RTEMS 6.1-rc8
This header file provides interfaces of the SMP Scheduler which are only used by the implementation. More...
#include <rtems/score/schedulersmp.h>#include <rtems/score/assert.h>#include <rtems/score/chainimpl.h>#include <rtems/score/schedulersimpleimpl.h>#include <rtems/bspIo.h>Go to the source code of this file.
Typedefs | |
| typedef bool(* | Scheduler_SMP_Has_ready) (Scheduler_Context *context) |
| typedef Scheduler_Node *(* | Scheduler_SMP_Get_highest_ready) (Scheduler_Context *context, Scheduler_Node *filter) |
| typedef Scheduler_Node *(* | Scheduler_SMP_Get_lowest_ready) (Scheduler_Context *context) |
| typedef Scheduler_Node *(* | Scheduler_SMP_Get_lowest_scheduled) (Scheduler_Context *context, Scheduler_Node *filter) |
| typedef void(* | Scheduler_SMP_Extract) (Scheduler_Context *context, Scheduler_Node *node_to_extract) |
| typedef void(* | Scheduler_SMP_Insert) (Scheduler_Context *context, Scheduler_Node *node_to_insert, Priority_Control insert_priority) |
| typedef void(* | Scheduler_SMP_Move) (Scheduler_Context *context, Scheduler_Node *node_to_move) |
| typedef bool(* | Scheduler_SMP_Ask_for_help) (Scheduler_Context *context, Thread_Control *thread, Scheduler_Node *node) |
| typedef void(* | Scheduler_SMP_Update) (Scheduler_Context *context, Scheduler_Node *node_to_update, Priority_Control new_priority) |
| typedef void(* | Scheduler_SMP_Set_affinity) (Scheduler_Context *context, Scheduler_Node *node, void *arg) |
| typedef bool(* | Scheduler_SMP_Enqueue) (Scheduler_Context *context, Scheduler_Node *node_to_enqueue, Priority_Control priority) |
| typedef void(* | Scheduler_SMP_Enqueue_scheduled) (Scheduler_Context *context, Scheduler_Node *node_to_enqueue, Priority_Control priority) |
| typedef void(* | Scheduler_SMP_Allocate_processor) (Scheduler_Context *context, Scheduler_Node *scheduled, Per_CPU_Control *cpu) |
| typedef void(* | Scheduler_SMP_Register_idle) (Scheduler_Context *context, Scheduler_Node *idle, Per_CPU_Control *cpu) |
Enumerations | |
| enum | Scheduler_SMP_Action { SCHEDULER_SMP_DO_SCHEDULE , SCHEDULER_SMP_DO_NOT_SCHEDULE } |
| This enumeration defines what a scheduler should do with a node which could be scheduled. | |
| void | _Scheduler_SMP_Remove_ask_for_help_from_processor (Thread_Control *thread, Per_CPU_Control *cpu) |
| Removes the thread's ask for help request from the processor. | |
