RTEMS 5.2-rc1
userextdata.h
1
9/*
10 * COPYRIGHT (c) 1989-2009.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * The license and distribution terms for this file may be
14 * found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 */
17
18#ifndef _RTEMS_SCORE_USEREXTDATA_H
19#define _RTEMS_SCORE_USEREXTDATA_H
20
21#include <rtems/score/userext.h>
22#include <rtems/score/chain.h>
23
24#ifdef __cplusplus
25extern "C" {
26#endif
27
39typedef struct {
40 Chain_Node Node;
43
50typedef struct {
51 Chain_Node Node;
53 User_extensions_Table Callouts;
55
61extern const size_t _User_extensions_Initial_count;
62
69
77
80#ifdef __cplusplus
81}
82#endif
83
84#endif
85/* end of include file */
User_extensions_Switch_control _User_extensions_Initial_switch_controls[]
A spare switch control for each initial user extension.
void(* User_extensions_thread_switch_extension)(struct _Thread_Control *executing, struct _Thread_Control *heir)
Task switch extension.
Definition: userext.h:156
The count of initial user extensions.
const User_extensions_Table _User_extensions_Initial_extensions[]
The table of initial user extensions.
Chain Handler API.
Definition: chain.h:68
Manages each user extension set.
Definition: userextdata.h:50
Manages the switch callouts.
Definition: userextdata.h:39
User extension table.
Definition: userext.h:232
User Extension Handler API.
