RTEMS  5.1
MP_packet_Prefix Struct Reference
#include <mppkt.h>
MP_packet_Classes the_class
Objects_Id id
Objects_Id source_tid
uint32_t source_priority
uint32_t return_code
uint32_t length
uint32_t to_convert
Watchdog_Interval timeout
The following record contains the prefix for every packet passed between nodes in an MP system.
Note
This structure is padded to ensure that anything following it is on a 16 byte boundary. This is the most stringent structure alignment rule encountered yet.
Field Documentation
◆ id
Objects_Id MP_packet_Prefix::id
This field is the id of the object to be acted upon.
◆ length
uint32_t MP_packet_Prefix::length
This field is the length of the data following the prefix.
◆ return_code
uint32_t MP_packet_Prefix::return_code
This field is where the status of the operation will be returned.
◆ source_priority
uint32_t MP_packet_Prefix::source_priority
This field is the priority of the originating thread.
◆ source_tid
Objects_Id MP_packet_Prefix::source_tid
This field is the ID of the originating thread.
◆ the_class
MP_packet_Classes MP_packet_Prefix::the_class
This field indicates the API class of the operation being performed.
◆ timeout
Watchdog_Interval MP_packet_Prefix::timeout
This field is the requested timeout for this operation.
◆ to_convert
uint32_t MP_packet_Prefix::to_convert
This field is the length of the data which required network conversion.
