RTEMS 6.1-rc8
This group contains the Thread Queue Handler implementation. More...
Files | |
| file | threadq.h |
| This header file provides interfaces of the Thread Queue Handler which are used by the implementation and the Application Configuration. | |
| file | threadqimpl.h |
| This header file provides interfaces of the Thread Queue Handler which are only used by the implementation. | |
| file | threadqops.h |
| This header file provides interfaces related to thread queue operations. | |
| file | threadq.c |
| This source file contains static assertions related to the Thread Queue Handler, the definition of _Thread_queue_Object_name, and the implementation of _Thread_queue_Acquire(), _Thread_queue_Do_acquire_critical(), _Thread_queue_Initialize(), _Thread_queue_MP_callout_do_nothing(), _Thread_queue_Object_initialize(), _Thread_queue_Queue_get_name_and_id(), _Thread_queue_Release(), and _Thread_queue_Release_critical(). | |
| file | threadqenqueue.c |
| This source file contains the implementation of _Thread_queue_Deadlock_fatal(), _Thread_queue_Deadlock_status(), _Thread_queue_Do_dequeue(), _Thread_queue_Enqueue(), _Thread_queue_Enqueue_do_nothing_extra(), _Thread_queue_Enqueue_sticky(), _Thread_queue_Extract_locked(), _Thread_queue_Path_acquire(), _Thread_queue_Path_release(), _Thread_queue_Resume(),_Thread_queue_Surrender(), _Thread_queue_Surrender_no_priority(), _Thread_queue_Surrender_sticky(). | |
| file | threadqextract.c |
| This source file contains the implementation of _Thread_queue_Extract(). | |
| file | threadqextractwithproxy.c |
| This source file contains the implementation of _Thread_MP_Extract_proxy(). | |
| file | threadqfirst.c |
| This source file contains the implementation of _Thread_queue_First(). | |
| file | threadqflush.c |
| This source file contains the implementation of _Thread_queue_Flush_default_filter(), _Thread_queue_Flush_status_object_was_deleted(), _Thread_queue_Flush_status_unavailable(), and _Thread_queue_Flush_critical(). | |
| file | threadqgetnameandid.c |
| This source file contains the implementation of _Thread_queue_Queue_get_name_and_id(). | |
| file | threadqops.c |
| This source file contains the definition of _Thread_queue_Operations_default, _Thread_queue_Operations_FIFO, _Thread_queue_Operations_priority, and _Thread_queue_Operations_priority_inherit. | |
| file | threadqtimeout.c |
| This source file contains the implementation of _Thread_queue_Add_timeout_ticks(), _Thread_queue_Add_timeout_timespec(), _Thread_queue_Add_timeout_monotonic_timespec(), and _Thread_queue_Add_timeout_realtime_timespec(). | |
| struct | Thread_queue_Lock_context |
| struct | Thread_queue_Context |
| Thread queue context for the thread queue methods. More... | |
| struct | Thread_queue_Priority_queue |
| Thread priority queue. More... | |
| struct | _Thread_queue_Heads |
| Thread queue heads. More... | |
| struct | Thread_queue_Queue |
| struct | Thread_queue_Operations |
| The thread queue operations are used to manage the threads of a thread queue. More... | |
| struct | Thread_queue_Control |
| struct | Thread_queue_Syslock_queue |
| Thread queue with a layout compatible to struct _Thread_queue_Queue defined in Newlib <sys/lock.h>. More... | |
| struct | Thread_queue_Object |
| Helper structure to ensure that all objects containing a thread queue have the right layout. More... | |
| #define | THREAD_QUEUE_LINK_OF_PATH_NODE(node) RTEMS_CONTAINER_OF( node, Thread_queue_Link, Path_node ); |
| #define | _Thread_queue_Context_ISR_disable(queue_context, level) |
| #define | _Thread_queue_Context_set_MP_callout(queue_context, mp_callout) |
| Sets the MP callout in the thread queue context. | |
| #define | _Thread_queue_Queue_acquire_critical(queue, lock_stats, lock_context) _Thread_queue_Queue_do_acquire_critical( queue, lock_context ) |
| #define | THREAD_QUEUE_INITIALIZER(_name) |
| #define | THREAD_QUEUE_OBJECT_ASSERT(object_type, wait_queue_member, msg) |
| #define | THREAD_QUEUE_QUEUE_TO_OBJECT(queue) |
Typedefs | |
| typedef struct _Thread_Control | Thread_Control |
| typedef struct Thread_queue_Context | Thread_queue_Context |
| typedef struct Thread_queue_Queue | Thread_queue_Queue |
| typedef struct Thread_queue_Operations | Thread_queue_Operations |
| typedef void(* | Thread_queue_Enqueue_callout) (Thread_queue_Queue *queue, Thread_Control *the_thread, struct Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context) |
| Thread queue enqueue callout. | |
| typedef void(* | Thread_queue_Deadlock_callout) (Thread_Control *the_thread) |
| Thread queue deadlock callout. | |
| typedef struct _Thread_queue_Heads | Thread_queue_Heads |
| Thread queue heads. | |
| typedef void(* | Thread_queue_Priority_actions_operation) (Thread_queue_Queue *queue, Priority_Actions *priority_actions) |
| Thread queue action operation. | |
| typedef void(* | Thread_queue_Enqueue_operation) (Thread_queue_Queue *queue, Thread_Control *the_thread, Thread_queue_Context *queue_context) |
| Thread queue enqueue operation. | |
| typedef void(* | Thread_queue_Extract_operation) (Thread_queue_Queue *queue, Thread_Control *the_thread, Thread_queue_Context *queue_context) |
| Thread queue extract operation. | |
| typedef Thread_Control *(* | Thread_queue_Surrender_operation) (Thread_queue_Queue *queue, Thread_queue_Heads *heads, Thread_Control *previous_owner, Thread_queue_Context *queue_context) |
| Thread queue surrender operation. | |
| typedef Thread_Control *(* | Thread_queue_First_operation) (const Thread_queue_Heads *heads) |
| Gets the first thread on the queue. | |
| typedef Thread_Control *(* | Thread_queue_Flush_filter) (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context) |
| Thread queue flush filter function. | |
Enumerations | |
| enum | Thread_queue_Deadlock_status { THREAD_QUEUE_NO_DEADLOCK , THREAD_QUEUE_DEADLOCK_DETECTED } |
| This is a status code to indicate if a deadlock was detected or not. More... | |
| void | _Thread_queue_Enqueue_do_nothing_extra (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context) |
| Does nothing. | |
| void | _Thread_queue_Add_timeout_ticks (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context) |
| Adds timeout ticks of the queue to the thread. | |
| void | _Thread_queue_Add_timeout_monotonic_timespec (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context) |
| Adds a monotonic timespec to the thread and sets the watchdog header to monotonic. | |
| void | _Thread_queue_Add_timeout_realtime_timespec (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context) |
| Adds a monotonic timespec to the thread and sets the watchdog header to realtime. | |
| void | _Thread_queue_Deadlock_status (Thread_Control *the_thread) |
| Sets the thread wait return code to STATUS_DEADLOCK. | |
| void | _Thread_queue_Deadlock_fatal (Thread_Control *the_thread) |
| Results in an INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK fatal error. | |
| size_t | _Thread_queue_Queue_get_name_and_id (const Thread_queue_Queue *queue, char *buffer, size_t buffer_size, Objects_Id *id) |
| Copies the thread queue name to the specified buffer. | |
| void | _Thread_queue_Enqueue (Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context) |
| Blocks the thread and places it on the thread queue. | |
| bool | _Thread_queue_Extract_locked (Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context) |
| Extracts the thread from the thread queue, restores the default wait operations and restores the default thread lock. | |
| void | _Thread_queue_Resume (Thread_queue_Queue *queue, Thread_Control *the_thread, Thread_queue_Context *queue_context) |
| Resumes the extracted or surrendered thread. | |
| void | _Thread_queue_Extract (Thread_Control *the_thread) |
| Extracts thread from thread queue. | |
| void | _Thread_queue_Surrender (Thread_queue_Queue *queue, Thread_queue_Heads *heads, Thread_Control *previous_owner, Thread_queue_Context *queue_context, const Thread_queue_Operations *operations) |
| Surrenders the thread queue previously owned by the thread to the first enqueued thread. | |
| void | _Thread_queue_Surrender_no_priority (Thread_queue_Queue *queue, Thread_queue_Heads *heads, Thread_queue_Context *queue_context, const Thread_queue_Operations *operations) |
| Status_Control | _Thread_queue_Surrender_priority_ceiling (Thread_queue_Queue *queue, Thread_Control *executing, Priority_Node *ceiling_priority, Thread_queue_Context *queue_context, const Thread_queue_Operations *operations) |
| Thread_Control * | _Thread_queue_First (Thread_queue_Control *the_thread_queue, const Thread_queue_Operations *operations) |
Returns the first thread on the thread queue if it exists, otherwise NULL. | |
| Thread_Control * | _Thread_queue_Flush_default_filter (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context) |
| Default thread queue flush filter function. | |
| Thread_Control * | _Thread_queue_Flush_status_unavailable (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context) |
| Status unavailable thread queue flush filter function. | |
| Thread_Control * | _Thread_queue_Flush_status_object_was_deleted (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context) |
| Status object was deleted thread queue flush filter function. | |
| size_t | _Thread_queue_Flush_critical (Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_queue_Flush_filter filter, Thread_queue_Context *queue_context) |
| Unblocks all threads enqueued on the thread queue. | |
| void | _Thread_queue_Initialize (Thread_queue_Control *the_thread_queue, const char *name) |
| Initializes the thread queue control to the given name. | |
| void | _Thread_queue_Object_initialize (Thread_queue_Control *the_thread_queue) |
| Initializes a thread queue embedded in an object with identifier. | |
| void | _Thread_queue_Do_nothing_priority_actions (Thread_queue_Queue *queue, Priority_Actions *priority_actions) |
| Initializes the priority actions so that no actions are performed. | |
| void | _Thread_queue_FIFO_enqueue (Thread_queue_Queue *queue, Thread_Control *the_thread, Thread_queue_Context *queue_context) |
| Enqueues the thread to the FIFO thread queue. | |
| void | _Thread_queue_FIFO_extract (Thread_queue_Queue *queue, Thread_Control *the_thread, Thread_queue_Context *queue_context) |
| Extracts the thread from the FIFO thread queue. | |
| Thread_Control * | _Thread_queue_FIFO_surrender (Thread_queue_Queue *queue, Thread_queue_Heads *heads, Thread_Control *previous_owner, Thread_queue_Context *queue_context) |
| Surrenders the thread queue to the first thread on the FIFO thread queue. | |
| Thread_Control * | _Thread_queue_FIFO_first (const Thread_queue_Heads *heads) |
| Gets the first thread on the FIFO thread queue. | |
| const Thread_queue_Operations | _Thread_queue_Operations_default |
| The default thread queue operations are used when a thread is not enqueued on a thread queue. | |
| const Thread_queue_Operations | _Thread_queue_Operations_FIFO |
| The FIFO thread queue operations are used when a thread is enqueued on a thread queue and provide FIFO ordering of enqueued threads. | |
| const Thread_queue_Operations | _Thread_queue_Operations_priority |
| The FIFO thread queue operations are used when a thread is enqueued on a thread queue and provide priority ordering of enqueued threads. | |
| const Thread_queue_Operations | _Thread_queue_Operations_priority_inherit |
| The FIFO thread queue operations are used when a thread is enqueued on a thread queue and provide priority ordering of enqueued threads with support for priority inheritance. | |
| const char | _Thread_queue_Object_name [] |
| The special thread queue name to indicated that the thread queue is embedded in an object with identifier. | |
This handler provides the capability to have threads block in ordered sets. The sets may be ordered using the FIFO or priority discipline.
| #define _Thread_queue_Context_ISR_disable | ( | queue_context, | |
| level | |||
| #define _Thread_queue_Context_set_MP_callout | ( | queue_context, | |
| mp_callout | |||
| [out] | queue_context | The thread queue context. |
| mp_callout | Callout to unblock the thread in case it is actually a thread proxy. This parameter is only used on multiprocessing configurations. Used by thread queue extract and unblock methods for objects with multiprocessing (MP) support. |
| #define THREAD_QUEUE_INITIALIZER | ( | _name | ) |
| #define THREAD_QUEUE_OBJECT_ASSERT | ( | object_type, | |
| wait_queue_member, | |||
| msg | |||
| #define THREAD_QUEUE_QUEUE_TO_OBJECT | ( | queue | ) |
| typedef void(* Thread_queue_Deadlock_callout) (Thread_Control *the_thread) |
| the_thread | The thread that detected the deadlock. |
| typedef void(* Thread_queue_Enqueue_callout) (Thread_queue_Queue *queue, Thread_Control *the_thread, struct Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context) |
| [in] | queue | The actual thread queue. |
| [in] | the_thread | The thread to enqueue. |
| [in] | cpu_self | The current processor. |
| [in] | queue_context | The thread queue context of the lock acquire. |
| typedef void(* Thread_queue_Enqueue_operation) (Thread_queue_Queue *queue, Thread_Control *the_thread, Thread_queue_Context *queue_context) |
A potential thread to update the priority due to priority inheritance is returned via the thread queue context. This thread is handed over to _Thread_Priority_update().
| [in] | the_thread | The thread to enqueue on the queue. |
| typedef void(* Thread_queue_Extract_operation) (Thread_queue_Queue *queue, Thread_Control *the_thread, Thread_queue_Context *queue_context) |
| [in] | the_thread | The thread to extract from the thread queue. |
| typedef Thread_Control *(* Thread_queue_First_operation) (const Thread_queue_Heads *heads) |
| heads | are heads of the thread queue. |
| NULL | No thread is enqueued on the thread queue. |
| typedef Thread_Control *(* Thread_queue_Flush_filter) (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context) |
Called under protection of the thread queue lock by _Thread_queue_Flush_critical() to optionally alter the thread wait information and control the iteration.
| the_thread | The thread to extract. This is the first parameter to optimize for architectures that use the same register for the first parameter and the return value. |
| queue_context | The thread queue context of the lock acquire. May be used to pass additional data to the filter function via an overlay structure. The filter function should not release or acquire the thread queue lock. |
| the_thread | Extract this thread. |
| NULL | Do not extract this thread and stop the thread queue flush operation. Threads that are already extracted will complete the flush operation. |
| typedef struct _Thread_queue_Heads Thread_queue_Heads |
Thread queue heads.
Each thread is equipped with spare thread queue heads in case it is not enqueued on a thread queue. The first thread enqueued on a thread queue will give its spare thread queue heads to that thread queue. The threads arriving at the queue will add their thread queue heads to the free chain of the queue heads provided by the first thread enqueued. Once a thread is dequeued it use the free chain to get new spare thread queue heads.
Uses a leading underscore in the structure name to allow forward declarations in standard header files provided by Newlib and GCC.
| typedef void(* Thread_queue_Priority_actions_operation) (Thread_queue_Queue *queue, Priority_Actions *priority_actions) |
| [in] | the_thread | The thread. |
| [in] | queue_context | The thread queue context providing the thread queue action set to perform. Returns the thread queue action set to perform on the thread queue owner or the empty set in case there is nothing to do. |
| typedef Thread_Control *(* Thread_queue_Surrender_operation) (Thread_queue_Queue *queue, Thread_queue_Heads *heads, Thread_Control *previous_owner, Thread_queue_Context *queue_context) |
This operation must dequeue and return the first thread on the queue.
| [in] | heads | The thread queue heads. It must not be NULL. |
| [in] | previous_owner | The previous owner of the thread queue. |
| void _Thread_queue_Add_timeout_monotonic_timespec | ( | Thread_queue_Queue * | queue, |
| Thread_Control * | the_thread, | ||
| Per_CPU_Control * | cpu_self, | ||
| Thread_queue_Context * | queue_context | ||
| queue | This parameter is unused. | |
| [in,out] | the_thread | The thread to add the timeout and set watchdog header to monotonic. |
| cpu_self | The cpu to get the monotonic watchdog header from. | |
| void _Thread_queue_Add_timeout_realtime_timespec | ( | Thread_queue_Queue * | queue, |
| [in,out] | the_thread | The thread to add the timeout and set watchdog header to realtime. |
| cpu_self | The cpu to get the realtime watchdog header from. | |
| void _Thread_queue_Add_timeout_ticks | ( | Thread_queue_Queue * | queue, |
| [in,out] | the_thread | The thread to add timeout ticks to. |
| cpu_self | The cpu for the operation. | |
| void _Thread_queue_Deadlock_fatal | ( | Thread_Control * | the_thread | ) |
| the_thread | The thread for the operation. |
| void _Thread_queue_Deadlock_status | ( | Thread_Control * | the_thread | ) |
| [out] | the_thread | The thread to set the wait return code to STATUS_DEADLOCK. |
| void _Thread_queue_Do_nothing_priority_actions | ( | Thread_queue_Queue * | queue, |
| Priority_Actions * | priority_actions | ||
| queue | is unused. | |
| [out] | priority_actions | is initialized so that no actions are performed. |
| void _Thread_queue_Enqueue | ( | Thread_queue_Queue * | queue, |
| const Thread_queue_Operations * | operations, | ||
This enqueues the thread on the thread queue, blocks the thread, and optionally starts the thread timer in case the timeout discipline is not WATCHDOG_NO_TIMEOUT. Timeout discipline and value are in the queue_context.
The caller must be the owner of the thread queue lock. This function will release the thread queue lock and register it as the new thread lock. Thread dispatching is disabled before the thread queue lock is released. Thread dispatching is enabled once the sequence to block the thread is complete. The operation to enqueue the thread on the queue is protected by the thread queue lock. This makes it possible to use the thread queue lock to protect the state of objects embedding the thread queue and directly enter _Thread_queue_Enqueue() in case the thread must block.
The thread queue context must be set up with the following functions, otherwise the behaviour is unpredictable
| queue | The actual thread queue. | |
| operations | The thread queue operations. | |
| [in,out] | the_thread | The thread to enqueue. |
| [in,out] | queue_context | The thread queue context of the lock acquire. |
| void _Thread_queue_Enqueue_do_nothing_extra | ( | Thread_queue_Queue * | queue, |
Does nothing.
| the_thread | This parameter is unused. |
| cpu_self | This parameter is unused. |
| queue_context | This parameter is unused. |
| void _Thread_queue_Extract | ( | Thread_Control * | the_thread | ) |
This routine removes the_thread its thread queue and cancels any timeouts associated with this blocking.
| [in,out] | the_thread | The pointer to a thread control block that is to be removed |
| bool _Thread_queue_Extract_locked | ( | Thread_queue_Queue * | queue, |
The caller must be the owner of the thread queue lock. The thread queue lock is not released.
| [in,out] | the_thread | The thread to extract. |
| [in,out] | queue_context | The thread queue context. |
| void _Thread_queue_FIFO_enqueue | ( | Thread_queue_Queue * | queue, |
| [in,out] | queue | is the thread queue. |
| [in,out] | the_thread | is the thread to enqueue. |
| [in,out] | queue_context | is the thread queue context. |
| void _Thread_queue_FIFO_extract | ( | Thread_queue_Queue * | queue, |
| [in,out] | the_thread | is the thread to extract. |
| Thread_Control * _Thread_queue_FIFO_first | ( | const Thread_queue_Heads * | heads | ) |
| Thread_Control * _Thread_queue_FIFO_surrender | ( | Thread_queue_Queue * | queue, |
| Thread_queue_Heads * | heads, | ||
| Thread_Control * | previous_owner, | ||
| [in,out] | heads | are heads of the thread queue. |
| previous_owner | is unused. | |
| Thread_Control * _Thread_queue_First | ( | Thread_queue_Control * | the_thread_queue, |
| const Thread_queue_Operations * | operations | ||
| the_thread_queue | The thread queue. |
| first | The first thread on the thread queue according to the enqueue order. |
| NULL | No thread is present on the thread queue. |
| size_t _Thread_queue_Flush_critical | ( | Thread_queue_Queue * | queue, |
| Thread_queue_Flush_filter | filter, | ||
This function iteratively extracts the first enqueued thread of the thread queue until the thread queue is empty or the filter function indicates a stop. The thread timers of the extracted threads are cancelled. The extracted threads are unblocked.
| filter | The filter functions is called for each thread to extract from the thread queue. It may be used to alter the thread under protection of the thread queue lock, for example to set the thread wait return code. The return value of the filter function controls if the thread queue flush operation should stop or continue. |
| Thread_Control * _Thread_queue_Flush_default_filter | ( | Thread_Control * | the_thread, |
| Thread_queue_Queue * | queue, | ||
| Thread_Control * _Thread_queue_Flush_status_object_was_deleted | ( | Thread_Control * | the_thread, |
Sets the thread wait return code of the thread to STATUS_OBJECT_WAS_DELETED
| [out] | the_thread | The thread to extract. |
| Thread_Control * _Thread_queue_Flush_status_unavailable | ( | Thread_Control * | the_thread, |
Sets the thread wait return code of the thread to STATUS_UNAVAILABLE.
| void _Thread_queue_Initialize | ( | Thread_queue_Control * | the_thread_queue, |
| const char * | name | ||
| [out] | the_thread_queue | The thread queue control to initialize. |
| name | The name for the_thread_queue. |
| void _Thread_queue_Object_initialize | ( | Thread_queue_Control * | the_thread_queue | ) |
The object must have the layout specified by Thread_queue_Object. It should be ensured with the THREAD_QUEUE_OBJECT_ASSERT() static assertion.
| [out] | the_thread_queue | The thread queue. |
| size_t _Thread_queue_Queue_get_name_and_id | ( | const Thread_queue_Queue * | queue, |
| char * | buffer, | ||
| size_t | buffer_size, | ||
| Objects_Id * | id | ||
| [out] | buffer | The buffer for the thread queue name copy. |
| buffer_size | The buffer size in characters. | |
| id | The object identifier in case the thread queue is embedded in an object with identifier, otherwise it is set to 0. |
| void _Thread_queue_Resume | ( | Thread_queue_Queue * | queue, |
This function makes the thread ready again. If necessary, the thread is unblocked and its thread timer removed.
The thread shall have been extracted from the thread queue or surrendered by the thread queue right before the call to this function. The caller shall be the owner of the thread queue lock.
| queue | is the actual thread queue. | |
| [in,out] | the_thread | is the thread to make ready and unblock. |
| void _Thread_queue_Surrender | ( | Thread_queue_Queue * | queue, |
| Thread_queue_Context * | queue_context, | ||
The owner of the thread queue must be set to NULL by the caller.
This function releases the thread queue lock. In addition it performs a thread dispatch if necessary.
| [in,out] | queue | The actual thread queue. |
| heads | The thread queue heads. It must not be NULL. | |
| previous_owner | The previous owner thread surrendering the thread queue. | |
| queue_context | The thread queue context of the lock acquire. | |
| void _Thread_queue_Surrender_no_priority | ( | Thread_queue_Queue * | queue, |
| Status_Control _Thread_queue_Surrender_priority_ceiling | ( | Thread_queue_Queue * | queue, |
| Thread_Control * | executing, | ||
| Priority_Node * | ceiling_priority, | ||
extern |
extern |
The default operations may be used by _Thread_Priority_apply() and _Thread_Continue() if the thread is not enqueued on a thread queue. The default operations do nothing.
