RTEMS 6.3
The Rate-Monotonic Manager provides facilities to implement tasks which execute in a periodic fashion. Critically, it also gathers information about the execution of those periods and can provide important statistics to the user which can be used to analyze and tune the application. More...
| struct | rtems_rate_monotonic_period_statistics |
| This structure provides the statistics of a period. More... | |
| struct | rtems_rate_monotonic_period_status |
| This structure provides the detailed status of a period. More... | |
| #define | RTEMS_PERIOD_STATUS WATCHDOG_NO_TIMEOUT |
| This constant is the interval passed to the rtems_rate_monotonic_period() directive to obtain status information. | |
Enumerations | |
| enum | rtems_rate_monotonic_period_states { RATE_MONOTONIC_INACTIVE , RATE_MONOTONIC_ACTIVE , RATE_MONOTONIC_EXPIRED } |
| This enumeration defines the states in which a period may be. More... | |
| rtems_status_code rtems_rate_monotonic_cancel | ( | rtems_id | id | ) |
Cancels the period.
| id | is the rate monotonic period identifier. |
This directive cancels the rate monotonic period specified by id. This period may be reinitiated by the next invocation of rtems_rate_monotonic_period().
| RTEMS_SUCCESSFUL | The requested operation was successful. |
| RTEMS_INVALID_ID | There was no rate monotonic period associated with the identifier specified by id. |
| RTEMS_NOT_OWNER_OF_RESOURCE | The rate monotonic period was not created by the calling task. |
The following constraints apply to this directive:
| rtems_status_code rtems_rate_monotonic_create | ( | rtems_name | name, |
| rtems_id * | id ) |
Creates a period.
| name | is the object name of the period. | |
| [out] | id | is the pointer to an rtems_id object. When the directive call is successful, the identifier of the created period will be stored in this object. |
This directive creates a period which resides on the local node. The period has the user-defined object name specified in name The assigned object identifier is returned in id. This identifier is used to access the period with other rate monotonic related directives.
| RTEMS_INVALID_NAME | The name parameter was invalid. |
| RTEMS_TOO_MANY | There was no inactive object available to create a period. The number of periods available to the application is configured through the CONFIGURE_MAXIMUM_PERIODS application configuration option. |
The calling task is registered as the owner of the created period. Some directives can be only used by this task for the created period.
For control and maintenance of the period, RTEMS allocates a PCB from the local PCB free pool and initializes it.
| rtems_status_code rtems_rate_monotonic_delete | ( | rtems_id | id | ) |
Deletes the period.
| id | is the period identifier. |
This directive deletes the period specified by id. If the period is running, it is automatically canceled.
| RTEMS_INVALID_ID | There was no period associated with the identifier specified by id. |
| rtems_status_code rtems_rate_monotonic_get_statistics | ( | rtems_id | id, |
| rtems_rate_monotonic_period_statistics * | status ) |
Gets the statistics of the period.
| id | is the rate monotonic period identifier. | |
| [out] | status | is the pointer to an rtems_rate_monotonic_period_statistics object. When the directive call is successful, the period statistics will be stored in this object. |
This directive returns the statistics of the rate monotonic period specified by id. The statistics of the period will be returned in the members of the period statistics object referenced by status:
| RTEMS_INVALID_ADDRESS | The status parameter was NULL. |
| rtems_status_code rtems_rate_monotonic_get_status | ( | rtems_id | id, |
| rtems_rate_monotonic_period_status * | status ) |
Gets the detailed status of the period.
| [out] | status | is the pointer to an rtems_rate_monotonic_period_status object. When the directive call is successful, the detailed period status will be stored in this object. |
This directive returns the detailed status of the rate monotonic period specified by id. The detailed status of the period will be returned in the members of the period status object referenced by status:
| rtems_status_code rtems_rate_monotonic_ident | ( | rtems_name | name, |
| rtems_id * | id ) |
Identifies a period by the object name.
| name | is the object name to look up. | |
| [out] | id | is the pointer to an rtems_id object. When the directive call is successful, the object identifier of an object with the specified name will be stored in this object. |
This directive obtains a period identifier associated with the period name specified in name.
| RTEMS_INVALID_ADDRESS | The id parameter was NULL. |
| RTEMS_INVALID_NAME | The name parameter was 0. |
| RTEMS_INVALID_NAME | There was no object with the specified name on the local node. |
If the period name is not unique, then the period identifier will match the first period with that name in the search order. However, this period identifier is not guaranteed to correspond to the desired period.
The objects are searched from lowest to the highest index. Only the local node is searched.
The period identifier is used with other rate monotonic related directives to access the period.
| rtems_status_code rtems_rate_monotonic_period | ( | rtems_id | id, |
| rtems_interval | length ) |
Concludes the current period and start the next period, or gets the period status.
| length | is the period length in clock ticks or RTEMS_PERIOD_STATUS to get the period status. |
This directive initiates the rate monotonic period specified by id with a length of period ticks specified by length. If the period is running, then the calling task will block for the remainder of the period before reinitiating the period with the specified period length. If the period was not running (either expired or never initiated), the period is immediately initiated and the directive returns immediately. If the period has expired, the postponed job will be released immediately and the following calls of this directive will release postponed jobs until there is no more deadline miss.
If invoked with a period length of RTEMS_PERIOD_STATUS ticks, the current state of the period will be returned. The directive status indicates the current state of the period. This does not alter the state or period length of the period.
| RTEMS_NOT_DEFINED | The rate monotonic period has never been initiated (only possible when the length parameter was equal to RTEMS_PERIOD_STATUS). |
| RTEMS_TIMEOUT | The rate monotonic period has expired. |
| void rtems_rate_monotonic_report_statistics | ( | void | ) |
Reports the period statistics using the printk() printer.
This directive prints a report on all active periods which have executed at least one period using the printk() printer.
| void rtems_rate_monotonic_report_statistics_with_plugin | ( | const struct rtems_printer * | printer | ) |
Reports the period statistics using the printer plugin.
| printer | is the printer plugin to output the report. |
This directive prints a report on all active periods which have executed at least one period using the printer plugin specified by printer.
| void rtems_rate_monotonic_reset_all_statistics | ( | void | ) |
Resets the statistics of all periods.
This directive resets the statistics information associated with all rate monotonic period instances.
| rtems_status_code rtems_rate_monotonic_reset_statistics | ( | rtems_id | id | ) |
Resets the statistics of the period.
This directive resets the statistics of the rate monotonic period specified by id.
