RTEMS 6.3
rtems_rate_monotonic_period_status Struct Reference
This structure provides the detailed status of a period. More...
#include <ratemon.h>
rtems_id owner
 This member contains the identifier of the owner task of the period.
rtems_rate_monotonic_period_states state
 This member contains the state of the period.
struct timespec since_last_period
 This member contains the time elapsed since the last successful invocation rtems_rate_monotonic_period() using CLOCK_MONOTONIC.
struct timespec executed_since_last_period
 This member contains the processor time consumed by the owner task since the last successful invocation rtems_rate_monotonic_period().
uint32_t postponed_jobs_count
 This member contains the count of jobs which are not released yet.
Field Documentation
◆ executed_since_last_period
struct timespec rtems_rate_monotonic_period_status::executed_since_last_period
If the period is expired or has not been initiated, then this value has no meaning.
◆ since_last_period
struct timespec rtems_rate_monotonic_period_status::since_last_period
