RTEMS 6.3
This header file evaluates configuration options related to the FACE Technical Standard. More...
The FACE Technical Standard (https://opengroup.org/face) is an open standard designed for safety critical embedded systems. It includes POSIX profiles and requirements that promote safety and portability. As a general rules, the profiles place a minimum on the services which an operating system must provide. Those same profile definitions represent the maximum services which an application may use.
