RTEMS 6.1-rc4
Files | Data Structures | Macros | Functions
Shared_tod_mcp7940m_rtc
RTC driver for the MCP7940M. More...
file  mcp7940m-rtc.h
 This file provides the interfaces of Shared_tod_mcp7940m_rtc.
file  mcp7940m.c
struct  mcp7940m_rtc
#define MCP7940M_RTC_INITIALIZER(i2c_path, i2c_address, has_crystal)
#define MCP7940M_RTC_TBL_ENTRY(dev_name, mcp7940m_rtc_ctx)    I2C_RTC_TBL_ENTRY(dev_name, mcp7940m_rtc_ctx)
int mcp7940m_hw_init (struct i2c_rtc_base *base)
To use this driver, use the following initialization:
Define a context for the RTC somewhere:
static struct mcp7940m_rtc rtc_ctx = MCP7940M_RTC_INITIALIZER("/dev/i2c-1", 0x6F, true);
Then you can use the following for the RTC_Table:
MCP7940M_RTC_TBL_ENTRY("/dev/rtc", &rtc_ctx)
◆ MCP7940M_RTC_INITIALIZER
#define MCP7940M_RTC_INITIALIZER (   i2c_path,
  i2c_address,
  has_crystal
Value:
.base = I2C_RTC_INITIALIZER( \
i2c_path, \
i2c_address, \
0, \
I2C_RTC_ORDER_sec_min_hour_wkday_day_month_year, \
"mcp7940", \
.crystal = has_crystal, \
int mcp7940m_hw_init(struct i2c_rtc_base *base)
Definition: mcp7940m.c:68
◆ mcp7940m_hw_init()
int mcp7940m_hw_init ( struct i2c_rtc_base base)
Hardware init. Used internally.
