RTEMS 6.3
file  testsuites/validation/tc-ratemon-period.c
struct  RtemsRatemonReqPeriod_Entry
struct  RtemsRatemonReqPeriod_Context
 Test context for spec:/rtems/ratemon/req/period test case. More...
struct  RtemsRatemonReqPeriod_Context::[struct].Map
enum  RtemsRatemonReqPeriod_Pre_Id { RtemsRatemonReqPeriod_Pre_Id_Valid , RtemsRatemonReqPeriod_Pre_Id_Invalid , RtemsRatemonReqPeriod_Pre_Id_NA }
enum  RtemsRatemonReqPeriod_Pre_Caller { RtemsRatemonReqPeriod_Pre_Caller_OwnerTask , RtemsRatemonReqPeriod_Pre_Caller_OtherTask , RtemsRatemonReqPeriod_Pre_Caller_NA }
enum  RtemsRatemonReqPeriod_Pre_Length { RtemsRatemonReqPeriod_Pre_Length_Ticks , RtemsRatemonReqPeriod_Pre_Length_Status , RtemsRatemonReqPeriod_Pre_Length_NA }
enum  RtemsRatemonReqPeriod_Pre_State { RtemsRatemonReqPeriod_Pre_State_Inactive , RtemsRatemonReqPeriod_Pre_State_Active , RtemsRatemonReqPeriod_Pre_State_Expired , RtemsRatemonReqPeriod_Pre_State_NA }
enum  RtemsRatemonReqPeriod_Pre_Postponed { RtemsRatemonReqPeriod_Pre_Postponed_Zero , RtemsRatemonReqPeriod_Pre_Postponed_One , RtemsRatemonReqPeriod_Pre_Postponed_Several , RtemsRatemonReqPeriod_Pre_Postponed_NA }
enum  RtemsRatemonReqPeriod_Pre_InactiveCause { RtemsRatemonReqPeriod_Pre_InactiveCause_New , RtemsRatemonReqPeriod_Pre_InactiveCause_Canceled , RtemsRatemonReqPeriod_Pre_InactiveCause_NA }
enum  RtemsRatemonReqPeriod_Post_Status {
  RtemsRatemonReqPeriod_Post_Status_Ok , RtemsRatemonReqPeriod_Post_Status_InvId , RtemsRatemonReqPeriod_Post_Status_NotOwn , RtemsRatemonReqPeriod_Post_Status_NotDef ,
  RtemsRatemonReqPeriod_Post_Status_TimeOut , RtemsRatemonReqPeriod_Post_Status_NA
enum  RtemsRatemonReqPeriod_Post_State {
  RtemsRatemonReqPeriod_Post_State_Inactive , RtemsRatemonReqPeriod_Post_State_Active , RtemsRatemonReqPeriod_Post_State_Expired , RtemsRatemonReqPeriod_Post_State_Nop ,
  RtemsRatemonReqPeriod_Post_State_NA
enum  RtemsRatemonReqPeriod_Post_Postponed { RtemsRatemonReqPeriod_Post_Postponed_Zero , RtemsRatemonReqPeriod_Post_Postponed_OneOrMore , RtemsRatemonReqPeriod_Post_Postponed_Nop , RtemsRatemonReqPeriod_Post_Postponed_NA }
enum  RtemsRatemonReqPeriod_Post_Delay { RtemsRatemonReqPeriod_Post_Delay_None , RtemsRatemonReqPeriod_Post_Delay_TillDeadline , RtemsRatemonReqPeriod_Post_Delay_NA }
enum  RtemsRatemonReqPeriod_Post_Scheduler { RtemsRatemonReqPeriod_Post_Scheduler_Called , RtemsRatemonReqPeriod_Post_Scheduler_Nop , RtemsRatemonReqPeriod_Post_Scheduler_NA }
 T_TEST_CASE_FIXTURE (RtemsRatemonReqPeriod, &RtemsRatemonReqPeriod_Fixture)
