RTEMS
5.1
Type definitions and defines for Cortex-M processor based devices. More...
Modules | |
Core Debug Registers (CoreDebug) | |
Type definitions for the Core Debug Registers. | |
Core Definitions | |
Definitions for base addresses, unions, and structures. | |
Core register bit field macros | |
Macros for use with bit field definitions (xxx_Pos, xxx_Msk). | |
Data Watchpoint and Trace (DWT) | |
Type definitions for the Data Watchpoint and Trace (DWT) | |
Instrumentation Trace Macrocell (ITM) | |
Type definitions for the Instrumentation Trace Macrocell (ITM) | |
Nested Vectored Interrupt Controller (NVIC) | |
Type definitions for the NVIC Registers. | |
Status and Control Registers | |
Core Register type definitions. | |
System Control Block (SCB) | |
Type definitions for the System Control Block Registers. | |
System Controls not in SCB (SCnSCB) | |
Type definitions for the System Control and ID Register not in the SCB. | |
System Tick Timer (SysTick) | |
Type definitions for the System Timer Registers. | |
Trace Port Interface (TPI) | |
Type definitions for the Trace Port Interface (TPI) | |
