RTEMS 6.3
LEON3 and LEON4
LEON3 and LEON4 Board Support Package. More...
Topics
 GR740 Bootstrap Signals
 This group contains the GR740 Bootstrap Signals interfaces.
 GR740 I/0 and PLL Configuration
 This group contains the GR740 I/0 and PLL Configuration interfaces.
 GR740 Temperatur Sensor Controller
 This group contains the GR740 Temperatur Sensor Controller interfaces.
 LEON3 AMBA Driver Handler
 AMBA Plag & Play Bus Driver Macros.
file  bsps/sparc/include/bsp/gr_leon4_n2x.h
 This header file provides interfaces of the GR-CPCI-LEON4-N2X (NGFP) PCI Peripheral driver.
file  bsps/sparc/leon3/clock/ckinit.c
 This source file contains the Clock Driver implementation.
file  bsps/sparc/leon3/console/printk_support.c
 This source file contains the definition of BSP_output_char and BSP_poll_char.
file  bsps/sparc/leon3/gnatsupp/gnatsupp.c
 Support for gnat/rtems interrupts and exception handling.
file  bsps/sparc/leon3/include/bsp.h
 Global BSP definitions.
file  bsps/sparc/leon3/include/bsp/irq.h
 LEON3 generic shared IRQ setup.
file  bsps/sparc/leon3/include/bsp/irqimpl.h
 This header file provides interfaces used by the interrupt support implementation.
file  bsps/sparc/leon3/include/bsp/leon3.h
 This header file provides interfaces used by the BSP implementation.
file  bsps/sparc/leon3/include/leon.h
 LEON3 BSP data types and macros.
file  bsps/sparc/leon3/include/tm27.h
 Implementations for interrupt mechanisms for Time Test 27.
file  bsps/sparc/leon3/start/bspsmp.c
 LEON3 SMP BSP Support.
file  bsps/sparc/leon3/start/bspstart.c
 This source file contains the implementation of bsp_start() and definitions of BSP-specific objects.
file  bsps/sparc/leon3/start/cache.c
 This source file contains the implementation of the Cache Manager.
file  bsps/sparc/leon3/start/cpucounter.c
 This source file contains the implementation of the CPU Counter.
file  bsps/sparc/leon3/start/eirq.c
 This source file contains the implementation of the interrupt controller support.
file  bsps/sparc/leon3/start/gettargethash.c
 This source file contains the sparc/leon3 implementation of rtems_get_target_hash().
file  bsps/sparc/leon3/start/setvec.c
 Install an interrupt vector on SPARC.
file  bsps/sparc/shared/irq/bsp_isr_handler.c
 This source file contains the implementation of _SPARC_Interrupt_dispatch().
struct  leon3_timecounter
 Represents the LEON3-specific timecounter. More...
#define LEON3   1
#define BSP_FEATURE_IRQ_EXTENSION
#define BSP_IDLE_TASK_BODY   bsp_idle_thread
#define BSP_NUMBER_OF_TERMIOS_PORTS   8
#define RTEMS_BSP_NETWORK_DRIVER_NAME_OPENETH   "open_eth1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_OPENETH   rtems_leon_open_eth_driver_attach
#define RTEMS_BSP_NETWORK_DRIVER_NAME_SMC91111   "smc_eth1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_SMC91111   rtems_smc91111_driver_attach_leon3
#define RTEMS_BSP_NETWORK_DRIVER_NAME_GRETH   "gr_eth1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_GRETH   rtems_leon_greth_driver_attach
#define RTEMS_BSP_NETWORK_DRIVER_NAME   RTEMS_BSP_NETWORK_DRIVER_NAME_GRETH
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   RTEMS_BSP_NETWORK_DRIVER_ATTACH_GRETH
#define HAS_SMC91111
#define GRETH_SUPPORTED
#define GRETH_MEM_LOAD(addr)
#define AMBAPPBUS_INFO_AVAIL
#define APBUART_INFO_AVAIL
#define GPTIMER_INFO_AVAIL
#define GRETH_INFO_AVAIL
#define LEON3_IRQCTRL_ACQUIRE(_lock_context)
 Acquires the interrupt controller lock.
#define LEON3_IRQCTRL_RELEASE(_lock_context)
 Releases the interrupt controller lock.
#define LEON3_REG_CACHE_CTRL_FI   0x00200000U
 This constant represents the flush instruction cache flag of the LEON cache control register.
#define LEON3_REG_CACHE_CTRL_DS   0x00800000U
 This constant represents the data cache snooping enable flag of the LEON cache control register.
#define LEON3_CLOCK_INDEX   0
 This constant defines the index of the GPTIMER timer used by the clock driver.
#define LEON3_COUNTER_GPTIMER_INDEX   ( LEON3_CLOCK_INDEX + 1 )
 This constant defines the index of the GPTIMER timer used by the CPU counter if the CPU counter uses the GPTIMER.
#define LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER   1000000
 This constant defines the frequency set by the boot loader of the first GPTIMER instance.
typedef void(*) bsp_shared_isr(void *arg)
void * bsp_idle_thread (uintptr_t ignored)
 Optimized idle task.
int rtems_leon_open_eth_driver_attach (struct rtems_bsdnet_ifconfig *config, int attach)
int rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config, int attach)
int rtems_leon_greth_driver_attach (struct rtems_bsdnet_ifconfig *config, int attach)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
void BSP_fatal_exit (uint32_t error)
void rtems_bsp_delay (int usecs)
void leon3_ext_irq_init (irqamp *regs)
 Initializes the interrupt controller for the boot processor.
RTEMS_NO_RETURN void leon3_power_down_loop (void)
 Sets asr19 to zero to enter the power-down mode of the processor in an infinite loop.
int CPU_SPARC_HAS_SNOOPING
int RAM_START
int RAM_END
int RAM_SIZE
int PROM_START
int PROM_END
int PROM_SIZE
int CLOCK_SPEED
int end
uint32_t LEON3_Cpu_Index
 This object provides the index of the boot processor.
rtems_interrupt_lock LEON3_IrqCtrl_Lock
 This lock serializes the interrupt controller access.
irqamp * LEON3_IrqCtrl_Regs
 This pointer provides the IRQ(A)MP register block address.
struct ambapp_dev * LEON3_IrqCtrl_Adev
 This pointer provides the IRQ(A)MP device information block.
uint32_t LEON3_IrqCtrl_EIrq
 This object provides the interrupt number used to multiplex extended interrupts or is zero if no extended interrupts are available.
int leon3_timer_core_index
 This object lets the user override which on-chip GPTIMER core will be used for system clock timer.
unsigned int leon3_timer_prescaler
 This object lets the user override system clock timer prescaler.
gptimer * LEON3_Timer_Regs
 This pointer provides the GPTIMER register block address.
struct ambapp_dev * LEON3_Timer_Adev
 This pointer provides the GPTIMER device information block.
apbuart * leon3_debug_uart
 This pointer provides the debug APBUART register block address.
leon3_timecounter leon3_timecounter_instance
 Provides the LEON3-specific timecounter.
◆ GRETH_MEM_LOAD
#define GRETH_MEM_LOAD ( addr)
Value:
leon_r32_no_cache((uintptr_t)addr)
◆ LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER
We assume that a boot loader (usually GRMON) initialized the GPTIMER 0 to run with 1MHz. This is used to determine all clock frequencies of the PnP devices. See also ambapp_freq_init() and ambapp_freq_get().
◆ LEON3_IRQCTRL_ACQUIRE
#define LEON3_IRQCTRL_ACQUIRE ( _lock_context)
Value:
#define rtems_interrupt_lock_acquire(_lock, _lock_context)
Acquires the ISR lock.
Definition intr.h:666
Definition eirq.c:50
Parameters
[out]_lock_contextis the lock context.
◆ LEON3_IRQCTRL_RELEASE
#define LEON3_IRQCTRL_RELEASE ( _lock_context)
Value:
#define rtems_interrupt_lock_release(_lock, _lock_context)
Releases the ISR lock.
Definition intr.h:709
Parameters
[in,out]_lock_contextis the lock context.
◆ bsp_idle_thread()
void * bsp_idle_thread ( uintptr_t ignored)
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
#include <bsp.h>
#define CONFIGURE_INIT
#define CONFIGURE_IDLE_TASK_BODY bsp_idle_thread
#include <confdefs.h>
This header file evaluates the application configuration options defined by the application.
◆ leon3_ext_irq_init()
void leon3_ext_irq_init ( irqamp * regs)
Parameters
[in,out]regsis the IRQ(A)MP register block address.
Variable Documentation
◆ LEON3_Cpu_Index
extern
This object should be read-only after initialization.
◆ LEON3_IrqCtrl_EIrq
extern
◆ leon3_timecounter_instance
extern
It is also used by the CPU counter implementation.
◆ leon3_timer_core_index
extern
This controls which timer core will be accociated with LEON3_Timer_Regs registers base address. This value will by destroyed during initialization.
  • 0 = Default configuration. GPTIMER[0]
  • 1 = GPTIMER[1]
  • 2 = GPTIMER[2]
◆ leon3_timer_prescaler
extern
This affects all timer instances on the system clock timer core determined by leon3_timer_core_index.
  • 0 = Default configuration. Use bootloader configured value.
  • N = Prescaler is set to N. N must not be less that number of timers.
  • 8 = Prescaler is set to 8 (the fastest prescaler possible on all HW)
