RTEMS 6.1-rc4
i2c_rtc_base Struct Reference
#include <i2c-rtc.h>
rtems_mutex mutex
const char * i2c_bus_path
uint8_t i2c_addr
bool initialized
int(* hw_init )(struct i2c_rtc_base *ctx)
size_t clock_offset
struct {
   size_t   year
   size_t   month
   size_t   wkday
   size_t   day
   size_t   hour
   size_t   min
   size_t   sec
order
Base context for the driver.
Field Documentation
◆ clock_offset
size_t i2c_rtc_base::clock_offset
Offset of the start of the clock register block.
◆ hw_init
int(* i2c_rtc_base::hw_init) (struct i2c_rtc_base *ctx)
Hardware initialization function. Will be called once when the RTC is used for the first time. Can return 0 on success or anything else on error. In an error case, it will be called again on the next use.
◆ i2c_addr
uint8_t i2c_rtc_base::i2c_addr
I2C address.
◆ i2c_bus_path
const char* i2c_rtc_base::i2c_bus_path
The path of the I2C bus device.
◆ initialized
bool i2c_rtc_base::initialized
Whether the RTC has already been initialized. Used internally.
◆ mutex
rtems_mutex i2c_rtc_base::mutex
Just initialize with RTEMS_MUTEX_INITIALIZER('mcp7940').
struct { ... } i2c_rtc_base::order
Order of the fields of the date.
