RTEMS
6.3
Toggle main menu visibility
bsps
include
grlib
ambapp.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
7
8
9
* COPYRIGHT (c) 2009.
10
* Aeroflex Gaisler.
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef __AMBAPP_H__
35
#define __AMBAPP_H__
36
37
#include <stddef.h>
38
39
/* Include VENDOR and DEVICE definitions */
40
#include "
ambapp_ids.h
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
45
55
56
/* Max supported AHB buses */
57
#define AHB_BUS_MAX 6
58
59
#define AMBAPP_FLAG_FFACT_DIR 0x100
/* Frequency factor direction, 0=down, 1=up */
60
#define AMBAPP_FLAG_FFACT 0x0f0
/* Frequency factor against top bus */
61
#define AMBAPP_FLAG_MBUS 0x00c
62
#define AMBAPP_FLAG_SBUS 0x003
63
64
/* Get APB or AHB information from a AMBA device */
65
#define DEV_TO_APB(adev) ((struct ambapp_apb_info *)((adev)->devinfo))
66
#define DEV_TO_AHB(adev) ((struct ambapp_ahb_info *)((adev)->devinfo))
67
#define DEV_TO_COMMON(adev) (((adev)->devinfo))
68
69
struct
ambapp_common_info
70
unsigned
char
irq;
71
unsigned
char
ver;
72
unsigned
char
ahbidx;
/* AHB Bus Index */
73
74
75
struct
ambapp_apb_info
76
struct
ambapp_common_info
common;
77
78
/* APB SPECIFIC */
79
unsigned
int
start;
80
unsigned
int
mask;
81
82
83
struct
ambapp_ahb_info
84
struct
ambapp_common_info
common;
85
86
/* AHB SPECIFIC */
87
unsigned
int
start[4];
88
unsigned
int
mask[4];
89
char
type[4];
/* type[N] Determine type of start[N]-mask[N],
90
* 2=AHB Memory Space, 3=AHB I/O Space */
91
unsigned
int
custom[3];
92
93
94
struct
ambapp_dev
95
struct
ambapp_dev
*next;
/* Next */
96
struct
ambapp_dev
*prev;
/* Previous Device. If (this ==
97
* rev->child) prev is bus bridge */
98
struct
ambapp_dev
*children;
/* Points to first device on sub-bus */
99
void
*owner;
/* Owner of this AMBA device */
100
unsigned
char
dev_type;
/* AHB MST, AHB SLV or APB SLV*/
101
unsigned
char
vendor;
/* Vendor ID */
102
unsigned
short
device;
/* Device ID */
103
104
/* Device info (APB/AHB dep. on type) */
105
struct
ambapp_common_info
devinfo[0];
106
107
108
/* Describes a complete AMBA Core. Each device may consist of 3 interfaces */
109
struct
ambapp_core
110
char
irq;
/* irq=-1 indicate no IRQ */
111
unsigned
char
vendor;
112
unsigned
short
device;
113
int
index;
/* Core index */
114
struct
ambapp_ahb_info
*ahb_mst;
115
struct
ambapp_ahb_info
*ahb_slv;
116
struct
ambapp_apb_info
*apb_slv;
117
118
119
struct
ambapp_ahb_bus
120
unsigned
int
ioarea;
/* AHB Bus IOAREA */
121
unsigned
int
freq_hz;
/* Frequency of AHB Bus */
122
struct
ambapp_dev
*bridge;
/* Bridge Device on Parent AHB Bus */
123
struct
ambapp_dev
*dev;
/* First Device on AHB Bus */
124
125
126
struct
ambapp_mmap
127
unsigned
int
size;
128
unsigned
int
local_adr;
129
unsigned
int
remote_adr;
130
131
132
/* Complete AMBA PnP information */
133
struct
ambapp_bus
134
struct
ambapp_dev
*root;
/* AHB/APB Device Tree*/
135
struct
ambapp_mmap
*mmaps;
/* Memory MAP Array */
136
struct
ambapp_ahb_bus
ahbs[AHB_BUS_MAX];
/* AHB Buses */
137
138
139
140
* Return values
141
* 0 - continue
142
* 1 - stop scanning
143
144
typedef
int (*ambapp_func_t)(
struct
ambapp_dev
*dev,
int
index,
void
*arg);
145
146
#define DEV_IS_FREE(dev) (dev->owner == NULL)
147
#define DEV_IS_ALLOCATED(dev) (dev->owner != NULL)
148
149
/* Options to ambapp_for_each */
150
#define OPTIONS_AHB_MSTS 0x00000001
151
#define OPTIONS_AHB_SLVS 0x00000002
152
#define OPTIONS_APB_SLVS 0x00000004
153
#define OPTIONS_ALL_DEVS (OPTIONS_AHB_MSTS|OPTIONS_AHB_SLVS|OPTIONS_APB_SLVS)
154
155
#define OPTIONS_FREE 0x00000010
156
#define OPTIONS_ALLOCATED 0x00000020
157
#define OPTIONS_ALL (OPTIONS_FREE|OPTIONS_ALLOCATED)
158
159
/* Depth first search, Defualt is breath first search. */
160
#define OPTIONS_DEPTH_FIRST 0x00000100
161
162
#define DEV_AHB_NONE 0
163
#define DEV_AHB_MST 1
164
#define DEV_AHB_SLV 2
165
#define DEV_APB_SLV 3
166
167
/* Structures used to access Plug&Play information directly */
168
struct
ambapp_pnp_ahb
169
const
unsigned
int
id;
/* VENDOR, DEVICE, VER, IRQ, */
170
const
unsigned
int
custom[3];
171
const
unsigned
int
mbar[4];
/* MASK, ADDRESS, TYPE, CACHABLE/PREFETCHABLE */
172
173
174
struct
ambapp_pnp_apb
175
const
unsigned
int
id;
176
const
unsigned
int
iobar;
177
178
179
#define ambapp_pnp_vendor(id) (((id) >> 24) & 0xff)
180
#define ambapp_pnp_device(id) (((id) >> 12) & 0xfff)
181
#define ambapp_pnp_ver(id) (((id)>>5) & 0x1f)
182
#define ambapp_pnp_irq(id) ((id) & 0x1f)
183
184
#define ambapp_pnp_start(mbar) (((mbar) & 0xfff00000) & (((mbar) & 0xfff0) << 16))
185
#define ambapp_pnp_mbar_mask(mbar) (((mbar)>>4) & 0xfff)
186
#define ambapp_pnp_mbar_type(mbar) ((mbar) & 0xf)
187
188
#define ambapp_pnp_apb_start(iobar, base) ((base) | ((((iobar) & 0xfff00000)>>12) & (((iobar) & 0xfff0)<<4)) )
189
#define ambapp_pnp_apb_mask(iobar) ((~(ambapp_pnp_mbar_mask(iobar)<<8) & 0x000fffff) + 1)
190
191
#define AMBA_TYPE_AHBIO_ADDR(addr,base_ioarea) ((unsigned int)(base_ioarea) | ((addr) >> 12))
192
193
#define AMBA_TYPE_APBIO 0x1
194
#define AMBA_TYPE_MEM 0x2
195
#define AMBA_TYPE_AHBIO 0x3
196
197
/* Copy Data from AMBA PnP I/O Area */
198
typedef
void
*(*ambapp_memcpy_t)(
199
void
*dest,
/* Destination RAM copy */
200
const
void
*src,
/* Source AMBA PnP Address to copy from */
201
int
n,
/* Number of bytes to be copied */
202
struct
ambapp_bus
*abus
/* Optional AMBA Bus pointer */
203
204
205
struct
ambapp_context
206
ambapp_memcpy_t copy_from_device;
207
void
*(*alloc)(size_t);
208
209
213
extern
struct
ambapp_bus
ambapp_plb
void
214
215
/* Scan a AMBA Plug & Play bus and create all device structures describing the
216
* the devices. The devices will form a tree, where every node describes one
217
* interface. The resulting tree is placed in the location pointed to by root.
218
219
* Since it the tree is located in RAM it is easier to work with AMBA buses
220
* that is located over PCI and SpaceWire etc.
221
222
* \param abus Resulting device node tree root is stored here.
223
* \param ioarea The IO-AREA where Plug & Play information can be found.
224
* \param ctx The scan context. May be NULL.
225
* \param mmaps Is used to perform address translation if needed.
226
227
228
extern
int
ambapp_scan(
229
struct
ambapp_bus
*abus,
230
unsigned
int
ioarea,
231
const
struct
ambapp_context
*ctx,
232
struct
ambapp_mmap
*mmaps
233
234
235
/* Initialize the frequency [Hz] of all AHB Buses from knowing the frequency
236
* of one particular APB/AHB Device.
237
238
extern
void
ambapp_freq_init(
239
struct
ambapp_bus
*abus,
240
struct
ambapp_dev
*dev,
241
unsigned
int
freq);
242
243
/* Returns the frequency [Hz] of a AHB/APB device */
244
extern
unsigned
int
ambapp_freq_get(
245
struct
ambapp_bus
*abus,
246
struct
ambapp_dev
*dev);
247
248
/* Iterates through all AMBA devices previously found, it calls func
249
* once for every device that match the search arguments.
250
251
* SEARCH OPTIONS
252
* All search options must be fulfilled, type of devices searched (options)
253
* and AMBA Plug&Play ID [VENDOR,DEVICE], before func() is called. The options
254
* can be use to search only for AMBA APB or AHB Slaves or AHB Masters for
255
* example. Note that when VENDOR=-1 or DEVICE=-1 it will match any vendor or
256
* device ID, this means setting both VENDOR and DEVICE to -1 will result in
257
* calling all devices matches the options argument.
258
259
* \param abus AMBAPP Bus to search
260
* \param options Search options, see OPTIONS_* above
261
* \param vendor AMBAPP VENDOR ID to search for
262
* \param device AMBAPP DEVICE ID to search for
263
* \param func Function called for every device matching search options
264
* \param arg Optional argument passed on to func
265
266
* func return value affects the search, returning a non-zero value will
267
* stop the search and ambapp_for_each will return immediately returning the
268
* same non-zero value.
269
270
* Return Values
271
* 0 - all devices was scanned
272
* non-zero - stopped by user function returning the non-zero value
273
274
extern
int
ambapp_for_each(
275
struct
ambapp_bus
*abus,
276
unsigned
int
options,
277
int
vendor,
278
int
device,
279
ambapp_func_t func,
280
void
*arg);
281
282
/* Helper function for ambapp_for_each(), find a device by index. If pcount
283
* is NULL the first device is returned, else pcount is interpreted as index
284
* by decrementing the value until zero is reaced: *count=0 first device,
285
* *count=1 second device etc.
286
287
* The matching device is returned, which will stop the ambapp_for_each search.
288
* If zero is returned from ambapp_for_each no device matching the index was
289
* found
290
291
extern
int
ambapp_find_by_idx(
struct
ambapp_dev
*dev,
int
index,
void
*pcount);
292
293
/* Get number of devices matching the options/vendor/device arguments, the
294
* arguments are passed onto ambapp_for_each().
295
296
extern
int
ambapp_dev_count(
struct
ambapp_bus
*abus,
unsigned
int
options,
297
int
vendor,
int
device);
298
299
/* Print short information about devices on the AMBA bus onto the console */
300
extern
void
ambapp_print(
struct
ambapp_bus
*abus,
int
show_depth);
301
302
/* Mark a device taken (allocate), Owner field is set with owner Data. Returns
303
* -1 if device has already been allocated.
304
305
extern
int
ambapp_alloc_dev(
struct
ambapp_dev
*dev,
void
*owner);
306
307
/* Owner field is cleared, which indicates that device is not allocated */
308
extern
void
ambapp_free_dev(
struct
ambapp_dev
*dev);
309
310
/* Find AHB/APB Bridge or AHB/AHB Bridge Parent */
311
extern
struct
ambapp_dev
*ambapp_find_parent(
struct
ambapp_dev
*dev);
312
313
/* Returns bus depth (number of sub AHB buses) of device from root bus */
314
extern
int
ambapp_depth(
struct
ambapp_dev
*dev);
315
316
/* Get Device Name from AMBA PnP name database */
317
extern
char
*ambapp_device_id2str(
int
vendor,
int
id
318
319
/* Get Vendor Name from AMBA PnP name database */
320
extern
char
*ambapp_vendor_id2str(
int
vendor);
321
322
/* Set together VENDOR_DEVICE Name from AMBA PnP name database. Return length
323
* of C-string stored in buf not including string termination '\0'.
324
325
extern
int
ambapp_vendev_id2str(
int
vendor,
int
id
char
*buf);
326
327
/* Help functions for backwards compability */
328
329
extern
int
ambapp_find_apbslv(
330
struct
ambapp_bus
*abus,
331
int
vendor,
332
int
device,
333
struct
ambapp_apb_info
*dev);
334
335
extern
int
ambapp_find_apbslv_next(
336
struct
ambapp_bus
*abus,
337
int
vendor,
338
int
device,
339
struct
ambapp_apb_info
*dev,
340
int
index);
341
342
extern
int
ambapp_find_apbslvs_next(
343
struct
ambapp_bus
*abus,
344
int
vendor,
345
int
device,
346
struct
ambapp_apb_info
*dev,
347
int
index,
348
int
maxno);
349
350
extern
int
ambapp_find_apbslvs(
351
struct
ambapp_bus
*abus,
352
int
vendor,
353
int
device,
354
struct
ambapp_apb_info
*dev,
355
int
maxno);
356
357
extern
int
ambapp_find_ahbslv(
358
struct
ambapp_bus
*abus,
359
int
vendor,
360
int
device,
361
struct
ambapp_ahb_info
*dev);
362
363
extern
int
ambapp_find_ahbslv_next(
364
struct
ambapp_bus
*abus,
365
int
vendor,
366
int
device,
367
struct
ambapp_ahb_info
*dev,
368
int
index);
369
370
extern
int
ambapp_find_ahbslvs_next(
371
struct
ambapp_bus
*abus,
372
int
vendor,
373
int
device,
374
struct
ambapp_ahb_info
*dev,
375
int
index,
376
int
maxno);
377
378
extern
int
ambapp_find_ahbslvs(
379
struct
ambapp_bus
*abus,
380
int
vendor,
381
int
device,
382
struct
ambapp_ahb_info
*dev,
383
int
maxno);
384
385
386
extern
int
ambapp_get_number_ahbslv_devices(
387
struct
ambapp_bus
*abus,
388
int
vendor,
389
int
device);
390
391
extern
int
ambapp_get_number_apbslv_devices(
392
struct
ambapp_bus
*abus,
393
int
vendor,
394
int
device);
395
396
#ifdef __cplusplus
397
398
#endif
399
401
402
#endif
ambapp_ids.h
AMBA Plug & Play Bus Vendor and Device IDs.
ambapp_plb
struct ambapp_bus * ambapp_plb(void)
Gets the fully scanned AMBA Plug & Play Processor Local Bus (PLB).
Definition
bspstart.c:58
ambapp_ahb_bus
Definition
ambapp.h:119
ambapp_ahb_info
Definition
ambapp.h:83
ambapp_apb_info
Definition
ambapp.h:75
ambapp_bus
Definition
ambapp.h:133
ambapp_common_info
Definition
ambapp.h:69
ambapp_context
Definition
ambapp.h:205
ambapp_core
Definition
ambapp.h:109
ambapp_dev
Definition
ambapp.h:94
ambapp_mmap
Definition
ambapp.h:126
ambapp_pnp_ahb
Definition
ambapp.h:168
ambapp_pnp_apb
Definition
ambapp.h:174
