RTEMS 6.1-rc6
Macros | Typedefs | Functions
Manages the Trace and Debugging Features of the RTEMS RFS File System. More...
#include <stddef.h>
#include <stdbool.h>
#include <stdint.h>
#define RTEMS_RFS_TRACE   1
#define RTEMS_RFS_TRACE_ALL   (0xffffffffffffffffULL)
#define RTEMS_RFS_TRACE_OPEN   (1ULL << 0)
#define RTEMS_RFS_TRACE_CLOSE   (1ULL << 1)
#define RTEMS_RFS_TRACE_MUTEX   (1ULL << 2)
#define RTEMS_RFS_TRACE_BUFFER_OPEN   (1ULL << 3)
#define RTEMS_RFS_TRACE_BUFFER_CLOSE   (1ULL << 4)
#define RTEMS_RFS_TRACE_BUFFER_SYNC   (1ULL << 5)
#define RTEMS_RFS_TRACE_BUFFER_RELEASE   (1ULL << 6)
#define RTEMS_RFS_TRACE_BUFFER_CHAINS   (1ULL << 7)
#define RTEMS_RFS_TRACE_BUFFER_HANDLE_REQUEST   (1ULL << 8)
#define RTEMS_RFS_TRACE_BUFFER_HANDLE_RELEASE   (1ULL << 9)
#define RTEMS_RFS_TRACE_BUFFER_SETBLKSIZE   (1ULL << 10)
#define RTEMS_RFS_TRACE_BUFFERS_RELEASE   (1ULL << 11)
#define RTEMS_RFS_TRACE_BLOCK_FIND   (1ULL << 12)
#define RTEMS_RFS_TRACE_BLOCK_MAP_GROW   (1ULL << 13)
#define RTEMS_RFS_TRACE_BLOCK_MAP_SHRINK   (1ULL << 14)
#define RTEMS_RFS_TRACE_GROUP_OPEN   (1ULL << 15)
#define RTEMS_RFS_TRACE_GROUP_CLOSE   (1ULL << 16)
#define RTEMS_RFS_TRACE_GROUP_BITMAPS   (1ULL << 17)
#define RTEMS_RFS_TRACE_INODE_OPEN   (1ULL << 18)
#define RTEMS_RFS_TRACE_INODE_CLOSE   (1ULL << 19)
#define RTEMS_RFS_TRACE_INODE_LOAD   (1ULL << 20)
#define RTEMS_RFS_TRACE_INODE_UNLOAD   (1ULL << 21)
#define RTEMS_RFS_TRACE_INODE_CREATE   (1ULL << 22)
#define RTEMS_RFS_TRACE_INODE_DELETE   (1ULL << 23)
#define RTEMS_RFS_TRACE_LINK   (1ULL << 24)
#define RTEMS_RFS_TRACE_UNLINK   (1ULL << 25)
#define RTEMS_RFS_TRACE_DIR_LOOKUP_INO   (1ULL << 26)
#define RTEMS_RFS_TRACE_DIR_LOOKUP_INO_CHECK   (1ULL << 27)
#define RTEMS_RFS_TRACE_DIR_LOOKUP_INO_FOUND   (1ULL << 28)
#define RTEMS_RFS_TRACE_DIR_ADD_ENTRY   (1ULL << 29)
#define RTEMS_RFS_TRACE_DIR_DEL_ENTRY   (1ULL << 30)
#define RTEMS_RFS_TRACE_DIR_READ   (1ULL << 31)
#define RTEMS_RFS_TRACE_DIR_EMPTY   (1ULL << 32)
#define RTEMS_RFS_TRACE_SYMLINK   (1ULL << 33)
#define RTEMS_RFS_TRACE_SYMLINK_READ   (1ULL << 34)
#define RTEMS_RFS_TRACE_FILE_OPEN   (1ULL << 35)
#define RTEMS_RFS_TRACE_FILE_CLOSE   (1ULL << 36)
#define RTEMS_RFS_TRACE_FILE_IO   (1ULL << 37)
#define RTEMS_RFS_TRACE_FILE_SET   (1ULL << 38)
typedef uint64_t rtems_rfs_trace_mask
bool rtems_rfs_trace (rtems_rfs_trace_mask mask)
rtems_rfs_trace_mask rtems_rfs_trace_set_mask (rtems_rfs_trace_mask mask)
rtems_rfs_trace_mask rtems_rfs_trace_clear_mask (rtems_rfs_trace_mask mask)
int rtems_rfs_trace_shell_command (int argc, char *argv[])
RTEMS File Systems Trace manages the trace and debugging features of the RTEMS RFS file system. The design allows all tracing code and strings to be removed from the target code for small footprint systems.
◆ RTEMS_RFS_TRACE
Is tracing enabled ?
◆ RTEMS_RFS_TRACE_ALL
List of tracing bits for the various parts of the file system.
Typedef Documentation
◆ rtems_rfs_trace_mask
The type of the mask.
◆ rtems_rfs_trace()
bool rtems_rfs_trace ( rtems_rfs_trace_mask  mask)
Call to check if this part is bring traced. If RTEMS_RFS_TRACE is defined to 0 the code is dead code elminiated when built with -Os, -O2, or higher.
Parameters
[in]maskis the part of the API to trace.
Return values
trueTracing is active for the mask.
falseDo not trace.
◆ rtems_rfs_trace_clear_mask()
rtems_rfs_trace_mask rtems_rfs_trace_clear_mask ( rtems_rfs_trace_mask  mask)
Clear the mask.
Parameters
[in]maskare the mask bits to clear.
Return values
maskThe previous mask.
◆ rtems_rfs_trace_set_mask()
rtems_rfs_trace_mask rtems_rfs_trace_set_mask ( rtems_rfs_trace_mask  mask)
Set the mask.
Parameters
[in]maskare the mask bits to set.
Return values
◆ rtems_rfs_trace_shell_command()
int rtems_rfs_trace_shell_command ( int  argc,
char *  argv[]
Add shell trace shell command.
