RTEMS 6.3
leon3.h File Reference
This header file provides interfaces used by the BSP implementation. More...
#include <grlib/apbuart-regs.h>
#include <grlib/gptimer-regs.h>
#include <bspopts.h>
#include <bsp/irqimpl.h>
#include <grlib/ambapp.h>
#include <sys/timetc.h>
struct  leon3_timecounter
 Represents the LEON3-specific timecounter. More...
#define LEON3_REG_CACHE_CTRL_FI   0x00200000U
 This constant represents the flush instruction cache flag of the LEON cache control register.
#define LEON3_REG_CACHE_CTRL_DS   0x00800000U
 This constant represents the data cache snooping enable flag of the LEON cache control register.
#define LEON3_CLOCK_INDEX   0
 This constant defines the index of the GPTIMER timer used by the clock driver.
#define LEON3_COUNTER_GPTIMER_INDEX   ( LEON3_CLOCK_INDEX + 1 )
 This constant defines the index of the GPTIMER timer used by the CPU counter if the CPU counter uses the GPTIMER.
#define LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER   1000000
 This constant defines the frequency set by the boot loader of the first GPTIMER instance.
RTEMS_NO_RETURN void leon3_power_down_loop (void)
 Sets asr19 to zero to enter the power-down mode of the processor in an infinite loop.
int leon3_timer_core_index
 This object lets the user override which on-chip GPTIMER core will be used for system clock timer.
unsigned int leon3_timer_prescaler
 This object lets the user override system clock timer prescaler.
gptimer * LEON3_Timer_Regs
 This pointer provides the GPTIMER register block address.
struct ambapp_dev * LEON3_Timer_Adev
 This pointer provides the GPTIMER device information block.
apbuart * leon3_debug_uart
 This pointer provides the debug APBUART register block address.
leon3_timecounter leon3_timecounter_instance
 Provides the LEON3-specific timecounter.
