RTEMS 6.1-rc1
This group contains the GRPCI2 interfaces. More...
Modules | |
AHB master to PCI memory address mapping register (AHBM2PCI) | |
This group contains register bit definitions. | |
AHB to PCI mapping for PCI IO (AHB2PCI) | |
Control register (CTRL) | |
DMA channel active register (DMACHAN) | |
DMA control and status register (DMACTRL) | |
DMA descriptor base address register (DMABASE) | |
PCI BAR to AHB address mapping register (PCI2AHB) | |
PCI master prefetch burst limit (BCIM) | |
PCI trace AD mask register (TADM) | |
PCI trace AD pattern register (TADP) | |
PCI trace Control and Status register (TCTRC) | |
PCI trace Ctrl signal mask register (TCM) | |
PCI trace Ctrl signal pattern register (TCP) | |
PCI trace PCI AD state register (TADS) | |
PCI trace PCI Ctrl signal state register (TCS) | |
PCI trace counter and mode register (TMODE) | |
Status and Capability register (STATCAP) | |
Files | |
file | grpci2-regs.h |
This header file defines the GRPCI2 register block interface. | |
struct | grpci2 |
This structure defines the GRPCI2 register block memory map. More... | |
Typedefs | |
typedef struct grpci2 | grpci2 |
This structure defines the GRPCI2 register block memory map. | |
