RTEMS
6.3
Toggle main menu visibility
bsps
include
grlib
gptimer-regs.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2021 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
37
* This file is part of the RTEMS quality process and was automatically
38
* generated. If you find something that needs to be fixed or
39
* worded better please post a report or patch to an RTEMS mailing list
40
* or raise a bug report:
41
42
* https://www.rtems.org/bugs.html
43
44
* For information on updating and regenerating please refer to the How-To
45
* section in the Software Requirements Engineering chapter of the
46
* RTEMS Software Engineering manual. The manual is provided as a part of
47
* a release. For development sources please refer to the online
48
* documentation at:
49
50
* https://docs.rtems.org
51
52
53
/* Generated from spec:/dev/grlib/if/gptimer-header */
54
55
#ifndef _GRLIB_GPTIMER_REGS_H
56
#define _GRLIB_GPTIMER_REGS_H
57
58
#include <stdint.h>
59
60
#ifdef __cplusplus
61
extern
"C"
62
#endif
63
64
/* Generated from spec:/dev/grlib/if/group */
65
73
74
/* Generated from spec:/dev/grlib/if/gptimer-timer */
75
85
94
95
#define GPTIMER_TCNTVAL_TCVAL_SHIFT 0
96
#define GPTIMER_TCNTVAL_TCVAL_MASK 0xffffffffU
97
#define GPTIMER_TCNTVAL_TCVAL_GET( _reg ) \
98
( ( ( _reg ) & GPTIMER_TCNTVAL_TCVAL_MASK ) >> \
99
GPTIMER_TCNTVAL_TCVAL_SHIFT )
100
#define GPTIMER_TCNTVAL_TCVAL_SET( _reg, _val ) \
101
( ( ( _reg ) & ~GPTIMER_TCNTVAL_TCVAL_MASK ) | \
102
( ( ( _val ) << GPTIMER_TCNTVAL_TCVAL_SHIFT ) & \
103
GPTIMER_TCNTVAL_TCVAL_MASK ) )
104
#define GPTIMER_TCNTVAL_TCVAL( _val ) \
105
106
107
109
118
119
#define GPTIMER_TRLDVAL_TRLDVAL_SHIFT 0
120
#define GPTIMER_TRLDVAL_TRLDVAL_MASK 0xffffffffU
121
#define GPTIMER_TRLDVAL_TRLDVAL_GET( _reg ) \
122
( ( ( _reg ) & GPTIMER_TRLDVAL_TRLDVAL_MASK ) >> \
123
GPTIMER_TRLDVAL_TRLDVAL_SHIFT )
124
#define GPTIMER_TRLDVAL_TRLDVAL_SET( _reg, _val ) \
125
( ( ( _reg ) & ~GPTIMER_TRLDVAL_TRLDVAL_MASK ) | \
126
( ( ( _val ) << GPTIMER_TRLDVAL_TRLDVAL_SHIFT ) & \
127
GPTIMER_TRLDVAL_TRLDVAL_MASK ) )
128
#define GPTIMER_TRLDVAL_TRLDVAL( _val ) \
129
130
131
133
141
142
#define GPTIMER_TCTRL_WS 0x100U
143
144
#define GPTIMER_TCTRL_WN 0x80U
145
146
#define GPTIMER_TCTRL_DH 0x40U
147
148
#define GPTIMER_TCTRL_CH 0x20U
149
150
#define GPTIMER_TCTRL_IP 0x10U
151
152
#define GPTIMER_TCTRL_IE 0x8U
153
154
#define GPTIMER_TCTRL_LD 0x4U
155
156
#define GPTIMER_TCTRL_RS 0x2U
157
158
#define GPTIMER_TCTRL_EN 0x1U
159
161
169
170
#define GPTIMER_TLATCH_LTCV_SHIFT 0
171
#define GPTIMER_TLATCH_LTCV_MASK 0xffffffffU
172
#define GPTIMER_TLATCH_LTCV_GET( _reg ) \
173
( ( ( _reg ) & GPTIMER_TLATCH_LTCV_MASK ) >> \
174
GPTIMER_TLATCH_LTCV_SHIFT )
175
#define GPTIMER_TLATCH_LTCV_SET( _reg, _val ) \
176
( ( ( _reg ) & ~GPTIMER_TLATCH_LTCV_MASK ) | \
177
( ( ( _val ) << GPTIMER_TLATCH_LTCV_SHIFT ) & \
178
GPTIMER_TLATCH_LTCV_MASK ) )
179
#define GPTIMER_TLATCH_LTCV( _val ) \
180
181
182
184
188
typedef
struct
gptimer_timer
192
uint32_t
tcntval
193
197
uint32_t
trldval
198
202
uint32_t
tctrl
203
207
uint32_t
tlatch
208
gptimer_timer
209
211
212
/* Generated from spec:/dev/grlib/if/gptimer */
213
223
231
232
#define GPTIMER_SCALER_SCALER_SHIFT 0
233
#define GPTIMER_SCALER_SCALER_MASK 0xffffU
234
#define GPTIMER_SCALER_SCALER_GET( _reg ) \
235
( ( ( _reg ) & GPTIMER_SCALER_SCALER_MASK ) >> \
236
GPTIMER_SCALER_SCALER_SHIFT )
237
#define GPTIMER_SCALER_SCALER_SET( _reg, _val ) \
238
( ( ( _reg ) & ~GPTIMER_SCALER_SCALER_MASK ) | \
239
( ( ( _val ) << GPTIMER_SCALER_SCALER_SHIFT ) & \
240
GPTIMER_SCALER_SCALER_MASK ) )
241
#define GPTIMER_SCALER_SCALER( _val ) \
242
243
244
246
255
256
#define GPTIMER_SRELOAD_SRELOAD_SHIFT 0
257
#define GPTIMER_SRELOAD_SRELOAD_MASK 0xffffU
258
#define GPTIMER_SRELOAD_SRELOAD_GET( _reg ) \
259
( ( ( _reg ) & GPTIMER_SRELOAD_SRELOAD_MASK ) >> \
260
GPTIMER_SRELOAD_SRELOAD_SHIFT )
261
#define GPTIMER_SRELOAD_SRELOAD_SET( _reg, _val ) \
262
( ( ( _reg ) & ~GPTIMER_SRELOAD_SRELOAD_MASK ) | \
263
( ( ( _val ) << GPTIMER_SRELOAD_SRELOAD_SHIFT ) & \
264
GPTIMER_SRELOAD_SRELOAD_MASK ) )
265
#define GPTIMER_SRELOAD_SRELOAD( _val ) \
266
267
268
270
278
279
#define GPTIMER_CONFIG_EV 0x2000U
280
281
#define GPTIMER_CONFIG_ES 0x1000U
282
283
#define GPTIMER_CONFIG_EL 0x800U
284
285
#define GPTIMER_CONFIG_EE 0x400U
286
287
#define GPTIMER_CONFIG_DF 0x200U
288
289
#define GPTIMER_CONFIG_SI 0x100U
290
291
#define GPTIMER_CONFIG_IRQ_SHIFT 3
292
#define GPTIMER_CONFIG_IRQ_MASK 0xf8U
293
#define GPTIMER_CONFIG_IRQ_GET( _reg ) \
294
( ( ( _reg ) & GPTIMER_CONFIG_IRQ_MASK ) >> \
295
GPTIMER_CONFIG_IRQ_SHIFT )
296
#define GPTIMER_CONFIG_IRQ_SET( _reg, _val ) \
297
( ( ( _reg ) & ~GPTIMER_CONFIG_IRQ_MASK ) | \
298
( ( ( _val ) << GPTIMER_CONFIG_IRQ_SHIFT ) & \
299
GPTIMER_CONFIG_IRQ_MASK ) )
300
#define GPTIMER_CONFIG_IRQ( _val ) \
301
302
303
304
#define GPTIMER_CONFIG_TIMERS_SHIFT 0
305
#define GPTIMER_CONFIG_TIMERS_MASK 0x7U
306
#define GPTIMER_CONFIG_TIMERS_GET( _reg ) \
307
( ( ( _reg ) & GPTIMER_CONFIG_TIMERS_MASK ) >> \
308
GPTIMER_CONFIG_TIMERS_SHIFT )
309
#define GPTIMER_CONFIG_TIMERS_SET( _reg, _val ) \
310
( ( ( _reg ) & ~GPTIMER_CONFIG_TIMERS_MASK ) | \
311
( ( ( _val ) << GPTIMER_CONFIG_TIMERS_SHIFT ) & \
312
GPTIMER_CONFIG_TIMERS_MASK ) )
313
#define GPTIMER_CONFIG_TIMERS( _val ) \
314
315
316
318
327
328
#define GPTIMER_LATCHCFG_LATCHSEL_SHIFT 0
329
#define GPTIMER_LATCHCFG_LATCHSEL_MASK 0xffffffffU
330
#define GPTIMER_LATCHCFG_LATCHSEL_GET( _reg ) \
331
( ( ( _reg ) & GPTIMER_LATCHCFG_LATCHSEL_MASK ) >> \
332
GPTIMER_LATCHCFG_LATCHSEL_SHIFT )
333
#define GPTIMER_LATCHCFG_LATCHSEL_SET( _reg, _val ) \
334
( ( ( _reg ) & ~GPTIMER_LATCHCFG_LATCHSEL_MASK ) | \
335
( ( ( _val ) << GPTIMER_LATCHCFG_LATCHSEL_SHIFT ) & \
336
GPTIMER_LATCHCFG_LATCHSEL_MASK ) )
337
#define GPTIMER_LATCHCFG_LATCHSEL( _val ) \
338
339
340
342
346
typedef
struct
gptimer
350
uint32_t
scaler
351
355
uint32_t
sreload
356
360
uint32_t
config
361
365
uint32_t
latchcfg
366
370
gptimer_timer
timer
[ 15 ];
371
gptimer
372
374
375
#ifdef __cplusplus
376
377
#endif
378
379
#endif
/* _GRLIB_GPTIMER_REGS_H */
gptimer_timer
This structure defines the GPTIMER TIMER register block memory map.
Definition
gptimer-regs.h:188
gptimer_timer::tctrl
uint32_t tctrl
See Timer n control register (TCTRL).
Definition
gptimer-regs.h:202
gptimer_timer::trldval
uint32_t trldval
See Timer n counter reload value register (TRLDVAL).
Definition
gptimer-regs.h:197
gptimer_timer::tcntval
uint32_t tcntval
See Timer n counter value register (TCNTVAL).
Definition
gptimer-regs.h:192
gptimer_timer::tlatch
uint32_t tlatch
See Timer n latch register (TLATCH).
Definition
gptimer-regs.h:207
gptimer
This structure defines the GPTIMER register block memory map.
Definition
gptimer-regs.h:346
gptimer::timer
gptimer_timer timer[15]
See GPTIMER TIMER.
Definition
gptimer-regs.h:370
gptimer::sreload
uint32_t sreload
See Scaler reload value register (SRELOAD).
Definition
gptimer-regs.h:355
gptimer::scaler
uint32_t scaler
See Scaler value register (SCALER).
Definition
gptimer-regs.h:350
gptimer::config
uint32_t config
See Configuration register (CONFIG).
Definition
gptimer-regs.h:360
gptimer::latchcfg
uint32_t latchcfg
See Timer latch configuration register (LATCHCFG).
Definition
gptimer-regs.h:365
