RTEMS  5.1
Files | Data Structures | Macros | Functions
Deterministic Priority Scheduler
Deterministic Priority Scheduler. More...
file  schedulerpriority.h
 Thread Manipulation with the Priority-Based Scheduler.
file  schedulerpriorityimpl.h
 Inlined Routines Associated with the Manipulation of the Priority-Based Scheduling Structures.
struct  Scheduler_priority_Context
struct  Scheduler_priority_Ready_queue
 Data for ready queue operations. More...
struct  Scheduler_priority_Node
 Scheduler node specialization for Deterministic Priority schedulers. More...
#define SCHEDULER_PRIORITY_ENTRY_POINTS
void _Scheduler_priority_Initialize (const Scheduler_Control *scheduler)
 Initializes the priority scheduler. More...
void _Scheduler_priority_Block (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Blocks the thread. More...
void _Scheduler_priority_Schedule (const Scheduler_Control *scheduler, Thread_Control *the_thread)
 Sets the heir thread to be the next ready thread. More...
void _Scheduler_priority_Unblock (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Unblocks the thread. More...
void _Scheduler_priority_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *base_node)
 Updates the priority of the node. More...
void _Scheduler_priority_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
 Initializes the node with the given priority. More...
void _Scheduler_priority_Yield (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Performs the yield of a thread. More...
RTEMS_INLINE_ROUTINE Scheduler_priority_Context_Scheduler_priority_Get_context (const Scheduler_Control *scheduler)
 Gets the context of the scheduler. More...
RTEMS_INLINE_ROUTINE Scheduler_priority_Node_Scheduler_priority_Thread_get_node (Thread_Control *the_thread)
 Gets the scheduler node of the thread. More...
RTEMS_INLINE_ROUTINE Scheduler_priority_Node_Scheduler_priority_Node_downcast (Scheduler_Node *node)
 Gets the priority node of the scheduler node. More...
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_initialize (Chain_Control *ready_queues, Priority_Control maximum_priority)
 Ready queue initialization. More...
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_enqueue (Chain_Node *node, Scheduler_priority_Ready_queue *ready_queue, Priority_bit_map_Control *bit_map)
 Enqueues a node on the specified ready queue. More...
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_enqueue_first (Chain_Node *node, Scheduler_priority_Ready_queue *ready_queue, Priority_bit_map_Control *bit_map)
 Enqueues a node on the specified ready queue as first. More...
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_extract (Chain_Node *node, Scheduler_priority_Ready_queue *ready_queue, Priority_bit_map_Control *bit_map)
 Extracts a node from the specified ready queue. More...
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Extract_body (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Extracts a node from the context of the scheduler. More...
RTEMS_INLINE_ROUTINE Chain_Node_Scheduler_priority_Ready_queue_first (Priority_bit_map_Control *bit_map, Chain_Control *ready_queues)
 Returns a pointer to the first node. More...
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Schedule_body (const Scheduler_Control *scheduler, Thread_Control *the_thread, bool force_dispatch)
 Scheduling decision logic. More...
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_update (Scheduler_priority_Ready_queue *ready_queue, unsigned int new_priority, Priority_bit_map_Control *bit_map, Chain_Control *ready_queues)
 Updates the specified ready queue data according to the new priority value. More...
◆ SCHEDULER_PRIORITY_ENTRY_POINTS
Value:
_Scheduler_priority_Initialize, /* initialize entry point */ \
_Scheduler_priority_Schedule, /* schedule entry point */ \
_Scheduler_priority_Yield, /* yield entry point */ \
_Scheduler_priority_Block, /* block entry point */ \
_Scheduler_priority_Unblock, /* unblock entry point */ \
_Scheduler_priority_Update_priority, /* update priority entry point */ \
_Scheduler_default_Map_priority, /* map priority entry point */ \
_Scheduler_default_Unmap_priority, /* unmap priority entry point */ \
_Scheduler_priority_Node_initialize, /* node initialize entry point */ \
_Scheduler_default_Node_destroy, /* node destroy entry point */ \
_Scheduler_default_Release_job, /* new period of task */ \
_Scheduler_default_Cancel_job, /* cancel period of task */ \
_Scheduler_default_Tick, /* tick entry point */ \
_Scheduler_default_Start_idle /* start idle entry point */ \
SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
void _Scheduler_priority_Node_initialize(const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
Definition: schedulerpriority.c:35
Entry points for the Deterministic Priority Based Scheduler.
◆ _Scheduler_priority_Block()
void _Scheduler_priority_Block ( const Scheduler_Control scheduler,
Thread_Control the_thread,
Scheduler_Node node
Blocks the thread.
Parameters
schedulerThe scheduler instance.
[in,out]the_threadThe thread to block.
[in,out]nodeThe thread's scheduler node.
◆ _Scheduler_priority_Extract_body()
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Extract_body ( const Scheduler_Control scheduler,
Scheduler_Node node
Parameters
the_threadThe thread of which the node will be extracted.
[in,out]Thenode which preserves the ready queue.
◆ _Scheduler_priority_Get_context()
RTEMS_INLINE_ROUTINE Scheduler_priority_Context* _Scheduler_priority_Get_context ( const Scheduler_Control scheduler)
Parameters
schedulerThe scheduler to get the context of.
Returns
The context of the scheduler.
◆ _Scheduler_priority_Initialize()
void _Scheduler_priority_Initialize ( const Scheduler_Control scheduler)
This routine initializes the priority scheduler.
Parameters
schedulerThe scheduler to initialize.
◆ _Scheduler_priority_Node_downcast()
RTEMS_INLINE_ROUTINE Scheduler_priority_Node* _Scheduler_priority_Node_downcast ( Scheduler_Node node)
Parameters
nodeThe node to get the priority node of.
Returns
The priority node.
◆ _Scheduler_priority_Node_initialize()
void _Scheduler_priority_Node_initialize ( const Scheduler_Control scheduler,
Scheduler_Node node,
Parameters
[out]nodeThe node to initialize.
the_threadThe thread of the scheduler node.
priorityThe priority for the initialization.
◆ _Scheduler_priority_Ready_queue_enqueue()
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_enqueue ( Chain_Node node,
Scheduler_priority_Ready_queue ready_queue,
Priority_bit_map_Control bit_map
The node is placed as the last element of its priority group.
Parameters
nodeThe node to enqueue.
[in,out]ready_queueThe ready queue.
[out]bit_mapThe priority bit map of the scheduler instance.
◆ _Scheduler_priority_Ready_queue_enqueue_first()
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_enqueue_first ( Chain_Node node,
The node is placed as the first element of its priority group.
Parameters
nodeThe node to enqueue as first.
◆ _Scheduler_priority_Ready_queue_extract()
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_extract ( Chain_Node node,
Parameters
nodeThe node to extract.
◆ _Scheduler_priority_Ready_queue_first()
RTEMS_INLINE_ROUTINE Chain_Node* _Scheduler_priority_Ready_queue_first ( Priority_bit_map_Control bit_map,
Chain_Control ready_queues
This routines returns a pointer to the first node on ready_queues.
Parameters
ready_queuesThe ready queues of the scheduler instance.
Returns
This method returns the first node.
◆ _Scheduler_priority_Ready_queue_initialize()
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_initialize ( Chain_Control ready_queues,
This routine initializes ready_queues for priority-based scheduling.
Parameters
[out]ready_queuesThe ready queue to initialize.
maximum_priorityThe maximum priority in the ready queue.
◆ _Scheduler_priority_Ready_queue_update()
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_update ( Scheduler_priority_Ready_queue ready_queue,
Parameters
new_priorityThe new priority.
◆ _Scheduler_priority_Schedule()
void _Scheduler_priority_Schedule ( const Scheduler_Control scheduler,
This kernel routine sets the heir thread to be the next ready thread by invoking the_scheduler->ready_queue->operations->first().
Parameters
the_threadThe thread for the operation.
◆ _Scheduler_priority_Schedule_body()
RTEMS_INLINE_ROUTINE void _Scheduler_priority_Schedule_body ( const Scheduler_Control scheduler,
bool  force_dispatch
This kernel routine implements scheduling decision logic for priority-based scheduling.
Parameters
[in,out]schedulerThe scheduler instance.
the_threadThis parameter is unused.
force_dispatchIndicates whether the dispatch happens also if the currently executing thread is set as not preemptible.
◆ _Scheduler_priority_Thread_get_node()
RTEMS_INLINE_ROUTINE Scheduler_priority_Node* _Scheduler_priority_Thread_get_node ( Thread_Control the_thread)
Parameters
the_threadThe thread to get the scheduler node of.
Returns
The scheduler node of the_thread.
◆ _Scheduler_priority_Unblock()
void _Scheduler_priority_Unblock ( const Scheduler_Control scheduler,
Scheduler_Node node
Parameters
[in,out]the_threadThe thread to unblock.
◆ _Scheduler_priority_Update_priority()
void _Scheduler_priority_Update_priority ( const Scheduler_Control scheduler,
Scheduler_Node base_node
Parameters
base_nodeThe thread's scheduler node.
◆ _Scheduler_priority_Yield()
void _Scheduler_priority_Yield ( const Scheduler_Control scheduler,
Scheduler_Node node
Parameters
[in,out]the_threadThe thread that performed the yield operation.
nodeThe scheduler node of the_thread.
