RTEMS 6.1-rc8
This group contains the SuperCore implementation. More...
Modules | |
| API Mutex Handler | |
| This group contains the API Mutex Handler implementation. | |
| Address Handler | |
| This group contains the Address Handler implementation. | |
| Assert Handler | |
| This group contains the Assert Handler implementation. | |
| Atomic Operations | |
| This group contains the atomic operations implementation. | |
| Barrier Handler | |
| This group contains the Barrier Handler implementation. | |
| CPU Architecture Support | |
| This group contains the implementation to support a processor architecture. | |
| Chain Handler | |
| This group contains the Chain Handler implementation. | |
| Context Handler | |
| This group contains the Context Handler implementation. | |
| Copyright Notice | |
| This group contains the implementation to provide a copyright notice and the RTEMS version. | |
| Exception Mapping Interfaces | |
| This group contains the interfaces for mapping machine exceptions to signals using the fatal error handler. | |
| Execute Once Support | |
| This group contains the implementation to execute a routine only once. | |
| Freechain Handler | |
| This group contains the Freechain Handler implementation. | |
| Futex Handler | |
| This group contains the Futex Handler implementation. | |
| Hash Handler | |
| This group contains the Hash Handler implementation. | |
| Heap Handler | |
| This group contains the Heap Handler implementation. | |
| ISR Handler | |
| This group contains the ISR Handler implementation. | |
| Internal Error Handler | |
| This group contains the Internal Error Handler implementation. | |
| MPCI Handler | |
| This group contains the MPCI Handler implementation. | |
| Memory Handler | |
| This group contains the Memory Handler implementation. | |
| Message Queue Handler | |
| This group contains the Message Queue Handler implementation. | |
| Multiprocessing (MP) Packet Handler | |
| This group contains the Multiprocessing (MP) Packet Handler implementation. | |
| Multiprocessor Resource Sharing Protocol (MrsP) | |
| This group contains the implementation to support the Multiprocessor Resource Sharing Protocol (MrsP) . | |
| Mutex Handler | |
| This group contains the Mutex Handler implementation. | |
| Object Handler | |
| This group contains the Object Handler implementation. | |
| Operation Status Support | |
| This group contains the Operation Status Support implementation. | |
| Per-CPU Information | |
| This group contains the implementation of the per-CPU information. | |
| Priority Bitmap | |
| This group contains the implementation to support priority bitmaps. | |
| Priority Handler | |
| This group contains the Priority Handler implementation. | |
| Processor Mask | |
| This group contains the implementation to support processor masks. | |
| Profiling Support | |
| This group contains the implementation to support profiling. | |
| Read-Write Lock | |
| This group contains the Read-Write Lock implementation. | |
| Red-Black Tree Handler | |
| This group contains the Red-Black Tree Handler implementation. | |
| SMP Barriers | |
| This group contains the SMP barrier implementation. | |
| SMP Locks | |
| This group contains the SMP lock implementation. | |
| SMP Support | |
| This group contains the implementation to support SMP systems. | |
| Scheduler Handler | |
| This group contains the Scheduler Handler implementation. | |
| Semaphore Handler | |
| This group contains the Semaphore Handler implementation. | |
| Stack Handler | |
| This group contains the Stack Handler implementation. | |
| System Lock Mutex Handler | |
| This group contains the System Lock Mutex Handler implementation. | |
| System Lock Mutex Support | |
| The System Lock Mutex Support helps to implement directives which use data structures compatible with the data structures defined by the Newlib provided <sys/lock.h> header file. | |
| System Lock Semaphore Support | |
| The System Lock Semaphore Support helps to implement directives which use data structures compatible with the data structures defined by the Newlib provided <sys/lock.h> header file. | |
| System State Handler | |
| This group contains the System State Handler implementation. | |
| Thread Handler | |
| This group contains the Thread Handler implementation. | |
| Thread Queue Handler | |
| This group contains the Thread Queue Handler implementation. | |
| Thread States | |
| This group contains the implementation to support thread states. | |
| Thread-Local Storage (TLS) | |
| This group contains the implementation to support thread-local storage (TLS). | |
| Time of Day Handler | |
| This group contains the Time of Day Handler implementation. | |
| Timecounter Handler | |
| This group contains the Timecounter Handler implementation. | |
| Timespec Helpers | |
| This group contains the implementation to support operations with variables of the POSIX defined struct timespec type. | |
| Timestamp Handler | |
| This group contains the Timestamp Handler implementation. | |
| User Extensions Handler | |
| This group contains the User Extensions Handler implementation. | |
| Watchdog Handler | |
| This group contains the Watchdog Handler implementation. | |
| Workspace Handler | |
| This group contains the Workspace Handler implementation. | |
Files | |
| file | basedefs.h |
| This header file provides basic definitions used by the API and the implementation. | |
| file | condition.c |
| This source file contains the implementation of _Condition_Wait(), _Condition_Wait_timed(), _Condition_Wait_recursive(), _Condition_Wait_recursive_timed(), _Condition_Wait_recursive_timed_ticks(), _Condition_Signal(), and _Condition_Broadcast(). | |
| file | configstackspacesize.c |
| This source file contains the implementation of rtems_configuration_get_stack_space_size(). | |
| file | debugisthreaddispatchingallowed.c |
| This source file contains the implementation of _Debug_Is_thread_dispatching_allowed(). | |
| file | debugunreachable.c |
| This source file contains the implementation of _Debug_Unreachable(). | |
| file | semaphore.c |
| This source file contains the implementation of _Semaphore_Wait(), _Semaphore_Wait_timed_ticks(), _Semaphore_Try_wait(), _Semaphore_Post(), and _Semaphore_Post_binary(). | |
| void * | RTEMS_DEQUALIFY_types_not_compatible (void) |
| A not implemented function to trigger compile time errors with an error message. | |
The SuperCore provides services for all APIs.
