RTEMS
5.1
Inlined Routines in the Watchdog Handler. More...
#include <rtems/score/watchdogticks.h>
#include <rtems/score/isrlock.h>
#include <rtems/score/rbtreeimpl.h>
#include <sys/types.h>
#include <sys/timespec.h>
#define | WATCHDOG_INITIALIZER(routine) |
Watchdog initializer for static initialization. More... | |
#define | _Watchdog_Tickle(header, first, now, lock, lock_context) _Watchdog_Do_tickle( header, first, now, lock_context ) |
#define | WATCHDOG_MAXIMUM_TICKS UINT64_MAX |
The maximum watchdog ticks value for the far future. | |
#define | WATCHDOG_NANOSECONDS_PER_SECOND 1000000000 |
#define | WATCHDOG_BITS_FOR_1E9_NANOSECONDS 30 |
The bits necessary to store 1000000000 (= WATCHDOG_NANOSECONDS_PER_SECOND) nanoseconds. More... | |
#define | WATCHDOG_MAX_SECONDS 0x3ffffffff |
The maximum number of seconds representable in the nanoseconds watchdog format. More... | |
Enumerations | |
enum | Watchdog_State { WATCHDOG_SCHEDULED_BLACK, WATCHDOG_SCHEDULED_RED, WATCHDOG_INACTIVE, WATCHDOG_PENDING } |
Watchdog states. More... | |
RTEMS_INLINE_ROUTINE void | _Watchdog_Header_initialize (Watchdog_Header *header) |
Initializes the watchdog header. More... | |
RTEMS_INLINE_ROUTINE Watchdog_Control * | _Watchdog_Header_first (const Watchdog_Header *header) |
Returns the first of the watchdog header. More... | |
RTEMS_INLINE_ROUTINE void | _Watchdog_Header_destroy (Watchdog_Header *header) |
Destroys the watchdog header. More... | |
void | _Watchdog_Tick (struct Per_CPU_Control *cpu) |
Performs a watchdog tick. More... | |
RTEMS_INLINE_ROUTINE Watchdog_State | _Watchdog_Get_state (const Watchdog_Control *the_watchdog) |
Gets the state of the watchdog. More... | |
RTEMS_INLINE_ROUTINE void | _Watchdog_Set_state (Watchdog_Control *the_watchdog, Watchdog_State state) |
Sets the state of the watchdog. More... | |
RTEMS_INLINE_ROUTINE Per_CPU_Control * | _Watchdog_Get_CPU (const Watchdog_Control *the_watchdog) |
Gets the watchdog's cpu. More... | |
RTEMS_INLINE_ROUTINE void | _Watchdog_Set_CPU (Watchdog_Control *the_watchdog, Per_CPU_Control *cpu) |
Sets the cpu for the watchdog. More... | |
RTEMS_INLINE_ROUTINE void | _Watchdog_Preinitialize (Watchdog_Control *the_watchdog, Per_CPU_Control *cpu) |
Pre-initializes a watchdog. More... | |
RTEMS_INLINE_ROUTINE void | _Watchdog_Initialize (Watchdog_Control *the_watchdog, Watchdog_Service_routine_entry routine) |
Initializes a watchdog with a new service routine. More... | |
void | _Watchdog_Do_tickle (Watchdog_Header *header, Watchdog_Control *first, uint64_t now, ISR_lock_Context *lock_context) |
Calls the routine of each not expired watchdog control node. More... | |
void | _Watchdog_Insert (Watchdog_Header *header, Watchdog_Control *the_watchdog, uint64_t expire) |
Inserts a watchdog into the set of scheduled watchdogs according to the specified expiration time. More... | |
void | _Watchdog_Remove (Watchdog_Header *header, Watchdog_Control *the_watchdog) |
In the case the watchdog is scheduled, then it is removed from the set of scheduled watchdogs. More... | |
RTEMS_INLINE_ROUTINE uint64_t | _Watchdog_Cancel (Watchdog_Header *header, Watchdog_Control *the_watchdog, uint64_t now) |
RTEMS_INLINE_ROUTINE bool | _Watchdog_Is_scheduled (const Watchdog_Control *the_watchdog) |
Checks if the watchdog is scheduled. More... | |
RTEMS_INLINE_ROUTINE void | _Watchdog_Next_first (Watchdog_Header *header, Watchdog_Control *the_watchdog) |
Sets the first node of the header. More... | |
RTEMS_INLINE_ROUTINE bool | _Watchdog_Is_valid_timespec (const struct timespec *ts) |
Checks if the timespec is a valid timespec for a watchdog. More... | |
RTEMS_INLINE_ROUTINE bool | _Watchdog_Is_valid_interval_timespec (const struct timespec *ts) |
Checks if the timespec is a valid interval timespec for a watchdog. More... | |
RTEMS_INLINE_ROUTINE const struct timespec * | _Watchdog_Future_timespec (struct timespec *now, const struct timespec *delta) |
Adds the delta timespec to the current time if the delta is a valid interval timespec. More... | |
RTEMS_INLINE_ROUTINE bool | _Watchdog_Is_far_future_timespec (const struct timespec *ts) |
Checks if the timespec is too far in the future. More... | |
RTEMS_INLINE_ROUTINE uint64_t | _Watchdog_Ticks_from_seconds (uint32_t seconds) |
Converts the seconds to ticks. More... | |
RTEMS_INLINE_ROUTINE uint64_t | _Watchdog_Ticks_from_timespec (const struct timespec *ts) |
Converts the timespec in ticks. More... | |
RTEMS_INLINE_ROUTINE uint64_t | _Watchdog_Ticks_from_sbintime (int64_t sbt) |
Converts the sbintime in ticks. More... | |
RTEMS_INLINE_ROUTINE void | _Watchdog_Per_CPU_acquire_critical (Per_CPU_Control *cpu, ISR_lock_Context *lock_context) |
Acquires the per cpu watchdog lock in a critical section. More... | |
RTEMS_INLINE_ROUTINE void | _Watchdog_Per_CPU_release_critical (Per_CPU_Control *cpu, ISR_lock_Context *lock_context) |
Releases the per cpu watchdog lock in a critical section. More... | |
RTEMS_INLINE_ROUTINE uint64_t | _Watchdog_Per_CPU_insert_ticks (Watchdog_Control *the_watchdog, Per_CPU_Control *cpu, Watchdog_Interval ticks) |
Sets the watchdog's cpu to the given instance and sets its expiration time to the watchdog expiration time of the cpu plus the ticks. More... | |
RTEMS_INLINE_ROUTINE uint64_t | _Watchdog_Per_CPU_insert (Watchdog_Control *the_watchdog, Per_CPU_Control *cpu, Watchdog_Header *header, uint64_t expire) |
Sets the watchdog's cpu and inserts it with the given expiration time in the scheduled watchdogs. More... | |
RTEMS_INLINE_ROUTINE void | _Watchdog_Per_CPU_remove (Watchdog_Control *the_watchdog, Per_CPU_Control *cpu, Watchdog_Header *header) |
Removes the watchdog from the cpu and the scheduled watchdogs. More... | |
RTEMS_INLINE_ROUTINE void | _Watchdog_Per_CPU_remove_ticks (Watchdog_Control *the_watchdog) |
This file contains the static inline implementation of all inlined routines in the Watchdog Handler.
