RTEMS 6.3
Test context for spec:/rtems/ratemon/req/period test case. More...
struct  [struct].Map
rtems_id period_id
 This member contains a valid identifier of a period.
rtems_rate_monotonic_period_status period_status
 This member is used to receive the rtems_rate_monotonic_period_status after the action.
rtems_id id_param
 This member specifies the id parameter for the action.
rtems_interval length_param
 This member specifies the length parameter for the action.
rtems_status_code status
 This member contains the returned status code of the action.
uint32_t(*) do_action (void *ctx, void(*todo)(void *ctx_arg))
 This member contains the pointer to the function which executes the action.
void(*) worker_todo (void *ctx)
 This member serves to pass the pointer to the function which the work owner task shall execute from function OwnerDoWork to function WorkerTask.
rtems_id task_id
 This member contains the owner task identifier of the owner task.
rtems_id worker_id
 This member contains the owner task identifier of the worker task (which is not the owner task).
rtems_id original_priority
 This member contains a backup of the task priority before the execution of this test.
uint32_t postponed_jobs_count
 This member contains the number of postponed jobs before the action.
rtems_rate_monotonic_period_states previous_state
 This member contains the state before the action.
uint32_t test_duration
 This member contains the number of clock ticks passed since the test started.
uint32_t test_duration_till_action
 This member contains the number of clock ticks passed since the test started till (before) the rtems_rate_monotonic_period() action is invoked.
uint32_t period_calls
 This member contains the number of times the rtems_rate_monotonic_period() function returned since the test started.
uint32_t action_duration
 This member contains the number of clock ticks which passed in the action till the rtems_rate_monotonic_period() function returned.
struct  Map
Field Documentation
◆ do_action
uint32_t(*) RtemsRatemonReqPeriod_Context::do_action(void *ctx, void(*todo)(void *ctx_arg))
The action is either executed by the owner task or by the worker task depending on the function pointer used here. ctx_arg must be a pointer to this context structure.
