RTEMS 6.3
This source file contains the implementation of _Scheduler_simple_SMP_Add_processor(), _Scheduler_simple_SMP_Ask_for_help(), _Scheduler_simple_SMP_Block(), _Scheduler_simple_SMP_Initialize(), _Scheduler_simple_SMP_Node_initialize(), _Scheduler_simple_SMP_Reconsider_help_request(), _Scheduler_simple_SMP_Remove_processor(), _Scheduler_simple_SMP_Unblock(), _Scheduler_simple_SMP_Update_priority(), _Scheduler_simple_SMP_Withdraw_node(), _Scheduler_simple_SMP_Make_sticky(), _Scheduler_simple_SMP_Clean_sticky(), and _Scheduler_simple_SMP_Yield(). More...
| void | _Scheduler_simple_SMP_Initialize (const Scheduler_Control *scheduler) |
| Initializes the scheduler's context. | |
| void | _Scheduler_simple_SMP_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority) |
| Initializes the node with the given attributes. | |
| void | _Scheduler_simple_SMP_Block (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| Blocks a thread. | |
| void | _Scheduler_simple_SMP_Unblock (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| Unblocks a thread. | |
| void | _Scheduler_simple_SMP_Update_priority (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| Updates the priority of the node. | |
| bool | _Scheduler_simple_SMP_Ask_for_help (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Asks for help. | |
| void | _Scheduler_simple_SMP_Reconsider_help_request (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Reconsiders help. | |
| void | _Scheduler_simple_SMP_Withdraw_node (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state) |
| Withdraws node. | |
| void | _Scheduler_simple_SMP_Make_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Makes the node sticky. | |
| void | _Scheduler_simple_SMP_Clean_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Cleans the sticky property from the node. | |
| void | _Scheduler_simple_SMP_Add_processor (const Scheduler_Control *scheduler, Thread_Control *idle) |
| Adds idle to scheduler. | |
| Thread_Control * | _Scheduler_simple_SMP_Remove_processor (const Scheduler_Control *scheduler, Per_CPU_Control *cpu) |
| Removes an idle thread from the given cpu. | |
| void | _Scheduler_simple_SMP_Yield (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
