RTEMS 6.3
src Directory Reference
barrier.c
 This source file contains a definition of the _Barrier_Information with zero objects.
barriercreate.c
 This source file contains the implementation of rtems_barrier_create() and the Barrier Manager system initialization.
barrierdelete.c
 This source file contains the implementation of rtems_barrier_delete().
barriergetnumwaiting.c
 This source file contains the implementation of rtems_barrier_get_number_waiting().
barrierident.c
 This source file contains the implementation of rtems_barrier_ident().
barrierrelease.c
 This source file contains the implementation of rtems_barrier_release().
barrierwait.c
 This source file contains the implementation of rtems_barrier_wait().
clockgetsecondssinceepoch.c
 This source file contains the implementation of rtems_clock_get_seconds_since_epoch().
clockgettickspersecond.c
 This source file contains the implementation of rtems_clock_get_ticks_per_second().
clockgettickssinceboot.c
 This source file contains the implementation of rtems_clock_get_ticks_since_boot().
clockgettod.c
 This source file contains the implementation of rtems_clock_get_tod().
clockgettodtimeval.c
 This source file contains the implementation of rtems_clock_get_tod_timeval().
clockgetuptime.c
 This source file contains the implementation of rtems_clock_get_uptime().
clockgetuptimenanoseconds.c
 This source file contains the implementation of rtems_clock_get_uptime_nanoseconds().
clockgetuptimeseconds.c
 This source file contains the implementation of rtems_clock_get_uptime_seconds().
clockgetuptimetimeval.c
 This source file contains the implementation of rtems_clock_get_uptime_timeval().
clockset.c
 This source file contains the implementation of rtems_clock_set().
clocktick.c
 This source file contains the implementation of rtems_clock_tick().
clocktodtoseconds.c
 This source file contains the implementation of _TOD_To_seconds().
clocktodvalidate.c
 This source file contains the implementation of _TOD_Validate().
dpmem.c
 This source file contains a definition of _Dual_ported_memory_Information with zero objects.
dpmemcreate.c
 This source file contains the implementation of rtems_port_create() and the Dual-Ported Memory Manager system initialization.
dpmemdelete.c
 This source file contains the implementation of rtems_port_delete().
dpmemexternal2internal.c
 This source file contains the implementation of rtems_port_external_to_internal().
dpmemident.c
 This source file contains the implementation of rtems_port_ident().
dpmeminternal2external.c
 This source file contains the implementation of rtems_port_internal_to_external().
eventmp.c
 This source file contains the implementation to support the Event Manager in multiprocessing (MP) configurations.
eventreceive.c
 This source file contains the implementation of rtems_event_receive().
eventseize.c
 This source file contains the implementation of _Event_Seize() and the Event Manager multiprocessing (MP) support system initialization.
eventsend.c
 This source file contains the implementation of rtems_event_send().
eventsurrender.c
 This source file contains the implementation of _Event_Surrender().
getapiconfig.c
 This source file contains the implementation of rtems_api_configuration_table().
intrbody.c
 This source file contains the implementation of directive bindings of the Interrupt Manager for languages other than C/C++.
intrcatch.c
 This source file contains the implementation of rtems_interrupt_catch().
modes.c
 This source file contains the implementation of rtems_interrupt_level_body() and the definition of rtems_interrupt_mask to support languages other than C/C++.
mp.c
 This source file contains the implementation to support the Classic API in multiprocessing (MP) configurations.
msg.c
 This source file contains a definition of the _Message_queue_Information with zero objects.
msgmp.c
 This source file contains the implementation to support the Message Manager in multiprocessing (MP) configurations.
msgqbroadcast.c
 This source file contains the implementation of rtems_message_queue_broadcast().
msgqconstruct.c
 This source file contains the implementation of rtems_message_queue_construct().
msgqcreate.c
 This source file contains the implementation of rtems_message_queue_create().
msgqdelete.c
 This source file contains the implementation of rtems_message_queue_delete().
msgqflush.c
 This source file contains the implementation of rtems_message_queue_flush().
msgqgetnumberpending.c
 This source file contains the implementation of rtems_message_queue_get_number_pending().
msgqident.c
 This source file contains the implementation of rtems_message_queue_ident().
msgqreceive.c
 This source file contains the implementation of rtems_message_queue_receive().
msgqsend.c
 This source file contains the implementation of rtems_message_queue_send().
msgqurgent.c
 This source file contains the implementation of rtems_message_queue_urgent().
part.c
 This source file contains a definition of the _Partition_Information with zero objects.
partcreate.c
 This source file contains the implementation of rtems_partition_create() and the Partition Manager system initialization.
partdelete.c
 This source file contains the implementation of rtems_partition_delete().
partgetbuffer.c
 This source file contains the implementation of rtems_partition_get_buffer().
partident.c
 This source file contains the implementation of rtems_partition_ident().
partmp.c
 This source file contains the implementation to support the Partition Manager in multiprocessing (MP) configurations.
partreturnbuffer.c
 This source file contains the implementation of rtems_partition_return_buffer().
ratemon.c
 This source file contains a definition of the _Rate_monotonic_Information with zero objects.
ratemoncancel.c
 This source file contains the implementation of rtems_rate_monotonic_cancel().
ratemoncreate.c
 This source file contains the implementation of rtems_rate_monotonic_create().
ratemondelete.c
 This source file contains the implementation of rtems_rate_monotonic_delete().
ratemongetstatistics.c
 This source file contains the implementation of rtems_rate_monotonic_get_statistics().
ratemongetstatus.c
 This source file contains the implementation of rtems_rate_monotonic_get_status().
ratemonident.c
 This source file contains the implementation of rtems_rate_monotonic_ident().
ratemonperiod.c
 This source file contains the implementation of rtems_rate_monotonic_period_states().
ratemonreportstatistics.c
 This source file contains the implementation of rtems_rate_monotonic_report_statistics_with_plugin().
ratemonresetall.c
 This source file contains the implementation of rtems_rate_monotonic_reset_all_statistics().
ratemonresetstatistics.c
 This source file contains the implementation of rtems_rate_monotonic_reset_statistics().
ratemontimeout.c
 This source file contains the implementation of _Rate_monotonic_Timeout().
region.c
 This source file contains a definition of the _Region_Information with zero objects.
regioncreate.c
 This source file contains the implementation of rtems_region_create() and the Region Manager system initialization.
regiondelete.c
 This source file contains the implementation of rtems_region_delete().
regionextend.c
 This source file contains the implementation of rtems_region_extend().
regiongetfreeinfo.c
 This source file contains the implementation of rtems_region_get_free_information().
regiongetinfo.c
 This source file contains the implementation of rtems_region_get_information().
regiongetsegment.c
 This source file contains the implementation of rtems_region_get_segment().
regiongetsegmentsize.c
 This source file contains the implementation of rtems_region_get_segment_size().
regionident.c
 This source file contains the implementation of rtems_region_ident().
regionprocessqueue.c
 This source file contains the implementation of _Region_Process_queue().
regionresizesegment.c
 This source file contains the implementation of rtems_region_resize_segment().
regionreturnsegment.c
 This source file contains the implementation of rtems_region_return_segment().
rtemsbuildid.c
 This source file contains the implementation of rtems_build_id() as a binding for languages other than C/C++.
rtemsbuildname.c
 This source file contains the implementation of rtems_build_name() as a binding for languages other than C/C++.
rtemsmaxprio.c
 This source file contains the implementation of _RTEMS_Maximum_priority().
rtemsnametoid.c
 This source file contains the implementation of _RTEMS_Name_to_id().
rtemsobjectapimaximumclass.c
 This source file contains the implementation of rtems_object_api_maximum_class().
rtemsobjectapiminimumclass.c
 This source file contains the implementation of rtems_object_api_minimum_class().
rtemsobjectgetapiclassname.c
 This source file contains the implementation of rtems_object_get_api_class_name().
rtemsobjectgetapiname.c
 This source file contains the implementation of rtems_object_get_api_name().
rtemsobjectgetclassicname.c
 This source file contains the implementation of rtems_object_get_classic_name().
rtemsobjectgetclassinfo.c
 This source file contains the implementation of rtems_object_get_class_information().
rtemsobjectgetname.c
 This source file contains the implementation of rtems_object_get_name().
rtemsobjectidapimaximum.c
 This source file contains the implementation of rtems_object_id_api_maximum() as a binding for languages other than C/C++.
rtemsobjectidapiminimum.c
 This source file contains the implementation of rtems_object_id_api_minimum() as a binding for languages other than C/C++.
rtemsobjectidgetapi.c
 This source file contains the implementation of rtems_object_id_get_api() as a binding for languages other than C/C++.
rtemsobjectidgetclass.c
 This source file contains the implementation of rtems_object_id_get_class() as a binding for languages other than C/C++.
rtemsobjectidgetindex.c
 This source file contains the implementation of rtems_object_id_get_index() as a binding for languages other than C/C++.
rtemsobjectidgetnode.c
 This source file contains the implementation of rtems_object_id_get_node() as a binding for languages other than C/C++.
rtemsobjectsetname.c
 This source file contains the implementation of rtems_object_set_name().
rtemstimer.c
 This source file contains a definition of the _Timer_Information with zero objects.
scheduleraddprocessor.c
 This source file contains the implementation of rtems_scheduler_add_processor().
schedulergetmaxprio.c
 This source file contains the implementation of rtems_scheduler_get_maximum_priority().
schedulergetprocessor.c
 This source file contains the implementation of rtems_scheduler_get_processor() which may be used by binding for languages other than C/C++.
schedulergetprocessormax.c
 This source file contains the implementation of rtems_scheduler_get_processor_maximum() which may be used by binding for languages other than C/C++.
schedulergetprocessorset.c
 This source file contains the implementation of rtems_scheduler_get_processor_set().
schedulerident.c
 This source file contains the implementation of rtems_scheduler_ident().
scheduleridentbyprocessor.c
 This source file contains the implementation of rtems_scheduler_ident_by_processor().
scheduleridentbyprocessorset.c
 This source file contains the implementation of rtems_scheduler_ident_by_processor_set().
schedulermapfromposix.c
 This source file contains the implementation of rtems_scheduler_map_priority_from_posix().
schedulermaptoposix.c
 This source file contains the implementation of rtems_scheduler_map_priority_to_posix().
schedulerremoveprocessor.c
 This source file contains the implementation of rtems_scheduler_remove_processor().
sem.c
 This source file contains a definition of the _Semaphore_Information with zero objects.
semcreate.c
 This source file contains the implementation of rtems_semaphore_create() and the Semaphore Manager system initialization.
semdelete.c
 This source file contains the implementation of rtems_semaphore_delete().
semflush.c
 This source file contains the implementation of rtems_semaphore_flush().
semident.c
 This source file contains the implementation of rtems_semaphore_ident().
semmp.c
 This source file contains the implementation to support the Semaphore Manager in multiprocessing (MP) configurations.
semobtain.c
 This source file contains the implementation of rtems_semaphore_obtain().
semrelease.c
 This source file contains the implementation of rtems_semaphore_release().
semsetpriority.c
 This source file contains the implementation of rtems_semaphore_set_priority().
signalcatch.c
 This source file contains the implementation of rtems_signal_catch() and the Signal Manager multiprocessing (MP) support system initialization.
signalmp.c
 This source file contains the implementation to support the Signal Manager in multiprocessing (MP) configurations.
signalsend.c
 This source file contains the implementation of rtems_signal_send().
statustext.c
 This source file contains the implementation of rtems_status_text().
statustoerrno.c
 This source file contains the implementation of rtems_status_code_to_errno().
systemeventreceive.c
 This source file contains the implementation of rtems_event_system_receive().
systemeventsend.c
 This source file contains the implementation of rtems_event_system_send().
taskconstruct.c
 This source file contains the implementation of rtems_task_construct() and the Task Manager system initialization.
taskconstructuser.c
 This source file contains the implementation of _RTEMS_tasks_Construct_user_task().
taskcreate.c
 This source file contains the implementation of rtems_task_create().
taskdelete.c
 This source file contains the implementation of rtems_task_delete().
taskexit.c
 This source file contains the implementation of rtems_task_exit().
taskgetaffinity.c
 This source file contains the implementation of rtems_task_get_affinity().
taskgetpriority.c
 This source file contains the implementation of rtems_task_get_priority().
taskgetscheduler.c
 This source file contains the implementation of rtems_task_get_scheduler().
taskident.c
 This source file contains the implementation of rtems_task_ident().
taskinitdefault.c
 This source file contains a definition of _RTEMS_tasks_User_task_table without a task entry.
taskinitusers.c
 This source file contains the implementation of _RTEMS_tasks_Initialize_user_task().
taskissuspended.c
 This source file contains the implementation of rtems_task_is_suspended().
taskiterate.c
 This source file contains the implementation of rtems_task_iterate().
taskmode.c
 This source file contains the implementation of rtems_task_mode().
taskmp.c
 This source file contains the implementation to support the Task Manager in multiprocessing (MP) configurations.
taskrestart.c
 This source file contains the implementation of rtems_task_restart().
taskresume.c
 This source file contains the implementation of rtems_task_resume().
tasks.c
 This source file contains a definition of the _RTEMS_tasks_Information with zero objects.
tasksetaffinity.c
 This source file contains the implementation of rtems_task_set_affinity().
tasksetpriority.c
 This source file contains the implementation of rtems_task_set_priority().
tasksetscheduler.c
 This source file contains the implementation of rtems_task_set_scheduler().
taskstart.c
 This source file contains the implementation of rtems_task_start().
tasksuspend.c
 This source file contains the implementation of rtems_task_suspend().
taskwakeafter.c
 This source file contains the implementation of rtems_task_wake_after().
taskwakewhen.c
 This source file contains the implementation of rtems_task_wake_when().
timercancel.c
 This source file contains the implementation of rtems_timer_cancel().
timercreate.c
 This source file contains the definition of _Timer_server and the implementation of _Timer_Routine_adaptor(), _Timer_Fire(), _Timer_Fire_after(), _Timer_Fire_when(), _Timer_Cancel(), and the Timer Manager system initialization.
timerdelete.c
 This source file contains the implementation of rtems_timer_delete().
timerfireafter.c
 This source file contains the implementation of rtems_timer_fire_after().
timerfirewhen.c
 This source file contains the implementation of rtems_timer_fire_when().
timergetinfo.c
 This source file contains the implementation of rtems_timer_get_information().
timerident.c
 This source file contains the implementation of rtems_timer_ident().
timerreset.c
 This source file contains the implementation of rtems_timer_reset().
timerserver.c
 This source file contains the implementation of rtems_timer_initiate_server().
timerserverfireafter.c
 This source file contains the implementation of rtems_timer_server_fire_after().
timerserverfirewhen.c
 This source file contains the implementation of rtems_timer_server_fire_when().
workspace.c
 This source file contains the implementation of rtems_workspace_get_information(), rtems_workspace_allocate(), and rtems_workspace_free().
workspacegreedy.c
 This source file contains the implementation of rtems_workspace_greedy_allocate(), rtems_workspace_greedy_allocate_all_except_largest(), and rtems_workspace_greedy_free().
