RTEMS 6.1-rc8
This group contains the RTEMS implementation components. More...
Modules | |
| Application Configuration | |
| The application configuration defines system parameters according to configuration options (defines) provided by the application. | |
| Base64 Encoding and Decoding | |
| This group contains support functions for base64 and base64url encoding and decoding. | |
| Build Options | |
| This group contains files generated by the build system. | |
| CPU Usage Reporting | |
| This group contains the implementation of CPU Usage Reporting. | |
| Classic API | |
| This group contains the Classic API implementation. | |
| Cyclic Redundancy Check (CRC) Support | |
| This group contains functions to calculate Cyclic Redundancy Check (CRC) values. | |
| Doxygen Support | |
| FreeBSD Kernel Space Support | |
| This group contains the interfaces used by FreeBSD kernel space components ported to RTEMS. | |
| GNAT/RTEMS interrupts and exception handling | |
| Hash Algorithms | |
| This group contains items related to the implementation of hash algorithms. | |
| IO Library | |
| Provides system call and file system interface definitions. | |
| POSIX API | |
| This group contains definitions and modules which are used to implement the POSIX APIs supported by RTEMS. | |
| RTEMS Test Framework Implementation | |
| Implementation details. | |
| Standard C Library Support | |
| RTEMS Specific Support for the Standard C Library. | |
| SuperCore | |
| This group contains the SuperCore implementation. | |
Files | |
| file | cpucounterconverter.c |
| This source file contains a implementation of the counter value conversion functions. | |
| #define | _RTEMS_SYSINIT_INDEX_ITEM(handler, index) |
| Creates the system initialization item associated with the handler and index. | |
| #define | _RTEMS_SYSINIT_ITEM(handler, module, order) _RTEMS_SYSINIT_INDEX_ITEM( handler, 0x##module##order ) |
| Creates the system initialization item associated with the handler, module, and order. | |
| void | _Sysinit_Verbose (void) |
| Enables a verbose system initialization. | |
| #define _RTEMS_SYSINIT_INDEX_ITEM | ( | handler, | |
| index | |||
The enum helps to detect typos in the module and order parameters of RTEMS_SYSINIT_ITEM().
| #define _RTEMS_SYSINIT_ITEM | ( | handler, | |
| module, | |||
| order | |||
| ) | _RTEMS_SYSINIT_INDEX_ITEM( handler, 0x##module##order ) |
This helper macro is used to perform parameter expansion in RTEMS_SYSINIT_ITEM().
