RTEMS 5.2-rc1
SMP Support. More...
Files | |
| file | smp.h |
| SuperCore SMP Support API. | |
| #define | _SMP_Processor_configured_maximum 1 |
| The configured processor maximum. More... | |
| #define | _SMP_Get_processor_maximum() UINT32_C(1) |
| #define | _SMP_Get_current_processor() UINT32_C(0) |
| #define | SMP_MESSAGE_SHUTDOWN 0x1UL |
| SMP message to request a processor shutdown. More... | |
| #define | SMP_MESSAGE_PERFORM_JOBS 0x2UL |
| SMP message to perform per-processor jobs. More... | |
| #define | _SMP_Handler_initialize() do { } while ( 0 ) |
| Initializes SMP Handler. More... | |
| #define | _SMP_Request_start_multitasking() do { } while ( 0 ) |
| Requests a multitasking start on all configured and available processors. | |
| #define | _SMP_Request_shutdown() do { } while ( 0 ) |
| Requests a shutdown of all processors. More... | |
Enumerations | |
| enum | SMP_Fatal_code { SMP_FATAL_BOOT_PROCESSOR_NOT_ASSIGNED_TO_SCHEDULER , SMP_FATAL_MANDATORY_PROCESSOR_NOT_PRESENT , SMP_FATAL_MULTITASKING_START_ON_INVALID_PROCESSOR , SMP_FATAL_MULTITASKING_START_ON_UNASSIGNED_PROCESSOR , SMP_FATAL_SHUTDOWN , SMP_FATAL_SHUTDOWN_RESPONSE , SMP_FATAL_START_OF_MANDATORY_PROCESSOR_FAILED , SMP_FATAL_SCHEDULER_PIN_OR_UNPIN_NOT_SUPPORTED , SMP_FATAL_WRONG_CPU_STATE_TO_PERFORM_JOBS } |
| SMP fatal codes. | |
| RTEMS_INLINE_ROUTINE const Processor_mask * | _SMP_Get_online_processors (void) |
| Gets all online processors. More... | |
| RTEMS_INLINE_ROUTINE const bool | _SMP_Need_inter_processor_interrupts (void) |
| Indicate if inter-processor interrupts are needed. More... | |
SMP Support.
This defines the interface of the SuperCore SMP support.
| #define _SMP_Handler_initialize | ( | void | ) | do { } while ( 0 ) |
This method initialize the SMP Handler.
| #define _SMP_Processor_configured_maximum 1 |
In SMP configurations, this constant is defined by the application configuration via <rtems/confdefs.h>, otherwise it is a compile-time constant with the value one.
| #define _SMP_Request_shutdown | ( | void | ) | do { } while ( 0 ) |
This function is a part of the system termination procedure.
| #define SMP_MESSAGE_PERFORM_JOBS 0x2UL |
| #define SMP_MESSAGE_SHUTDOWN 0x1UL |
| RTEMS_INLINE_ROUTINE const Processor_mask * _SMP_Get_online_processors | ( | void | ) |
| RTEMS_INLINE_ROUTINE const bool _SMP_Need_inter_processor_interrupts | ( | void | ) |
