RTEMS
6.3
Toggle main menu visibility
include
sys
timetc.h
1
9
10
11
12
* "THE BEER-WARE LICENSE" (Revision 42):
13
* <phk@FreeBSD.ORG> wrote this file. As long as you retain this notice you
14
* can do whatever you want with this stuff. If we meet some day, and you think
15
* this stuff is worth it, you can buy me a beer in return. Poul-Henning Kamp
16
17
18
19
#ifndef _SYS_TIMETC_H_
20
#define _SYS_TIMETC_H_
21
22
#ifndef __rtems__
23
#ifndef _KERNEL
24
#error "no user-serviceable parts inside"
25
#endif
26
#else
/* __rtems__ */
27
#ifdef __cplusplus
28
extern
"C"
29
#endif
/* __cplusplus */
30
#endif
/* __rtems__ */
31
32
33
* `struct timecounter' is the interface between the hardware which implements
34
* a timecounter and the MI code which uses this to keep track of time.
35
36
* A timecounter is a binary counter which has two properties:
37
* * it runs at a fixed, known frequency.
38
* * it has sufficient bits to not roll over in less than approximately
39
* max(2 msec, 2/HZ seconds). (The value 2 here is really 1 + delta,
40
* for some indeterminate value of delta.)
41
42
43
struct
timecounter
44
struct
vdso_timehands;
45
struct
vdso_timehands32;
46
#ifndef __rtems__
47
typedef
u_int timecounter_get_t(
struct
timecounter
48
#else
/* __rtems__ */
49
typedef
uint32_t timecounter_get_t(
struct
timecounter
50
#define tc_getfrequency _Timecounter_Get_frequency
51
#endif
/* __rtems__ */
52
typedef
void
timecounter_pps_t(
struct
timecounter
53
typedef
uint32_t timecounter_fill_vdso_timehands_t(
struct
vdso_timehands *,
54
struct
timecounter
55
typedef
uint32_t timecounter_fill_vdso_timehands32_t(
struct
vdso_timehands32 *,
56
struct
timecounter
57
58
struct
timecounter
59
timecounter_get_t *tc_get_timecount;
60
#ifndef __rtems__
61
62
* This function reads the counter. It is not required to
63
* mask any unimplemented bits out, as long as they are
64
* constant.
65
66
timecounter_pps_t *tc_poll_pps;
67
#endif
/* __rtems__ */
68
69
* This function is optional. It will be called whenever the
70
* timecounter is rewound, and is intended to check for PPS
71
* events. Normal hardware does not need it but timecounters
72
* which latch PPS in hardware do.
73
74
uint32_t tc_counter_mask;
75
/* This mask should mask off any unimplemented bits. */
76
uint64_t tc_frequency;
77
/* Frequency of the counter in Hz. */
78
const
char
*tc_name;
79
/* Name of the timecounter. */
80
int
tc_quality;
81
#ifndef __rtems__
82
83
* Used to determine if this timecounter is better than
84
* another timecounter higher means better. Negative
85
* means "only use at explicit request".
86
87
u_int tc_flags;
88
#define TC_FLAGS_C2STOP 1
/* Timer dies in C2+. */
89
#define TC_FLAGS_SUSPEND_SAFE 2
90
* Timer functional across
91
* suspend/resume.
92
93
94
void
*tc_priv;
95
/* Pointer to the timecounter's private parts. */
96
struct
timecounter
*tc_next;
97
/* Pointer to the next timecounter. */
98
timecounter_fill_vdso_timehands_t *tc_fill_vdso_timehands;
99
timecounter_fill_vdso_timehands32_t *tc_fill_vdso_timehands32;
100
#endif
/* __rtems__ */
101
102
103
extern
struct
timecounter
timecounter
104
extern
int
tc_min_ticktock_freq;
105
* Minimal tc_ticktock() call frequency,
106
* required to handle counter wraps.
107
108
109
u_int64_t tc_getfrequency(
void
110
void
tc_init(
struct
timecounter
*tc);
111
void
tc_setclock(
struct
timespec *ts);
112
void
tc_ticktock(
int
cnt);
113
void
cpu_tick_calibration(
void
114
115
#ifdef SYSCTL_DECL
116
SYSCTL_DECL(_kern_timecounter);
117
#endif
118
119
#ifdef __rtems__
120
#ifdef __cplusplus
121
122
#endif
/* __cplusplus */
123
#endif
/* __rtems__ */
124
#endif
/* !_SYS_TIMETC_H_ */
timecounter
Definition
timetc.h:58
