RTEMS
6.3
Toggle main menu visibility
include
confdefs
initthread.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
14
15
16
* Copyright (C) 2020 embedded brains GmbH & Co. KG
17
18
19
* modification, are permitted provided that the following conditions
20
* are met:
21
* 1. Redistributions of source code must retain the above copyright
22
* notice, this list of conditions and the following disclaimer.
23
* 2. Redistributions in binary form must reproduce the above copyright
24
* notice, this list of conditions and the following disclaimer in the
25
* documentation and/or other materials provided with the distribution.
26
27
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
28
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
29
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
30
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
31
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37
* POSSIBILITY OF SUCH DAMAGE.
38
39
40
#ifndef _RTEMS_CONFDEFS_INITTHREAD_H
41
#define _RTEMS_CONFDEFS_INITTHREAD_H
42
43
#ifndef __CONFIGURATION_TEMPLATE_h
44
#error "Do not include this file directly, use <rtems/confdefs.h> instead"
45
#endif
46
47
#ifdef CONFIGURE_INIT
48
49
#ifdef CONFIGURE_POSIX_INIT_THREAD_TABLE
50
51
rtems/confdefs/percpu.h
52
rtems/posix/pthread.h
53
rtems/sysinit.h
54
55
#ifndef CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
56
#define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT POSIX_Init
57
#endif
58
59
#ifndef CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
60
#define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE \
61
CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
62
#endif
63
64
#if CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE \
65
66
#define _CONFIGURE_POSIX_INIT_THREAD_STACK_EXTRA \
67
( CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE - \
68
CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE )
69
#endif
70
71
#ifdef __cplusplus
72
extern
"C"
73
#endif
74
75
const
posix_initialization_threads_table
_POSIX_Threads_User_thread_table
76
77
78
79
80
RTEMS_SYSINIT_ITEM
81
_POSIX_Threads_Initialize_user_thread
82
RTEMS_SYSINIT_POSIX_USER_THREADS,
83
RTEMS_SYSINIT_ORDER_MIDDLE
84
85
86
#ifdef __cplusplus
87
88
#endif
89
90
#endif
/* CONFIGURE_POSIX_INIT_THREAD_TABLE */
91
92
#ifndef _CONFIGURE_POSIX_INIT_THREAD_STACK_EXTRA
93
#define _CONFIGURE_POSIX_INIT_THREAD_STACK_EXTRA 0
94
#endif
95
96
#endif
/* CONFIGURE_INIT */
97
98
#endif
/* _RTEMS_CONFDEFS_INITTHREAD_H */
percpu.h
This header file evaluates configuration options related to the per-CPU configuration.
const posix_initialization_threads_table _POSIX_Threads_User_thread_table
Initialization table for the first user POSIX thread.
void _POSIX_Threads_Initialize_user_thread(void)
System initialization handler to create the first user POSIX thread.
Definition
pthreadinitthreads.c:49
RTEMS_SYSINIT_ITEM
#define RTEMS_SYSINIT_ITEM(handler, module, order)
Creates the system initialization item associated with the handler, module, and order.
Definition
sysinit.h:204
This configuration option is an integer define.
Definition
appl-config.h:4388
This configuration option is an initializer define.
Definition
appl-config.h:4360
pthread.h
POSIX Threads Private Support.
Definition
pthread.h:62
sysinit.h
This header file provides the API of the System Initialization Support.
