RTEMS 6.1-rc1
Control register (CTRL)
This group contains register bit definitions. More...
#define GRPCI2_CTRL_RE   0x80000000U
#define GRPCI2_CTRL_MR   0x40000000U
#define GRPCI2_CTRL_TR   0x20000000U
#define GRPCI2_CTRL_SI   0x8000000U
#define GRPCI2_CTRL_PE   0x4000000U
#define GRPCI2_CTRL_ER   0x2000000U
#define GRPCI2_CTRL_EI   0x1000000U
#define GRPCI2_CTRL_BUS_NUMBER_SHIFT   16
#define GRPCI2_CTRL_BUS_NUMBER_MASK   0xff0000U
#define GRPCI2_CTRL_BUS_NUMBER_GET(_reg)
#define GRPCI2_CTRL_BUS_NUMBER_SET(_reg, _val)
#define GRPCI2_CTRL_BUS_NUMBER(_val)
#define GRPCI2_CTRL_DFA   0x800U
#define GRPCI2_CTRL_IB   0x400U
#define GRPCI2_CTRL_CB   0x200U
#define GRPCI2_CTRL_DIF   0x100U
#define GRPCI2_CTRL_DEVICE_INT_MASK_SHIFT   4
#define GRPCI2_CTRL_DEVICE_INT_MASK_MASK   0xf0U
#define GRPCI2_CTRL_DEVICE_INT_MASK_GET(_reg)
#define GRPCI2_CTRL_DEVICE_INT_MASK_SET(_reg, _val)
#define GRPCI2_CTRL_DEVICE_INT_MASK(_val)
#define GRPCI2_CTRL_HOST_INT_MASK_SHIFT   0
#define GRPCI2_CTRL_HOST_INT_MASK_MASK   0xfU
#define GRPCI2_CTRL_HOST_INT_MASK_GET(_reg)
#define GRPCI2_CTRL_HOST_INT_MASK_SET(_reg, _val)
#define GRPCI2_CTRL_HOST_INT_MASK(_val)
◆ GRPCI2_CTRL_BUS_NUMBER
#define GRPCI2_CTRL_BUS_NUMBER (   _val)
Value:
( ( ( _val ) << GRPCI2_CTRL_BUS_NUMBER_SHIFT ) & \
GRPCI2_CTRL_BUS_NUMBER_MASK )
◆ GRPCI2_CTRL_BUS_NUMBER_GET
#define GRPCI2_CTRL_BUS_NUMBER_GET (   _reg)
Value:
( ( ( _reg ) & GRPCI2_CTRL_BUS_NUMBER_MASK ) >> \
◆ GRPCI2_CTRL_BUS_NUMBER_SET
#define GRPCI2_CTRL_BUS_NUMBER_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GRPCI2_CTRL_BUS_NUMBER_MASK ) | \
GRPCI2_CTRL_BUS_NUMBER_MASK ) )
◆ GRPCI2_CTRL_DEVICE_INT_MASK
#define GRPCI2_CTRL_DEVICE_INT_MASK (   _val)
Value:
( ( ( _val ) << GRPCI2_CTRL_DEVICE_INT_MASK_SHIFT ) & \
GRPCI2_CTRL_DEVICE_INT_MASK_MASK )
◆ GRPCI2_CTRL_DEVICE_INT_MASK_GET
#define GRPCI2_CTRL_DEVICE_INT_MASK_GET (   _reg)
Value:
( ( ( _reg ) & GRPCI2_CTRL_DEVICE_INT_MASK_MASK ) >> \
◆ GRPCI2_CTRL_DEVICE_INT_MASK_SET
#define GRPCI2_CTRL_DEVICE_INT_MASK_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GRPCI2_CTRL_DEVICE_INT_MASK_MASK ) | \
GRPCI2_CTRL_DEVICE_INT_MASK_MASK ) )
◆ GRPCI2_CTRL_HOST_INT_MASK
#define GRPCI2_CTRL_HOST_INT_MASK (   _val)
Value:
( ( ( _val ) << GRPCI2_CTRL_HOST_INT_MASK_SHIFT ) & \
GRPCI2_CTRL_HOST_INT_MASK_MASK )
◆ GRPCI2_CTRL_HOST_INT_MASK_GET
#define GRPCI2_CTRL_HOST_INT_MASK_GET (   _reg)
Value:
( ( ( _reg ) & GRPCI2_CTRL_HOST_INT_MASK_MASK ) >> \
◆ GRPCI2_CTRL_HOST_INT_MASK_SET
#define GRPCI2_CTRL_HOST_INT_MASK_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GRPCI2_CTRL_HOST_INT_MASK_MASK ) | \
GRPCI2_CTRL_HOST_INT_MASK_MASK ) )
