19 #ifndef _RTEMS_SCORE_CPU_H 20 #define _RTEMS_SCORE_CPU_H 42 #define CPU_SIMPLE_VECTORED_INTERRUPTS FALSE 44 #define CPU_HARDWARE_FP FALSE 46 #define CPU_SOFTWARE_FP FALSE 48 #define CPU_ALL_TASKS_ARE_FP FALSE 50 #define CPU_IDLE_TASK_IS_FP FALSE 52 #define CPU_USE_DEFERRED_FP_SWITCH FALSE 54 #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE 67 #define CPU_STACK_GROWS_UP FALSE 70 #define CPU_CACHE_LINE_BYTES 32 72 #define CPU_STRUCTURE_ALIGNMENT 84 #define CPU_MODES_INTERRUPT_MASK 0x00000001 86 #define CPU_MAXIMUM_PROCESSORS 32 164 #define _CPU_Context_Get_SP( _context ) \ 165 (_context)->r3_stack_pointer 177 uint32_t special_interrupt_register;
199 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 205 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE 218 #define CPU_STACK_MINIMUM_SIZE (1024*4) 220 #define CPU_SIZEOF_POINTER 4 230 #define CPU_ALIGNMENT 8 255 #define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT 271 #define CPU_STACK_ALIGNMENT 4 273 #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES 294 #define _CPU_ISR_Disable( _isr_cookie ) \ 298 v850_get_psw( _psw ); \ 299 __asm__ __volatile__( "di" ); \ 300 _isr_cookie = _psw; \ 314 #define _CPU_ISR_Enable( _isr_cookie ) \ 316 unsigned int _psw = (_isr_cookie); \ 318 v850_set_psw( _psw ); \ 333 #define _CPU_ISR_Flash( _isr_cookie ) \ 335 unsigned int _psw = (_isr_cookie); \ 336 v850_set_psw( _psw ); \ 337 __asm__ __volatile__( "di" ); \ 342 return ( level & V850_PSW_INTERRUPT_DISABLE_MASK )
343 != V850_PSW_INTERRUPT_DISABLE;
361 #define _CPU_ISR_Set_level( new_level ) \ 364 __asm__ __volatile__( "di" ); \ 366 __asm__ __volatile__( "ei" ); \ 421 uint32_t *stack_base,
444 #define _CPU_Context_Restart_self( _the_context ) \ 445 _CPU_Context_restore( (_the_context) ); 467 #define _CPU_Context_Initialize_fp( _destination ) \ 485 #define _CPU_Fatal_halt( _source, _error ) \ 487 __asm__ __volatile__ ( "di" ); \ 488 __asm__ __volatile__ ( "mov %0, r10; " : "=r" ((_error)) ); \ 489 __asm__ __volatile__ ( "halt" ); \ 494 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE 631 static inline uint32_t CPU_swap_u32(
635 unsigned int swapped;
637 #if (V850_HAS_BYTE_SWAP_INSTRUCTION == 1) 641 __asm__ __volatile__ (
"bsw %0, %1" :
"=r" (
v),
"=&r" (swapped) );
643 uint32_t byte1, byte2, byte3, byte4;
645 byte4 = (value >> 24) & 0xff;
646 byte3 = (value >> 16) & 0xff;
647 byte2 = (value >> 8) & 0xff;
648 byte1 = value & 0xff;
650 swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
667 unsigned int swapped;
669 #if (V850_HAS_BYTE_SWAP_INSTRUCTION == 1) 673 __asm__ __volatile__ (
"bsh %0, %1" :
"=r" (
v),
"=&r" (swapped) );
675 swapped = ((value & 0xff) << 8) | ((value >> 8) & 0xff);
688 static inline CPU_Counter_ticks _CPU_Counter_difference(
689 CPU_Counter_ticks second,
690 CPU_Counter_ticks first
693 return second - first;
#define _CPU_Context_restore_fp(_fp_context_ptr)
Nothing to do due to the synchronous or lazy floating point switch.
Definition: cpu.h:904
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
uint32_t r3_stack_pointer
Definition: cpu.h:142
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
Thread register context.
Definition: cpu.h:194
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
Interrupt stack frame (ISF).
Definition: cpu.h:191
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
#define _CPU_Context_save_fp(_fp_context_ptr)
Definition: cpu.h:898
void _CPU_Initialize(void)
CPU initialization.
Definition: cpu.c:45
#define CPU_swap_u16(value)
Definition: cpu.h:642
SPARC basic context.
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
uint32_t CPU_Counter_ticks
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
V850 Set up Basic CPU Dependency Settings Based on Compiler Settings.
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
uintptr_t CPU_Uint32ptr
Definition: cpu.h:662
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
unsigned size
Definition: tte.h:74
unsigned v
Definition: tte.h:73
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
