RTEMS
6.3
Toggle main menu visibility
include
confdefs
face.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
19
20
21
* Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
22
23
24
* modification, are permitted provided that the following conditions
25
* are met:
26
* 1. Redistributions of source code must retain the above copyright
27
* notice, this list of conditions and the following disclaimer.
28
* 2. Redistributions in binary form must reproduce the above copyright
29
* notice, this list of conditions and the following disclaimer in the
30
* documentation and/or other materials provided with the distribution.
31
32
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
33
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
34
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
35
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
36
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
37
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
38
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
39
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
40
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
41
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
42
* POSSIBILITY OF SUCH DAMAGE.
43
44
45
#ifndef _RTEMS_CONFDEFS_FACE_H
46
#define _RTEMS_CONFDEFS_FACE_H
47
48
#ifndef __CONFIGURATION_TEMPLATE_h
49
#error "Do not include this file directly, use <rtems/confdefs.h> instead"
50
#endif
51
52
#ifdef CONFIGURE_INIT
53
54
#ifdef CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR
55
56
rtems/posix/timer.h
57
58
int
_POSIX_Timer_Is_allowed
59
clockid_t clock_id
60
61
62
63
* Per the FACE Technical Standard, POSIX timers should not be
64
* allowed on CLOCK_REALTIME for safety reasons. If the application
65
* wants the FACE behavior, then this method is instantiated.
66
67
if
( clock_id == CLOCK_REALTIME ) {
68
return
EPERM;
69
70
71
if
( clock_id != CLOCK_MONOTONIC ) {
72
return
EINVAL;
73
74
75
return
0;
76
77
78
#endif
/* CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR */
79
80
#endif
/* CONFIGURE_INIT */
81
82
#endif
/* _RTEMS_CONFDEFS_FACE_H */
timer.h
POSIX Timers Internal Support.
int _POSIX_Timer_Is_allowed(clockid_t clock_id)
Follow POSIX or FACE Technical Standard on timer_create.
Definition
psxtimercreate.c:54
