(_val)
#define GRPCI2_CTRL_HOST_INT_MASK_SHIFT   0
#define GRPCI2_CTRL_HOST_INT_MASK_MASK   0xfU
#define GRPCI2_CTRL_HOST_INT_MASK_GET(_reg)
#define GRPCI2_CTRL_HOST_INT_MASK_SET(_reg, _val)
#define GRPCI2_CTRL_HOST_INT_MASK(_val)
#define GRPCI2_STATCAP_HOST   0x80000000U
#define GRPCI2_STATCAP_MST   0x40000000U
#define GRPCI2_STATCAP_TAR   0x20000000U
#define GRPCI2_STATCAP_DMA   0x10000000U
#define GRPCI2_STATCAP_DI   0x8000000U
#define GRPCI2_STATCAP_HI   0x4000000U
#define GRPCI2_STATCAP_IRQ_MODE_SHIFT   24
#define GRPCI2_STATCAP_IRQ_MODE_MASK   0x3000000U
#define GRPCI2_STATCAP_IRQ_MODE_GET(_reg)
#define GRPCI2_STATCAP_IRQ_MODE_SET(_reg, _val)
#define GRPCI2_STATCAP_IRQ_MODE(_val)
#define GRPCI2_STATCAP_TRACE   0x800000U
#define GRPCI2_STATCAP_CFGDO   0x100000U
#define GRPCI2_STATCAP_CFGER   0x80000U
#define GRPCI2_STATCAP_CORE_INT_STATUS_SHIFT   12
#define GRPCI2_STATCAP_CORE_INT_STATUS_MASK   0x7f000U
#define GRPCI2_STATCAP_CORE_INT_STATUS_GET(_reg)
#define GRPCI2_STATCAP_CORE_INT_STATUS_SET(_reg, _val)
#define GRPCI2_STATCAP_CORE_INT_STATUS(_val)
#define GRPCI2_STATCAP_HOST_INT_STATUS_SHIFT   8
#define GRPCI2_STATCAP_HOST_INT_STATUS_MASK   0xf00U
#define GRPCI2_STATCAP_HOST_INT_STATUS_GET(_reg)
#define GRPCI2_STATCAP_HOST_INT_STATUS_SET(_reg, _val)
#define GRPCI2_STATCAP_HOST_INT_STATUS(_val)
#define GRPCI2_STATCAP_FDEPTH_SHIFT   2
#define GRPCI2_STATCAP_FDEPTH_MASK   0x1cU
#define GRPCI2_STATCAP_FDEPTH_GET(_reg)
#define GRPCI2_STATCAP_FDEPTH_SET(_reg, _val)
#define GRPCI2_STATCAP_FDEPTH(_val)
#define GRPCI2_STATCAP_FNUM_SHIFT   0
#define GRPCI2_STATCAP_FNUM_MASK   0x3U
#define GRPCI2_STATCAP_FNUM_GET(_reg)
#define GRPCI2_STATCAP_FNUM_SET(_reg, _val)
#define GRPCI2_STATCAP_FNUM(_val)
#define GRPCI2_BCIM_AHB_MASTER_UNMASK_SHIFT   16
#define GRPCI2_BCIM_AHB_MASTER_UNMASK_MASK   0xffff0000U
#define GRPCI2_BCIM_AHB_MASTER_UNMASK_GET(_reg)
#define GRPCI2_BCIM_AHB_MASTER_UNMASK_SET(_reg, _val)
#define GRPCI2_BCIM_AHB_MASTER_UNMASK(_val)
#define GRPCI2_BCIM_BURST_LENGTH_SHIFT   0
#define GRPCI2_BCIM_BURST_LENGTH_MASK   0xffU
#define GRPCI2_BCIM_BURST_LENGTH_GET(_reg)
#define GRPCI2_BCIM_BURST_LENGTH_SET(_reg, _val)
#define GRPCI2_BCIM_BURST_LENGTH(_val)
#define GRPCI2_AHB2PCI_AHB_TO_PCI_IO_SHIFT   16
#define GRPCI2_AHB2PCI_AHB_TO_PCI_IO_MASK   0xffff0000U
#define GRPCI2_AHB2PCI_AHB_TO_PCI_IO_GET(_reg)
#define GRPCI2_AHB2PCI_AHB_TO_PCI_IO_SET(_reg, _val)
#define GRPCI2_AHB2PCI_AHB_TO_PCI_IO(_val)
#define GRPCI2_DMACTRL_SAFE   0x80000000U
#define GRPCI2_DMACTRL_CHIRQ_SHIFT   12
#define GRPCI2_DMACTRL_CHIRQ_MASK   0xff000U
#define GRPCI2_DMACTRL_CHIRQ_GET(_reg)
#define GRPCI2_DMACTRL_CHIRQ_SET(_reg, _val)
#define GRPCI2_DMACTRL_CHIRQ(_val)
#define GRPCI2_DMACTRL_MA   0x800U
#define GRPCI2_DMACTRL_TA   0x400U
#define GRPCI2_DMACTRL_PE   0x200U
#define GRPCI2_DMACTRL_AE   0x100U
#define GRPCI2_DMACTRL_DE   0x80U
#define GRPCI2_DMACTRL_NUMCH_SHIFT   4
#define GRPCI2_DMACTRL_NUMCH_MASK   0x70U
#define GRPCI2_DMACTRL_NUMCH_GET(_reg)
#define GRPCI2_DMACTRL_NUMCH_SET(_reg, _val)
#define GRPCI2_DMACTRL_NUMCH(_val)
#define GRPCI2_DMACTRL_ACTIVE   0x8U
#define GRPCI2_DMACTRL_DIS   0x4U
#define GRPCI2_DMACTRL_IE   0x2U
#define GRPCI2_DMACTRL_EN   0x1U
#define GRPCI2_DMABASE_BASE_SHIFT   0
#define GRPCI2_DMABASE_BASE_MASK   0xffffffffU
#define GRPCI2_DMABASE_BASE_GET(_reg)
#define GRPCI2_DMABASE_BASE_SET(_reg, _val)
#define GRPCI2_DMABASE_BASE(_val)
#define GRPCI2_DMACHAN_CHAN_SHIFT   0
#define GRPCI2_DMACHAN_CHAN_MASK   0xffffffffU
#define GRPCI2_DMACHAN_CHAN_GET(_reg)
#define GRPCI2_DMACHAN_CHAN_SET(_reg, _val)
#define GRPCI2_DMACHAN_CHAN(_val)
#define GRPCI2_PCI2AHB_ADDR_SHIFT   0
#define GRPCI2_PCI2AHB_ADDR_MASK   0xffffffffU
#define GRPCI2_PCI2AHB_ADDR_GET(_reg)
#define GRPCI2_PCI2AHB_ADDR_SET(_reg, _val)
#define GRPCI2_PCI2AHB_ADDR(_val)
#define GRPCI2_AHBM2PCI_ADDR_SHIFT   0
#define GRPCI2_AHBM2PCI_ADDR_MASK   0xffffffffU
#define GRPCI2_AHBM2PCI_ADDR_GET(_reg)
#define GRPCI2_AHBM2PCI_ADDR_SET(_reg, _val)
#define GRPCI2_AHBM2PCI_ADDR(_val)
#define GRPCI2_TCTRC_TRIG_INDEX_SHIFT   16
#define GRPCI2_TCTRC_TRIG_INDEX_MASK   0xffff0000U
#define GRPCI2_TCTRC_TRIG_INDEX_GET(_reg)
#define GRPCI2_TCTRC_TRIG_INDEX_SET(_reg, _val)
#define GRPCI2_TCTRC_TRIG_INDEX(_val)
#define GRPCI2_TCTRC_AR   0x8000U
#define GRPCI2_TCTRC_EN   0x4000U
#define GRPCI2_TCTRC_DEPTH_SHIFT   4
#define GRPCI2_TCTRC_DEPTH_MASK   0xff0U
#define GRPCI2_TCTRC_DEPTH_GET(_reg)
#define GRPCI2_TCTRC_DEPTH_SET(_reg, _val)
#define GRPCI2_TCTRC_DEPTH(_val)
#define GRPCI2_TCTRC_SO   0x2U
#define GRPCI2_TCTRC_SA   0x1U
#define GRPCI2_TMODE_TRACING_MODE_SHIFT   24
#define GRPCI2_TMODE_TRACING_MODE_MASK   0xf000000U
#define GRPCI2_TMODE_TRACING_MODE_GET(_reg)
#define GRPCI2_TMODE_TRACING_MODE_SET(_reg, _val)
#define GRPCI2_TMODE_TRACING_MODE(_val)
#define GRPCI2_TMODE_TRIG_COUNT_SHIFT   16
#define GRPCI2_TMODE_TRIG_COUNT_MASK   0xff0000U
#define GRPCI2_TMODE_TRIG_COUNT_GET(_reg)
#define GRPCI2_TMODE_TRIG_COUNT_SET(_reg, _val)
#define GRPCI2_TMODE_TRIG_COUNT(_val)
#define GRPCI2_TMODE_DELAYED_STOP_SHIFT   0
#define GRPCI2_TMODE_DELAYED_STOP_MASK   0xffffU
#define GRPCI2_TMODE_DELAYED_STOP_GET(_reg)
#define GRPCI2_TMODE_DELAYED_STOP_SET(_reg, _val)
#define GRPCI2_TMODE_DELAYED_STOP(_val)
#define GRPCI2_TADP_PATTERN_SHIFT   0
#define GRPCI2_TADP_PATTERN_MASK   0xffffffffU
#define GRPCI2_TADP_PATTERN_GET(_reg)
#define GRPCI2_TADP_PATTERN_SET(_reg, _val)
#define GRPCI2_TADP_PATTERN(_val)
#define GRPCI2_TADM_MASK_SHIFT   0
#define GRPCI2_TADM_MASK_MASK   0xffffffffU
#define GRPCI2_TADM_MASK_GET(_reg)
#define GRPCI2_TADM_MASK_SET(_reg, _val)
#define GRPCI2_TADM_MASK(_val)
#define GRPCI2_TCP_CBE_3_0_SHIFT   16
#define GRPCI2_TCP_CBE_3_0_MASK   0xf0000U
#define GRPCI2_TCP_CBE_3_0_GET(_reg)
#define GRPCI2_TCP_CBE_3_0_SET(_reg, _val)
#define GRPCI2_TCP_CBE_3_0(_val)
#define GRPCI2_TCP_FRAME   0x8000U
#define GRPCI2_TCP_IRDY   0x4000U
#define GRPCI2_TCP_TRDY   0x2000U
#define GRPCI2_TCP_STOP   0x1000U
#define GRPCI2_TCP_DEVSEL   0x800U
#define GRPCI2_TCP_PAR   0x400U
#define GRPCI2_TCP_PERR   0x200U
#define GRPCI2_TCP_SERR   0x100U
#define GRPCI2_TCP_IDSEL   0x80U
#define GRPCI2_TCP_REQ   0x40U
#define GRPCI2_TCP_GNT   0x20U
#define GRPCI2_TCP_LOCK   0x10U
#define GRPCI2_TCP_RST   0x8U
#define GRPCI2_TCM_CBE_3_0_SHIFT   16
#define GRPCI2_TCM_CBE_3_0_MASK   0xf0000U
#define GRPCI2_TCM_CBE_3_0_GET(_reg)
#define GRPCI2_TCM_CBE_3_0_SET(_reg, _val)
#define GRPCI2_TCM_CBE_3_0(_val)
#define GRPCI2_TCM_FRAME   0x8000U
#define GRPCI2_TCM_IRDY   0x4000U
#define GRPCI2_TCM_TRDY   0x2000U
#define GRPCI2_TCM_STOP   0x1000U
#define GRPCI2_TCM_DEVSEL   0x800U
#define GRPCI2_TCM_PAR   0x400U
#define GRPCI2_TCM_PERR   0x200U
#define GRPCI2_TCM_SERR   0x100U
#define GRPCI2_TCM_IDSEL   0x80U
#define GRPCI2_TCM_REQ   0x40U
#define GRPCI2_TCM_GNT   0x20U
#define GRPCI2_TCM_LOCK   0x10U
#define GRPCI2_TCM_RST   0x8U
#define GRPCI2_TADS_SIGNAL_SHIFT   0
#define GRPCI2_TADS_SIGNAL_MASK   0xffffffffU
#define GRPCI2_TADS_SIGNAL_GET(_reg)
#define GRPCI2_TADS_SIGNAL_SET(_reg, _val)
#define GRPCI2_TADS_SIGNAL(_val)
#define GRPCI2_TCS_CBE_3_0_SHIFT   16
#define GRPCI2_TCS_CBE_3_0_MASK   0xf0000U
#define GRPCI2_TCS_CBE_3_0_GET(_reg)
#define GRPCI2_TCS_CBE_3_0_SET(_reg, _val)
#define GRPCI2_TCS_CBE_3_0(_val)
#define GRPCI2_TCS_FRAME   0x8000U
#define GRPCI2_TCS_IRDY   0x4000U
#define GRPCI2_TCS_TRDY   0x2000U
#define GRPCI2_TCS_STOP   0x1000U
#define GRPCI2_TCS_DEVSEL   0x800U
#define GRPCI2_TCS_PAR   0x400U
#define GRPCI2_TCS_PERR   0x200U
#define GRPCI2_TCS_SERR   0x100U
#define GRPCI2_TCS_IDSEL   0x80U
#define GRPCI2_TCS_REQ   0x40U
#define GRPCI2_TCS_GNT   0x20U
#define GRPCI2_TCS_LOCK   0x10U
#define GRPCI2_TCS_RST   0x8U
typedef struct grpci2 grpci2
