Here is a list of all documented functions, variables, defines, enums, and typedefs with links to the documentation:
- x -
- XBAR1_IRQ_0_1_IRQn : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBAR1_IRQ_2_3_IRQn : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBAR_CLOCKS : fsl_clock.h
- XBARA1 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA1_BASE : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_BASE_ADDRS : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_BASE_PTRS : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_CLOCKS : fsl_clock.h
- XBARA_CTRL0_DEN0 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_CTRL0_DEN1 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_CTRL0_EDGE0 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_CTRL0_EDGE1 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_CTRL0_IEN0 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_CTRL0_IEN1 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_CTRL0_STS0 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_CTRL0_STS1 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_CTRL1_DEN2 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_CTRL1_DEN3 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_CTRL1_EDGE2 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_CTRL1_EDGE3 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_CTRL1_IEN2 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_CTRL1_IEN3 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_CTRL1_STS2 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARA_CTRL1_STS3 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARB2 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARB2_BASE : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARB3 : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARB3_BASE : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARB_BASE_ADDRS : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARB_BASE_PTRS : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XBARB_CLOCKS : fsl_clock.h
- XDMAC_CHANNEL_NUM : xdmac.h
- XDMAC_CONTROLLER_NUM : xdmac.h
- XDMAC_MAX_BT_SIZE : xdmac.h
- XDMAD_AllocateChannel() : xdmad.c
- XDMAD_ConfigureTransfer() : xdmad.c
- XDMAD_FreeChannel() : xdmad.c
- XDMAD_PrepareChannel() : xdmad.c
- XDMAD_SetCallback() : xdmad.c
- XDMAD_StartTransfer() : xdmad.c
- XDMAD_StopTransfer() : xdmad.c
- XDMAIF_Get_ChannelNumber() : xdma_hardware_interface.c
- XDMAIF_IsValidatedPeripherOnDma() : xdma_hardware_interface.c
- XECC_BASE_ADDRS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_BASE_PTRS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_CLOCKS : fsl_clock.h
- XECC_ECC_BASE_ADDR0_ECC_BASE_ADDR0 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ECC_BASE_ADDR1_ECC_BASE_ADDR1 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ECC_BASE_ADDR2_ECC_BASE_ADDR2 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ECC_BASE_ADDR3_ECC_BASE_ADDR3 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ECC_CTRL_ECC_EN : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ECC_CTRL_RECC_EN : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ECC_CTRL_SWAP_EN : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ECC_CTRL_WECC_EN : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ECC_END_ADDR0_ECC_END_ADDR0 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ECC_END_ADDR1_ECC_END_ADDR1 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ECC_END_ADDR2_ECC_END_ADDR2 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ECC_END_ADDR3_ECC_END_ADDR3 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ERR_DATA_INJ_ERR_DATA_INJ : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ERR_ECC_INJ_ERR_ECC_INJ : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ERR_SIG_EN_MULTI_ERR_SIG_EN : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ERR_SIG_EN_Reserved1 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ERR_SIG_EN_SINGLE_ERR_SIG_EN : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ERR_STAT_EN_MULIT_ERR_STAT_EN : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ERR_STAT_EN_Reserved1 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ERR_STAT_EN_SINGLE_ERR_STAT_EN : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ERR_STATUS_MULTI_ERR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ERR_STATUS_Reserved1 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_ERR_STATUS_SINGLE_ERR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_FLEXSPI1 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_FLEXSPI1_BASE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_FLEXSPI1_FATAL_INT_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_FLEXSPI1_INT_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_FLEXSPI2 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_FLEXSPI2_BASE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_FLEXSPI2_FATAL_INT_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_FLEXSPI2_INT_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_MULTI_ERR_ADDR_MULTI_ERR_ADDR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_MULTI_ERR_BIT_FIELD_MULTI_ERR_BIT_FIELD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_MULTI_ERR_BIT_FIELD_Reserved1 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_MULTI_ERR_DATA_MULTI_ERR_DATA : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_MULTI_ERR_ECC_MULTI_ERR_ECC : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_SEMC : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_SEMC_BASE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_SEMC_FATAL_INT_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_SEMC_INT_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_SINGLE_ERR_ADDR_SINGLE_ERR_ADDR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_SINGLE_ERR_BIT_FIELD_Reserved1 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_SINGLE_ERR_BIT_FIELD_SINGLE_ERR_BIT_FIELD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_SINGLE_ERR_DATA_SINGLE_ERR_DATA : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_SINGLE_ERR_ECC_SINGLE_ERR_ECC : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XECC_SINGLE_ERR_POS_SINGLE_ERR_POS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- xilinx_zynqmp_nor_jffs2_initialize() : jffs2_xqspipsu.h
- XMIT_RESET : uart.h
- XNANDPSU_BB_PATTERN : xnandpsu_bbm.h
- XNANDPSU_BB_PTRN_LEN_LARGE_PAGE : xnandpsu_bbm.h
- XNANDPSU_BB_PTRN_LEN_SML_PAGE : xnandpsu_bbm.h
- XNANDPSU_BB_PTRN_OFF_LARGE_PAGE : xnandpsu_bbm.h
- XNANDPSU_BB_PTRN_OFF_SML_PAGE : xnandpsu_bbm.h
- XNANDPSU_BBT_BLOCK_SHIFT : xnandpsu_bbm.h
- XNANDPSU_BBT_DESC_MAX_BLOCKS : xnandpsu_bbm.h
- XNANDPSU_BBT_DESC_PAGE_OFFSET : xnandpsu_bbm.h
- XNANDPSU_BBT_DESC_SIG_LEN : xnandpsu_bbm.h
- XNANDPSU_BBT_DESC_SIG_OFFSET : xnandpsu_bbm.h
- XNANDPSU_BBT_DESC_VER_OFFSET : xnandpsu_bbm.h
- XNANDPSU_BBT_ENTRY_NUM_BLOCKS : xnandpsu_bbm.h
- XNANDPSU_BBT_SCAN_2ND_PAGE : xnandpsu_bbm.h
- XNandPsu_BbtBlockShift : xnandpsu_bbm.h
- XNANDPSU_BCH : xnandpsu.h
- XNANDPSU_BLOCK_BAD : xnandpsu_bbm.h
- XNANDPSU_BLOCK_FACTORY_BAD : xnandpsu_bbm.h
- XNANDPSU_BLOCK_GOOD : xnandpsu_bbm.h
- XNANDPSU_BLOCK_RESERVED : xnandpsu_bbm.h
- XNANDPSU_BLOCK_SHIFT_MASK : xnandpsu_bbm.h
- XNANDPSU_BLOCK_TYPE_MASK : xnandpsu_bbm.h
- XNANDPSU_BUF_DATA_PORT_OFFSET : xnandpsu_hw.h
- XNandPsu_CfgInitialize() : xnandpsu.h
- XNandPsu_ChangeTimingMode() : xnandpsu.h
- XNandPsu_ClrBits : xnandpsu.h
- XNANDPSU_CMD_ADDR_CYCLES_MASK : xnandpsu_hw.h
- XNANDPSU_CMD_ADDR_CYCLES_SHIFT : xnandpsu_hw.h
- XNANDPSU_CMD_CMD1_MASK : xnandpsu_hw.h
- XNANDPSU_CMD_CMD2_MASK : xnandpsu_hw.h
- XNANDPSU_CMD_CMD2_SHIFT : xnandpsu_hw.h
- XNANDPSU_CMD_DMA_EN_MASK : xnandpsu_hw.h
- XNANDPSU_CMD_DMA_EN_SHIFT : xnandpsu_hw.h
- XNANDPSU_CMD_ECC_ON_MASK : xnandpsu_hw.h
- XNANDPSU_CMD_ECC_ON_SHIFT : xnandpsu_hw.h
- XNANDPSU_CMD_OFFSET : xnandpsu_hw.h
- XNANDPSU_CMD_PG_SIZE_MASK : xnandpsu_hw.h
- XNANDPSU_CMD_PG_SIZE_SHIFT : xnandpsu_hw.h
- XNANDPSU_CPU_REL_OFFSET : xnandpsu_hw.h
- XNANDPSU_DATA_INTF_DATA_INTF_MASK : xnandpsu_hw.h
- XNANDPSU_DATA_INTF_DATA_INTF_SHIFT : xnandpsu_hw.h
- XNANDPSU_DATA_INTF_NVDDR2_MASK : xnandpsu_hw.h
- XNANDPSU_DATA_INTF_NVDDR_MASK : xnandpsu_hw.h
- XNANDPSU_DATA_INTF_NVDDR_SHIFT : xnandpsu_hw.h
- XNANDPSU_DATA_INTF_OFFSET : xnandpsu_hw.h
- XNANDPSU_DATA_INTF_SDR_MASK : xnandpsu_hw.h
- XNandPsu_DataInterface : xnandpsu.h
- XNandPsu_DisableDmaMode() : xnandpsu.h
- XNandPsu_DisableEccMode() : xnandpsu.h
- XNANDPSU_DMA_BUF_BND_BND_MASK : xnandpsu_hw.h
- XNANDPSU_DMA_BUF_BND_OFFSET : xnandpsu_hw.h
- XNANDPSU_DMA_SYS_ADDR0_OFFSET : xnandpsu_hw.h
- XNANDPSU_DMA_SYS_ADDR1_OFFSET : xnandpsu_hw.h
- XNandPsu_DmaMode : xnandpsu.h
- XNANDPSU_ECC_ADDR_MASK : xnandpsu_hw.h
- XNANDPSU_ECC_CNT_1BIT_OFFSET : xnandpsu_hw.h
- XNANDPSU_ECC_CNT_2BIT_OFFSET : xnandpsu_hw.h
- XNANDPSU_ECC_CNT_3BIT_OFFSET : xnandpsu_hw.h
- XNANDPSU_ECC_CNT_4BIT_OFFSET : xnandpsu_hw.h
- XNANDPSU_ECC_CNT_5BIT_OFFSET : xnandpsu_hw.h
- XNANDPSU_ECC_CNT_6BIT_OFFSET : xnandpsu_hw.h
- XNANDPSU_ECC_CNT_7BIT_OFFSET : xnandpsu_hw.h
- XNANDPSU_ECC_CNT_8BIT_OFFSET : xnandpsu_hw.h
- XNANDPSU_ECC_ERR_CNT_OFFSET : xnandpsu_hw.h
- XNANDPSU_ECC_ERR_CNT_PG_BND_ERR_CNT_MASK : xnandpsu_hw.h
- XNANDPSU_ECC_ERR_CNT_PKT_BND_ERR_CNT_MASK : xnandpsu_hw.h
- XNANDPSU_ECC_HAMMING_BCH_MASK : xnandpsu_hw.h
- XNANDPSU_ECC_OFFSET : xnandpsu_hw.h
- XNANDPSU_ECC_SIZE_MASK : xnandpsu_hw.h
- XNANDPSU_ECC_SPR_CMD_ECC_ADDR_CYCLES_MASK : xnandpsu_hw.h
- XNANDPSU_ECC_SPR_CMD_OFFSET : xnandpsu_hw.h
- XNANDPSU_ECC_SPR_CMD_SPR_CMD_MASK : xnandpsu_hw.h
- XNandPsu_EccMode : xnandpsu.h
- XNandPsu_EnableDmaMode() : xnandpsu.h
- XNandPsu_EnableEccMode() : xnandpsu.h
- XNandPsu_Erase() : xnandpsu.h
- XNandPsu_EraseBlock() : xnandpsu.h
- XNANDPSU_FLASH_BLOCK_BAD : xnandpsu_bbm.h
- XNANDPSU_FLASH_BLOCK_FAC_BAD : xnandpsu_bbm.h
- XNANDPSU_FLASH_BLOCK_GOOD : xnandpsu_bbm.h
- XNANDPSU_FLASH_BLOCK_RESERVED : xnandpsu_bbm.h
- XNANDPSU_FLASH_STS_FLASH_STS_MASK : xnandpsu_hw.h
- XNANDPSU_FLASH_STS_OFFSET : xnandpsu_hw.h
- XNandPsu_GetFeature() : xnandpsu.h
- XNANDPSU_HAMMING : xnandpsu.h
- XNANDPSU_ID2_DEVICE_ID2_MASK : xnandpsu_hw.h
- XNandPsu_InitBbtDesc() : xnandpsu_bbm.h
- XNANDPSU_INTERRUPT : xnandpsu.h
- XNANDPSU_INTR_BUFF_RD_RDY_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_BUFF_WR_RDY_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_DMA_INT_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_ERR_AHB_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_ERR_INTR_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_MUL_BIT_ERR_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_SIG_EN_BUFF_RD_RDY_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_SIG_EN_BUFF_WR_RDY_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_SIG_EN_DMA_INT_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_SIG_EN_ERR_AHB_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_SIG_EN_ERR_INTR_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_SIG_EN_MUL_BIT_ERR_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_SIG_EN_OFFSET : xnandpsu_hw.h
- XNANDPSU_INTR_SIG_EN_TRANS_COMP_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_STS_BUFF_RD_RDY_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_STS_BUFF_WR_RDY_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_STS_DMA_INT_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_STS_EN_BUFF_RD_RDY_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_STS_EN_BUFF_WR_RDY_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_STS_EN_DMA_INT_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_STS_EN_ERR_AHB_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_STS_EN_ERR_INTR_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_STS_EN_MUL_BIT_ERR_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_STS_EN_OFFSET : xnandpsu_hw.h
- XNANDPSU_INTR_STS_EN_TRANS_COMP_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_STS_ERR_AHB_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_STS_ERR_INTR_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_STS_MUL_BIT_ERR_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_STS_OFFSET : xnandpsu_hw.h
- XNANDPSU_INTR_STS_TRANS_COMP_STS_EN_MASK : xnandpsu_hw.h
- XNANDPSU_INTR_TRANS_COMP_STS_EN_MASK : xnandpsu_hw.h
- XNandPsu_IntrSigClear : xnandpsu.h
- XNandPsu_IntrSigEnable : xnandpsu.h
- XNandPsu_IntrStsEnable : xnandpsu.h
- XNandPsu_IsBlockBad() : xnandpsu_bbm.h
- XNandPsu_MarkBlockBad() : xnandpsu.h
- XNANDPSU_MAX_BLOCKS : xnandpsu.h
- XNANDPSU_MAX_LUNS : xnandpsu.h
- XNANDPSU_MAX_PAGE_SIZE : xnandpsu.h
- XNANDPSU_MAX_PAGES_PER_BLOCK : xnandpsu.h
- XNANDPSU_MAX_PKT_COUNT : xnandpsu.h
- XNANDPSU_MAX_PKT_SIZE : xnandpsu.h
- XNANDPSU_MAX_SPARE_SIZE : xnandpsu.h
- XNANDPSU_MAX_TARGETS : xnandpsu.h
- XNANDPSU_MDMA : xnandpsu.h
- XNANDPSU_MEM_ADDR1_COL_ADDR_MASK : xnandpsu_hw.h
- XNANDPSU_MEM_ADDR1_OFFSET : xnandpsu_hw.h
- XNANDPSU_MEM_ADDR1_PG_ADDR_MASK : xnandpsu_hw.h
- XNANDPSU_MEM_ADDR1_PG_ADDR_SHIFT : xnandpsu_hw.h
- XNANDPSU_MEM_ADDR2_BUS_WIDTH_MASK : xnandpsu_hw.h
- XNANDPSU_MEM_ADDR2_BUS_WIDTH_SHIFT : xnandpsu_hw.h
- XNANDPSU_MEM_ADDR2_CHIP_SEL_MASK : xnandpsu_hw.h
- XNANDPSU_MEM_ADDR2_CHIP_SEL_SHIFT : xnandpsu_hw.h
- XNANDPSU_MEM_ADDR2_MEM_ADDR_MASK : xnandpsu_hw.h
- XNANDPSU_MEM_ADDR2_MODE_MASK : xnandpsu_hw.h
- XNANDPSU_MEM_ADDR2_NFC_BCH_MODE_MASK : xnandpsu_hw.h
- XNANDPSU_MEM_ADDR2_OFFSET : xnandpsu_hw.h
- XNANDPSU_NO_OOB_BBT_DESC_SIG_OFFSET : xnandpsu_bbm.h
- XNANDPSU_NO_OOB_BBT_DESC_VER_OFFSET : xnandpsu_bbm.h
- XNANDPSU_NVDDR : xnandpsu.h
- XNandPsu_OnfiParamPageCrc() : xnandpsu_onfi.h
- XNANDPSU_PAGE_SIZE_16K : xnandpsu.h
- XNANDPSU_PAGE_SIZE_1K_16BIT : xnandpsu.h
- XNANDPSU_PAGE_SIZE_2K : xnandpsu.h
- XNANDPSU_PAGE_SIZE_4K : xnandpsu.h
- XNANDPSU_PAGE_SIZE_512 : xnandpsu.h
- XNANDPSU_PAGE_SIZE_8K : xnandpsu.h
- XNANDPSU_PIO : xnandpsu.h
- XNANDPSU_PKT_OFFSET : xnandpsu_hw.h
- XNANDPSU_PKT_PKT_CNT_MASK : xnandpsu_hw.h
- XNANDPSU_PKT_PKT_CNT_SHIFT : xnandpsu_hw.h
- XNANDPSU_PKT_PKT_SIZE_MASK : xnandpsu_hw.h
- XNANDPSU_POLLING : xnandpsu.h
- XNandPsu_Prepare_Cmd() : xnandpsu.h
- XNANDPSU_PROG_BLK_ERASE_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_CHNG_RD_COL_ENH_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_CHNG_ROW_ADDR_END_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_CHNG_ROW_ADDR_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_COPY_BACK_INTRLVD_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_GET_FEATURES_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_MUL_DIE_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_MUL_DIE_RD_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_ODT_CONF_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_OFFSET : xnandpsu_hw.h
- XNANDPSU_PROG_PG_PROG_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_PGM_PG_CLR_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_RD_CACHE_END_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_RD_CACHE_RAND_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_RD_CACHE_SEQ_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_RD_CACHE_START_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_RD_ID_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_RD_INTRLVD_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_RD_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_RD_PRM_PG_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_RD_STS_ENH_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_RD_STS_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_RD_UNQ_ID_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_RST_LUN_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_RST_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_SET_FEATURES_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_SMALL_DATA_MOVE_MASK : xnandpsu_hw.h
- XNANDPSU_PROG_VOL_SEL_MASK : xnandpsu_hw.h
- XNandPsu_Read() : xnandpsu.h
- XNandPsu_ReadModifyWrite : xnandpsu.h
- XNandPsu_ReadReg : xnandpsu_hw.h
- XNandPsu_ReadSpareBytes() : xnandpsu.h
- XNANDPSU_READY_BUSY_OFFSET : xnandpsu_hw.h
- XNandPsu_ScanBbt() : xnandpsu.h
- XNANDPSU_SDMA : xnandpsu.h
- XNANDPSU_SDR : xnandpsu.h
- XNandPsu_SetBits : xnandpsu.h
- XNandPsu_SetFeature() : xnandpsu.h
- XNANDPSU_SLV_DMA_CONF_DMA_BURST_SIZE_MASK : xnandpsu_hw.h
- XNANDPSU_SLV_DMA_CONF_DMA_TMOUT_CNT_VAL_MASK : xnandpsu_hw.h
- XNANDPSU_SLV_DMA_CONF_DMA_TRANS_CNT_MASK : xnandpsu_hw.h
- XNANDPSU_SLV_DMA_CONF_OFFSET : xnandpsu_hw.h
- XNANDPSU_SLV_DMA_CONF_SDMA_EN_MASK : xnandpsu_hw.h
- XNANDPSU_SLV_DMA_CONF_SDMA_TX_RX_MASK : xnandpsu_hw.h
- XNandPsu_SWMode : xnandpsu.h
- XNANDPSU_TIMING_DQS_BUFF_SEL_MASK : xnandpsu_hw.h
- XNANDPSU_TIMING_OFFSET : xnandpsu_hw.h
- XNANDPSU_TIMING_SLOW_FAST_TCAD_MASK : xnandpsu_hw.h
- XNANDPSU_TIMING_TADL_TIME_MASK : xnandpsu_hw.h
- XNANDPSU_TIMING_TCCS_TIME_MASK : xnandpsu_hw.h
- XNandPsu_TimingMode : xnandpsu.h
- XNandPsu_Write() : xnandpsu.h
- XNandPsu_WriteReg : xnandpsu_hw.h
- XNandPsu_WriteSpareBytes() : xnandpsu.h
- xPSR_C_Msk : core_cm4.h, core_cm7.h
- xPSR_C_Pos : core_cm4.h, core_cm7.h
- xPSR_GE_Msk : core_cm4.h, core_cm7.h
- xPSR_GE_Pos : core_cm4.h, core_cm7.h
- xPSR_ICI_IT_1_Msk : core_cm4.h, core_cm7.h
- xPSR_ICI_IT_1_Pos : core_cm4.h, core_cm7.h
- xPSR_ICI_IT_2_Msk : core_cm4.h, core_cm7.h
- xPSR_ICI_IT_2_Pos : core_cm4.h, core_cm7.h
- xPSR_ISR_Msk : core_cm4.h, core_cm7.h
- xPSR_ISR_Pos : core_cm4.h, core_cm7.h
- xPSR_N_Msk : core_cm4.h, core_cm7.h
- xPSR_N_Pos : core_cm4.h, core_cm7.h
- xPSR_Q_Msk : core_cm4.h, core_cm7.h
- xPSR_Q_Pos : core_cm4.h, core_cm7.h
- xPSR_T_Msk : core_cm4.h, core_cm7.h
- xPSR_T_Pos : core_cm4.h, core_cm7.h
- xPSR_V_Msk : core_cm4.h, core_cm7.h
- xPSR_V_Pos : core_cm4.h, core_cm7.h
- xPSR_Z_Msk : core_cm4.h, core_cm7.h
- xPSR_Z_Pos : core_cm4.h, core_cm7.h
- XQSPIPS_BASEADDR : xqspipsu_hw.h
- XQSPIPS_EN_REG : xqspipsu_hw.h
- XQSPIPS_LQSPI_CFG_RST_STATE : xqspipsu_hw.h
- XQSPIPS_LQSPI_CR_4_BYTE_STATE : xqspipsu_hw.h
- XQSPIPS_LQSPI_CR_INST_MASK : xqspipsu_hw.h
- XQSPIPS_LQSPI_CR_RST_STATE : xqspipsu_hw.h
- XQspiPsu_Abort() : xqspipsu.h
- XQSPIPSU_CFG_OFFSET : xqspipsu_hw.h
- XQspiPsu_CfgInitialize() : xqspipsu.h
- XQspiPsu_CheckDmaDone() : xqspipsu.h
- XQspiPsu_ClearOptions() : xqspipsu.h
- XQSPIPSU_CLK_ACTIVE_LOW_OPTION : xqspipsu.h
- XQSPIPSU_CLK_PHASE_1_OPTION : xqspipsu.h
- XQSPIPSU_CLK_PRESCALE_128 : xqspipsu.h
- XQSPIPSU_CLK_PRESCALE_16 : xqspipsu.h
- XQSPIPSU_CLK_PRESCALE_2 : xqspipsu.h
- XQSPIPSU_CLK_PRESCALE_256 : xqspipsu.h
- XQSPIPSU_CLK_PRESCALE_32 : xqspipsu.h
- XQSPIPSU_CLK_PRESCALE_4 : xqspipsu.h
- XQSPIPSU_CLK_PRESCALE_64 : xqspipsu.h
- XQSPIPSU_CLK_PRESCALE_8 : xqspipsu.h
- XQspiPsu_ConfigTable : xqspipsu.h
- XQSPIPSU_CONNECTION_MODE_PARALLEL : xqspipsu.h
- XQSPIPSU_CONNECTION_MODE_SINGLE : xqspipsu.h
- XQSPIPSU_CONNECTION_MODE_STACKED : xqspipsu.h
- XQSPIPSU_CR_PRESC_MAXIMUM : xqspipsu.h
- XQspiPsu_CreatePollDataConfig() : xqspipsu_hw.c
- XQSPIPSU_DATA_DLY_ADJ_OFFSET : xqspipsu_hw.h
- XQspiPsu_Disable : xqspipsu.h
- XQSPIPSU_DMA_BYTES_MAX : xqspipsu.h
- XQSPIPSU_EN_OFFSET : xqspipsu_hw.h
- XQspiPsu_Enable : xqspipsu.h
- XQSPIPSU_FIFO_CTRL_OFFSET : xqspipsu_hw.h
- XQspiPsu_FillTxFifo() : xqspipsu_hw.c
- XQSPIPSU_FREQ_100MHZ : xqspipsu.h
- XQSPIPSU_FREQ_150MHZ : xqspipsu.h
- XQSPIPSU_FREQ_37_5MHZ : xqspipsu.h
- XQSPIPSU_FREQ_40MHZ : xqspipsu.h
- XQSPIPSU_GEN_FIFO_OFFSET : xqspipsu_hw.h
- XQSPIPSU_GENFIFO_CS_HOLD : xqspipsu.h
- XQSPIPSU_GENFIFO_CS_SETUP : xqspipsu.h
- XQSPIPSU_GENFIFO_EXP_START : xqspipsu.h
- XQSPIPSU_GENFIFO_IMM_DATA_MASK : xqspipsu_hw.h
- XQspiPsu_GenFifoEntryData() : xqspipsu_control.c
- XQspiPsu_GenFifoEntryDataLen() : xqspipsu_hw.c
- XQspiPsu_GetLqspiConfigReg : xqspipsu.h
- XQspiPsu_GetOptions() : xqspipsu.h
- XQSPIPSU_GF_SNAPSHOT_OFFSET : xqspipsu_hw.h
- XQSPIPSU_GF_THRESHOLD_OFFSET : xqspipsu_hw.h
- XQSPIPSU_GPIO_OFFSET : xqspipsu_hw.h
- XQSPIPSU_H_ : xqspipsu.h
- XQSPIPSU_HW_H : xqspipsu_hw.h
- XQspiPsu_Idle() : xqspipsu.h
- XQSPIPSU_IDR_OFFSET : xqspipsu_hw.h
- XQSPIPSU_IER_OFFSET : xqspipsu_hw.h
- XQSPIPSU_IMR_OFFSET : xqspipsu_hw.h
- XQspiPsu_In32 : xqspipsu_hw.h
- XQspiPsu_InterruptHandler() : xqspipsu.h
- XQspiPsu_InterruptTransfer() : xqspipsu.h
- XQspiPsu_IORead() : xqspipsu_hw.c
- XQSPIPSU_ISR_OFFSET : xqspipsu_hw.h
- XQSPIPSU_LPBK_DLY_ADJ_OFFSET : xqspipsu_hw.h
- XQSPIPSU_LQSPI_CR_ADDR_32BIT_MASK : xqspipsu_hw.h
- XQSPIPSU_LQSPI_CR_LINEAR_MASK : xqspipsu_hw.h
- XQSPIPSU_LQSPI_CR_MODE_BITS_MASK : xqspipsu_hw.h
- XQSPIPSU_LQSPI_CR_MODE_EN_MASK : xqspipsu_hw.h
- XQSPIPSU_LQSPI_CR_MODE_ON_MASK : xqspipsu_hw.h
- XQSPIPSU_LQSPI_CR_OFFSET : xqspipsu_hw.h
- XQSPIPSU_LQSPI_CR_SEP_BUS_MASK : xqspipsu_hw.h
- XQSPIPSU_LQSPI_CR_TWO_MEM_MASK : xqspipsu_hw.h
- XQSPIPSU_LQSPI_CR_U_PAGE_MASK : xqspipsu_hw.h
- XQSPIPSU_LQSPI_LESS_THEN_SIXTEENMB : xqspipsu.h
- XQSPIPSU_LQSPI_MODE_OPTION : xqspipsu.h
- XQSPIPSU_MANUAL_START_OPTION : xqspipsu.h
- XQSPIPSU_MOD_ID_OFFSET : xqspipsu_hw.h
- XQSPIPSU_MSG_FLAG_POLL : xqspipsu.h
- XQSPIPSU_MSG_FLAG_RX : xqspipsu.h
- XQSPIPSU_MSG_FLAG_STRIPE : xqspipsu.h
- XQSPIPSU_MSG_FLAG_TX : xqspipsu.h
- XQSPIPSU_NUM_OPTIONS : xqspipsu_options.c
- XQspiPsu_Out32 : xqspipsu_hw.h
- XQSPIPSU_POLL_CFG_OFFSET : xqspipsu_hw.h
- XQspiPsu_PollDataConfig() : xqspipsu_control.c
- XQspiPsu_PollDataHandler() : xqspipsu.c
- XQspiPsu_PolledTransfer() : xqspipsu.h
- XQSPIPSU_QSPIDMA_DST_ADDR_OFFSET : xqspipsu_hw.h
- XQSPIPSU_READMODE_DMA : xqspipsu.h
- XQSPIPSU_READMODE_IO : xqspipsu.h
- XQspiPsu_ReadReg : xqspipsu_hw.h
- XQspiPsu_ReadRxFifo() : xqspipsu_hw.c
- XQspiPsu_Reset() : xqspipsu.h
- XQSPIPSU_RX_COPY_OFFSET : xqspipsu_hw.h
- XQSPIPSU_RXADDR_OVER_32BIT : xqspipsu.h
- XQSPIPSU_RXD_OFFSET : xqspipsu_hw.h
- XQspiPsu_RXSetup() : xqspipsu_hw.c
- XQSPIPSU_SEL_OFFSET : xqspipsu_hw.h
- XQspiPsu_Select : xqspipsu.h
- XQSPIPSU_SELECT_FLASH_BUS_BOTH : xqspipsu.h
- XQSPIPSU_SELECT_FLASH_BUS_LOWER : xqspipsu.h
- XQSPIPSU_SELECT_FLASH_BUS_UPPER : xqspipsu.h
- XQSPIPSU_SELECT_FLASH_CS_BOTH : xqspipsu.h
- XQSPIPSU_SELECT_FLASH_CS_LOWER : xqspipsu.h
- XQSPIPSU_SELECT_FLASH_CS_UPPER : xqspipsu.h
- XQSPIPSU_SELECT_MODE_DUALSPI : xqspipsu.h
- XQSPIPSU_SELECT_MODE_QUADSPI : xqspipsu.h
- XQSPIPSU_SELECT_MODE_SPI : xqspipsu.h
- XQspiPsu_SelectFlash() : xqspipsu.h
- XQspiPsu_SelectSpiMode() : xqspipsu_hw.c
- XQSPIPSU_SET_WP : xqspipsu.h
- XQspiPsu_SetClkPrescaler() : xqspipsu.h
- XQspiPsu_SetDefaultConfig() : xqspipsu_hw.c
- XQspiPsu_SetIOMode() : xqspipsu_hw.c
- XQspiPsu_SetOptions() : xqspipsu.h
- XQspiPsu_SetReadMode() : xqspipsu.h
- XQspiPsu_SetStatusHandler() : xqspipsu.h
- XQspiPsu_Setup64BRxDma() : xqspipsu_hw.c
- XQspiPsu_SetupRxDma() : xqspipsu_hw.c
- XQspiPsu_SetWP() : xqspipsu.h
- XQspiPsu_StartDmaTransfer() : xqspipsu.h
- XQspiPsu_StatusHandler : xqspipsu.h
- XQSPIPSU_TX_THRESHOLD_OFFSET : xqspipsu_hw.h
- XQSPIPSU_TXD_OFFSET : xqspipsu_hw.h
- XQspiPsu_TXRXSetup() : xqspipsu_hw.c
- XQspiPsu_TXSetup() : xqspipsu_hw.c
- XQspiPsu_WriteProtectToggle() : xqspipsu.h
- XQspiPsu_WriteReg : xqspipsu_hw.h
- XQSPIPSU_XFER_STS_OFFSET : xqspipsu_hw.h
- XRDC2_BASE_ADDRS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_BASE_PTRS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_D0 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_D0_BASE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_D1 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_D1_BASE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- xrdc2_master_t : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MCR_GCL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MCR_GVLDC : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MCR_GVLDM : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MDAC_MDA_W0_MASK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MDAC_MDA_W0_MATCH : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MDAC_MDA_W1_DID : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MDAC_MDA_W1_DL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MDAC_MDA_W1_PA : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MDAC_MDA_W1_SA : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MDAC_MDA_W1_VLD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W0_SRTADDR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W1_SRTADDR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W2_ENDADDR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W3_ENDADDR : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W5_D0ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W5_D1ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W5_D2ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W5_D3ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W5_D4ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W5_D5ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W5_D6ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W5_D7ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W5_EALO : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W6_D10ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W6_D11ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W6_D12ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W6_D13ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W6_D14ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W6_D15ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W6_D8ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W6_D9ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W6_DL2 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W6_EAL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MRC_MRGD_W6_VLD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W0_D0ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W0_D1ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W0_D2ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W0_D3ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W0_D4ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W0_D5ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W0_D6ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W0_D7ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W0_EALO : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W1_D10ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W1_D11ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W1_D12ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W1_D13ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W1_D14ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W1_D15ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W1_D8ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W1_D9ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W1_DL2 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W1_EAL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_MSC_MSAC_W1_VLD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W0_D0ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W0_D1ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W0_D2ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W0_D3ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W0_D4ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W0_D5ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W0_D6ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W0_D7ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W0_EALO : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W1_D10ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W1_D11ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W1_D12ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W1_D13ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W1_D14ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W1_D15ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W1_D8ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W1_D9ACP : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W1_DL2 : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W1_EAL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_PAC_PDAC_W1_VLD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_SR_DIN : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_SR_GCLO : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XRDC2_SR_HRL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- XTALOSC24M : MIMXRT1052.h
- XTALOSC24M_BASE : MIMXRT1052.h
- XTALOSC24M_BASE_ADDRS : MIMXRT1052.h
- XTALOSC24M_BASE_PTRS : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_CLR_LPBG_SEL : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_CLR_OSC_SEL : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_CLR_RC_OSC_EN : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_DELAY : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_STAT : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_LPBG_SEL : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_OSC_SEL : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_RC_OSC_EN : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_SET_LPBG_SEL : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_SET_OSC_SEL : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_SET_RC_OSC_EN : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_DELAY : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_STAT : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_TOG_LPBG_SEL : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_TOG_OSC_SEL : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_TOG_RC_OSC_EN : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_DELAY : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_STAT : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_DELAY : MIMXRT1052.h
- XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_STAT : MIMXRT1052.h
- XTALOSC24M_MISC0_CLKGATE_CTRL : MIMXRT1052.h
- XTALOSC24M_MISC0_CLKGATE_DELAY : MIMXRT1052.h
- XTALOSC24M_MISC0_CLR_CLKGATE_CTRL : MIMXRT1052.h
- XTALOSC24M_MISC0_CLR_CLKGATE_DELAY : MIMXRT1052.h
- XTALOSC24M_MISC0_CLR_DISCON_HIGH_SNVS : MIMXRT1052.h
- XTALOSC24M_MISC0_CLR_OSC_I : MIMXRT1052.h
- XTALOSC24M_MISC0_CLR_REFTOP_SELFBIASOFF : MIMXRT1052.h
- XTALOSC24M_MISC0_CLR_REFTOP_VBGADJ : MIMXRT1052.h
- XTALOSC24M_MISC0_CLR_RTC_XTAL_SOURCE : MIMXRT1052.h
- XTALOSC24M_MISC0_CLR_STOP_MODE_CONFIG : MIMXRT1052.h
- XTALOSC24M_MISC0_CLR_VID_PLL_PREDIV : MIMXRT1052.h
- XTALOSC24M_MISC0_DISCON_HIGH_SNVS : MIMXRT1052.h
- XTALOSC24M_MISC0_OSC_I : MIMXRT1052.h
- XTALOSC24M_MISC0_REFTOP_SELFBIASOFF : MIMXRT1052.h
- XTALOSC24M_MISC0_REFTOP_VBGADJ : MIMXRT1052.h
- XTALOSC24M_MISC0_RTC_XTAL_SOURCE : MIMXRT1052.h
- XTALOSC24M_MISC0_SET_CLKGATE_CTRL : MIMXRT1052.h
- XTALOSC24M_MISC0_SET_CLKGATE_DELAY : MIMXRT1052.h
- XTALOSC24M_MISC0_SET_DISCON_HIGH_SNVS : MIMXRT1052.h
- XTALOSC24M_MISC0_SET_OSC_I : MIMXRT1052.h
- XTALOSC24M_MISC0_SET_REFTOP_SELFBIASOFF : MIMXRT1052.h
- XTALOSC24M_MISC0_SET_REFTOP_VBGADJ : MIMXRT1052.h
- XTALOSC24M_MISC0_SET_RTC_XTAL_SOURCE : MIMXRT1052.h
- XTALOSC24M_MISC0_SET_STOP_MODE_CONFIG : MIMXRT1052.h
- XTALOSC24M_MISC0_SET_VID_PLL_PREDIV : MIMXRT1052.h
- XTALOSC24M_MISC0_STOP_MODE_CONFIG : MIMXRT1052.h
- XTALOSC24M_MISC0_TOG_CLKGATE_CTRL : MIMXRT1052.h
- XTALOSC24M_MISC0_TOG_CLKGATE_DELAY : MIMXRT1052.h
- XTALOSC24M_MISC0_TOG_DISCON_HIGH_SNVS : MIMXRT1052.h
- XTALOSC24M_MISC0_TOG_OSC_I : MIMXRT1052.h
- XTALOSC24M_MISC0_TOG_REFTOP_SELFBIASOFF : MIMXRT1052.h
- XTALOSC24M_MISC0_TOG_REFTOP_VBGADJ : MIMXRT1052.h
- XTALOSC24M_MISC0_TOG_RTC_XTAL_SOURCE : MIMXRT1052.h
- XTALOSC24M_MISC0_TOG_STOP_MODE_CONFIG : MIMXRT1052.h
- XTALOSC24M_MISC0_TOG_VID_PLL_PREDIV : MIMXRT1052.h
- XTALOSC24M_MISC0_VID_PLL_PREDIV : MIMXRT1052.h
- XTTCPS_CLK_CNTRL_EXT_EDGE_MASK : xttcps_hw.h
- XTTCPS_CLK_CNTRL_OFFSET : xttcps_hw.h
- XTTCPS_CLK_CNTRL_PS_DISABLE : xttcps_hw.h
- XTTCPS_CLK_CNTRL_PS_EN_MASK : xttcps_hw.h
- XTTCPS_CLK_CNTRL_PS_VAL_MASK : xttcps_hw.h
- XTTCPS_CLK_CNTRL_PS_VAL_SHIFT : xttcps_hw.h
- XTTCPS_CLK_CNTRL_SRC_MASK : xttcps_hw.h
- XTTCPS_CNT_CNTRL_DECR_MASK : xttcps_hw.h
- XTTCPS_CNT_CNTRL_DIS_MASK : xttcps_hw.h
- XTTCPS_CNT_CNTRL_EN_WAVE_MASK : xttcps_hw.h
- XTTCPS_CNT_CNTRL_INT_MASK : xttcps_hw.h
- XTTCPS_CNT_CNTRL_MATCH_MASK : xttcps_hw.h
- XTTCPS_CNT_CNTRL_OFFSET : xttcps_hw.h
- XTTCPS_CNT_CNTRL_POL_WAVE_MASK : xttcps_hw.h
- XTTCPS_CNT_CNTRL_RESET_VALUE : xttcps_hw.h
- XTTCPS_CNT_CNTRL_RST_MASK : xttcps_hw.h
- XTTCPS_COUNT_VALUE_MASK : xttcps_hw.h
- XTTCPS_COUNT_VALUE_OFFSET : xttcps_hw.h
- XTTCPS_IER_OFFSET : xttcps_hw.h
- XTTCPS_INTERVAL_VAL_MASK : xttcps_hw.h
- XTTCPS_INTERVAL_VAL_OFFSET : xttcps_hw.h
- XTTCPS_ISR_OFFSET : xttcps_hw.h
- XTTCPS_IXR_ALL_MASK : xttcps_hw.h
- XTTCPS_IXR_CNT_OVR_MASK : xttcps_hw.h
- XTTCPS_IXR_INTERVAL_MASK : xttcps_hw.h
- XTTCPS_IXR_MATCH_0_MASK : xttcps_hw.h
- XTTCPS_IXR_MATCH_1_MASK : xttcps_hw.h
- XTTCPS_IXR_MATCH_2_MASK : xttcps_hw.h
- XTTCPS_MATCH_0_OFFSET : xttcps_hw.h
- XTTCPS_MATCH_1_OFFSET : xttcps_hw.h
- XTTCPS_MATCH_2_OFFSET : xttcps_hw.h
- XTTCPS_MATCH_MASK : xttcps_hw.h
- XTtcPs_Match_N_Offset : xttcps_hw.h
- XTTCPS_NUM_MATCH_REG : xttcps_hw.h
- XTtcPs_ReadReg : xttcps_hw.h
- XTtcPs_WriteReg : xttcps_hw.h
