RTEMS 7.0-rc1
This source file contains the implementation of CTU CAN FD controller. More...
#include <stdatomic.h>#include <stdint.h>#include <stddef.h>#include <errno.h>#include <stdbool.h>#include <endian.h>#include <stdlib.h>#include <string.h>#include <rtems.h>#include <rtems/malloc.h>#include <rtems/score/basedefs.h>#include <dev/can/can-devcommon.h>#include <dev/can/can-helpers.h>#include <dev/can/can.h>#include <dev/can/ctucanfd.h>#include "ctucanfd_kframe.h"#include "ctucanfd_kregs.h"#include "ctucanfd_txb.h"#include "ctucanfd_internal.h"Functions | |
| struct rtems_can_chip * | rtems_ctucanfd_initialize (uintptr_t addr, rtems_vector_number irq, rtems_task_priority worker_priority, unsigned int ntxbufs, rtems_option irq_option, unsigned long can_clk_rate) |
| This function initializes the CTU CAN FD controller. | |
| struct rtems_can_chip * rtems_ctucanfd_initialize | ( | uintptr_t | addr, |
| rtems_vector_number | irq, | ||
| rtems_task_priority | worker_priority, | ||
| unsigned int | ntxbufs, | ||
| rtems_option | irq_option, | ||
| unsigned long | can_clk_rate | ||
This is an entry point for CTU CAN FD controller initialization. This function allocates generic CAN and CTU CAN FD related structures, sets default values and initializes the resources (interrupt handler, semaphore. worker thread).
| addr | CTU CAN FD code base address. |
| irq | Interrupt number |
| worker_priotiry | The priority of TX/RX worker thread |
| ntxbufs | Number of TX hardware buffers to be used. The function automatically limits the maximum HW buffers based on the used core. You can use RTEMS_CTUCANFD_NTXBUFS_MAX to setup maximum available buffers. |
| irq_option | RTEMS_INTERRUPT_SHARED or RTEMS_INTERRUPT_UNIQUE |
| can_clk_rate | CAN clock rate. |
