RTEMS 5.2-rc1
isr.h
1
14/*
15 * COPYRIGHT (c) 1989-2012.
16 * On-Line Applications Research Corporation (OAR).
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef _RTEMS_SCORE_ISR_H
24#define _RTEMS_SCORE_ISR_H
25
27
44#ifdef __cplusplus
45extern "C" {
46#endif
47
51typedef uint32_t ISR_Vector_number;
52
56typedef void ISR_Handler;
57
58#if (CPU_SIMPLE_VECTORED_INTERRUPTS == FALSE)
59
60typedef void * ISR_Handler_entry;
61
62#else
66#if (CPU_ISR_PASSES_FRAME_POINTER == TRUE)
67typedef ISR_Handler ( *ISR_Handler_entry )(
70 );
71#else
72typedef ISR_Handler ( *ISR_Handler_entry )(
74 );
75#endif
76
81extern ISR_Handler_entry _ISR_Vector_table[ CPU_INTERRUPT_NUMBER_OF_VECTORS ];
82#endif
83
90RTEMS_DECLARE_GLOBAL_SYMBOL( _ISR_Stack_size );
91
99extern char _ISR_Stack_area_begin[];
100
108extern const char _ISR_Stack_area_end[];
109
115void _ISR_Handler_initialization ( void );
116
134#define _ISR_Install_vector( _vector, _new_handler, _old_handler ) \
135 _CPU_ISR_install_vector( _vector, _new_handler, _old_handler )
136
151void _ISR_Handler( void );
152
163bool _ISR_Is_in_progress( void );
164
165#ifdef __cplusplus
166}
167#endif
168
171#endif
172/* end of include file */
bool _ISR_Is_in_progress(void)
Checks if an ISR in progress.
Definition: nios2-isr-is-in-progress.c:23
void ISR_Handler
Definition: isr.h:56
void _ISR_Handler(void)
ISR interrupt dispatcher.
Definition: cpu_asm.c:126
The interrupt stack area end.
void _ISR_Handler_initialization(void)
Initializes the ISR handler.
Definition: isr.c:36
The interrupt stack area begin.
RTEMS_DECLARE_GLOBAL_SYMBOL(_ISR_Stack_size)
Global symbol with a value equal to the configure interrupt stack size.
Definition: isr.h:51
ISR Level Type.
#define CPU_INTERRUPT_NUMBER_OF_VECTORS
Definition: cpu.h:686
Interrupt stack frame (ISF).
Definition: cpu.h:191
