RTEMS 6.1-rc8
This source file contains NOEL-V/APBUART definitions of BSP_output_char_function_type and :: BSP_output_char and an implementation of console_initialize(). More...
#include <rtems/bspIo.h>#include <rtems/console.h>#include <rtems/sysinit.h>#include <rtems/termiostypes.h>#include <bsp/fatal.h>#include <bsp/fdt.h>#include <bsp/irq.h>#include <bsp/riscv.h>#include <libfdt.h>#include <grlib/apbuart.h>#include <grlib/apbuart_termios.h>Macros | |
| #define | RISCV_CONSOLE_IS_COMPATIBLE(actual, actual_len, desired) |
| rtems_status_code | console_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| Console initialization entry point. | |
| RTEMS_SYSINIT_ITEM (riscv_console_probe, RTEMS_SYSINIT_BSP_START, RTEMS_SYSINIT_ORDER_LAST_BUT_5) | |
| BSP_output_char_function_type | BSP_output_char = riscv_output_char_init |
| This function pointer references the kernel character output implementation. | |
| BSP_polling_getchar_function_type | BSP_poll_char = NULL |
| This function pointer may reference the kernel character input implementation. | |
| #define RISCV_CONSOLE_IS_COMPATIBLE | ( | actual, | |
| actual_len, | |||
| desired | |||
| rtems_status_code console_initialize | ( | rtems_device_major_number | major, |
| rtems_device_minor_number | minor, | ||
| void * | arg | ||
This method initializes the console device driver.
| [in] | major | is the device driver major number. |
| [in] | minor | is the device driver minor number. |
| [in] | arg | is the parameters to this call. |
| RTEMS_SUCCESSFUL | The device driver is successfully initialized. |
Initialize all serial drivers specified in driver_context_table
| [in] | major | |
| [in] | minor | |
| [in] | arg |
| RTEMS_SUCCESSFUL | Initialization completed |
This routine initializes the console IO driver.
Parameters
| major | major number |
| minor | minor number |
Output parameters: NONE
| unsigned context |
Context identifier.
Context register selection.
