RTEMS 5.2-rc1
Macros | Typedefs | Functions
config.h File Reference
Table of User Defined Configuration Parameters. More...
#include <rtems/score/isr.h>
#include <rtems/score/memory.h>
#include <rtems/score/smp.h>
#include <rtems/score/stack.h>
#include <rtems/score/userextdata.h>
#include <rtems/score/threadidledata.h>
#include <rtems/score/watchdogticks.h>
#include <rtems/score/wkspacedata.h>
#include <rtems/rtems/config.h>
#include <rtems/extension.h>
#define RTEMS_UNLIMITED_OBJECTS   OBJECTS_UNLIMITED_OBJECTS
#define rtems_resource_unlimited(resource)    ( resource | RTEMS_UNLIMITED_OBJECTS )
#define rtems_resource_is_unlimited(resource)    _Objects_Is_unlimited(resource)
#define rtems_resource_maximum_per_allocation(resource)    _Objects_Maximum_per_allocation(resource)
#define rtems_configuration_get_unified_work_area()    (_Workspace_Is_unified)
#define rtems_configuration_get_stack_allocator_avoids_work_space()    (_Stack_Allocator_avoids_workspace)
 Return if the stack allocator avoids the work space. More...
#define rtems_configuration_get_work_space_size()
#define rtems_configuration_get_microseconds_per_tick()    (_Watchdog_Microseconds_per_tick)
#define rtems_configuration_get_milliseconds_per_tick()    (_Watchdog_Microseconds_per_tick / 1000)
#define rtems_configuration_get_nanoseconds_per_tick()    (_Watchdog_Nanoseconds_per_tick)
#define rtems_configuration_get_ticks_per_timeslice()    (_Watchdog_Ticks_per_timeslice)
#define rtems_configuration_get_idle_task()    (_Thread_Idle_entry)
#define rtems_configuration_get_idle_task_stack_size()    (_Thread_Idle_stack_size)
#define rtems_configuration_get_interrupt_stack_size()    ((size_t) _ISR_Stack_size)
#define rtems_configuration_get_stack_allocate_init_hook()    (_Stack_Allocator_initialize)
#define rtems_configuration_get_stack_allocate_hook()    (_Stack_Allocator_allocate)
#define rtems_configuration_get_stack_free_hook()    (_Stack_Allocator_free)
#define rtems_configuration_get_stack_allocate_for_idle_hook()    (_Stack_Allocator_allocate_for_idle)
#define rtems_configuration_get_do_zero_of_workspace()    _Memory_Zero_before_use
#define rtems_configuration_get_number_of_initial_extensions()    ((uint32_t) _User_extensions_Initial_count)
#define rtems_configuration_get_user_extension_table()    (&_User_extensions_Initial_extensions[ 0 ])
#define rtems_configuration_get_user_multiprocessing_table()    NULL
#define rtems_configuration_get_maximum_processors()    (_SMP_Processor_configured_maximum)
 Returns the configured maximum count of processors. More...
typedef Stack_Allocator_initialize rtems_stack_allocate_init_hook
 The stack allocator initialization handler. More...
typedef Stack_Allocator_allocate rtems_stack_allocate_hook
 Stack allocator allocate handler. More...
typedef Stack_Allocator_free rtems_stack_free_hook
 Stack allocator free handler. More...
uintptr_t rtems_configuration_get_stack_space_size (void)
uint32_t rtems_configuration_get_maximum_extensions (void)
This include file contains the table of user defined configuration parameters.
◆ rtems_configuration_get_do_zero_of_workspace
#define rtems_configuration_get_do_zero_of_workspace ( )     _Memory_Zero_before_use
This macro assists in accessing the field which indicates whether RTEMS is responsible for zeroing the Executive Workspace.
◆ rtems_configuration_get_maximum_processors
#define rtems_configuration_get_maximum_processors ( )     (_SMP_Processor_configured_maximum)
The actual number of processors available for the application will be less than or equal to the configured maximum count of processors.
On single-processor configurations this is a compile time constant which evaluates to one.
Returns
The configured maximum count of processors.
◆ rtems_configuration_get_stack_allocator_avoids_work_space
#define rtems_configuration_get_stack_allocator_avoids_work_space ( )     (_Stack_Allocator_avoids_workspace)
Return values
trueThe stack allocator must not allocate the thread stacks from the RTEMS Workspace
falseThe stack allocator should allocate the thread stacks from the RTEMS Workspace.
◆ rtems_configuration_get_work_space_size
#define rtems_configuration_get_work_space_size ( )
Value:
0 : rtems_configuration_get_stack_space_size()))
const uintptr_t _Workspace_Size
The workspace size in bytes.
Definition: config.h:92
Typedef Documentation
◆ rtems_stack_allocate_hook
Parameters
stack_sizeThe size of the stack area to allocate in bytes.
Return values
NULLNot enough memory.
otherPointer to begin of stack area.
◆ rtems_stack_allocate_init_hook
Parameters
stack_space_sizeThe size of the stack space in bytes.
◆ rtems_stack_free_hook
Parameters
]addr A pointer to previously allocated stack area or NULL.
