RTEMS 6.3
objectsclassic.h
2
13
14/*
15 * Copyright (C) 2020 embedded brains GmbH & Co. KG
16 *
17 * Redistribution and use in source and binary forms, with or without
18 * modification, are permitted provided that the following conditions
19 * are met:
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 * 2. Redistributions in binary form must reproduce the above copyright
23 * notice, this list of conditions and the following disclaimer in the
24 * documentation and/or other materials provided with the distribution.
25 *
26 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36 * POSSIBILITY OF SUCH DAMAGE.
37 */
38
39#ifndef _RTEMS_CONFDEFS_OBJECTSCLASSIC_H
40#define _RTEMS_CONFDEFS_OBJECTSCLASSIC_H
41
42#ifndef __CONFIGURATION_TEMPLATE_h
43#error "Do not include this file directly, use <rtems/confdefs.h> instead"
44#endif
45
46#ifdef CONFIGURE_INIT
47
49
50#if CONFIGURE_MAXIMUM_BARRIERS > 0
52#endif
53
54#if CONFIGURE_MAXIMUM_PORTS > 0
56#endif
57
58#if CONFIGURE_MAXIMUM_MESSAGE_QUEUES > 0
60#endif
61
62#if CONFIGURE_MAXIMUM_PARTITIONS > 0
63 #include <rtems/rtems/partdata.h>
64#endif
65
66#if CONFIGURE_MAXIMUM_PERIODS > 0
68#endif
69
70#if CONFIGURE_MAXIMUM_REGIONS > 0
72#endif
73
74#if CONFIGURE_MAXIMUM_SEMAPHORES > 0
76 #include <rtems/rtems/semdata.h>
77#endif
78
79#if CONFIGURE_MAXIMUM_TIMERS > 0
81#endif
82
83#ifdef __cplusplus
84extern "C" {
85#endif
86
87#if CONFIGURE_MAXIMUM_BARRIERS > 0
89#endif
90
91#if CONFIGURE_MAXIMUM_MESSAGE_QUEUES > 0
93#endif
94
95#if CONFIGURE_MAXIMUM_PARTITIONS > 0
97#endif
98
99#if CONFIGURE_MAXIMUM_PERIODS > 0
101#endif
102
103#if CONFIGURE_MAXIMUM_PORTS > 0
105#endif
106
107#if CONFIGURE_MAXIMUM_REGIONS > 0
109#endif
110
111#if CONFIGURE_MAXIMUM_SEMAPHORES > 0
114 _CONFIGURE_SCHEDULER_COUNT
115 );
116#endif
117
118#if CONFIGURE_MAXIMUM_TIMERS > 0
120#endif
121
122#ifdef __cplusplus
123}
124#endif
125
126#endif /* CONFIGURE_INIT */
127
128#endif /* _RTEMS_CONFDEFS_OBJECTSCLASSIC_H */
This header file provides data structures used by the implementation and the Application Configuratio...
This header file evaluates configuration options related to the scheduler configuration.
#define CONFIGURE_MAXIMUM_SEMAPHORES
This configuration option is an integer define.
Definition appl-config.h:701
#define CONFIGURE_MAXIMUM_BARRIERS
Definition appl-config.h:451
#define CONFIGURE_MAXIMUM_PORTS
Definition appl-config.h:612
#define CONFIGURE_MAXIMUM_PARTITIONS
Definition appl-config.h:532
#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES
Definition appl-config.h:492
#define CONFIGURE_MAXIMUM_TIMERS
Definition appl-config.h:802
#define CONFIGURE_MAXIMUM_PERIODS
Definition appl-config.h:572
#define CONFIGURE_MAXIMUM_REGIONS
Definition appl-config.h:652
#define BARRIER_INFORMATION_DEFINE(max)
Macro to define the objects information for the Classic Barrier objects.
Definition barrierdata.h:81
#define DUAL_PORTED_MEMORY_INFORMATION_DEFINE(max)
Macro to define the objects information for the Classic Dual Ported Memory objects.
Definition dpmemdata.h:84
#define MESSAGE_QUEUE_INFORMATION_DEFINE(max)
Macro to define the objects information for the Classic Message Queue objects.
Definition messagedata.h:97
#define PARTITION_INFORMATION_DEFINE(_max)
Defines the Partition Manager objects information.
Definition partdata.h:144
#define RATE_MONOTONIC_INFORMATION_DEFINE(max)
Macro to define the objects information for the Classic Rate Monotonic objects.
Definition ratemondata.h:169
#define REGION_INFORMATION_DEFINE(max)
Macro to define the objects information for the Classic Region objects.
Definition regiondata.h:83
#define SEMAPHORE_INFORMATION_DEFINE(max, scheduler_count)
Macro to define the objects information for the Classic Semaphore objects.
Definition semdata.h:156
#define TIMER_INFORMATION_DEFINE(max)
Macro to define the objects information for the Classic Timer objects.
Definition timerdata.h:94
This header file evaluates configuration options related to the unlimited objects configuration.
