RTEMS 6.1-rc4
Modules | Files | Data Structures | Macros | Functions | Variables
Shared_tod_i2c_rtc
Generic I2C RTC driver. More...
 Shared_tod_abeoz9_rtc
 RTC driver for the Abracon EOZ9 series.
 Shared_tod_mcp7940m_rtc
 RTC driver for the MCP7940M.
file  i2c-rtc.h
 This file provides the interfaces of Shared_tod_i2c_rtc.
file  i2c-rtc.c
 This file provides the implementation of Shared_tod_i2c_rtc.
struct  i2c_rtc_base
#define I2C_RTC_ORDER_sec_min_hour_wkday_day_month_year    { .sec = 0, .min = 1, .hour = 2, .day = 4, .wkday = 3, .month = 5, .year = 6 }
#define I2C_RTC_ORDER_sec_min_hour_day_wkday_month_year    { .sec = 0, .min = 1, .hour = 2, .day = 3, .wkday = 4, .month = 5, .year = 6 }
#define I2C_RTC_INITIALIZER(i2c_path, i2c_address, offset, reg_order, driver_name, hwinit)
#define I2C_RTC_TBL_ENTRY(dev_name, i2c_rtc_ctx)
bool i2c_rtc_probe (int minor)
int i2c_rtc_read (struct i2c_rtc_base *ctx, uint8_t addr, uint8_t *buf, size_t len)
int i2c_rtc_write (struct i2c_rtc_base *ctx, uint8_t addr, const uint8_t *buf, size_t len)
const rtc_fns i2c_rtc_fns
Base functionality for I2C based RTC drivers. An additional, chip specific initialization is necessary.
Expects a register block with the following time format:
See abeoz9 or mcp7940m for how to use this base driver.
◆ I2C_RTC_INITIALIZER
#define I2C_RTC_INITIALIZER (   i2c_path,
  i2c_address,
  offset,
  reg_order,
  driver_name,
  hwinit
Value:
.mutex = RTEMS_MUTEX_INITIALIZER(driver_name), \
.i2c_bus_path = i2c_path, \
.i2c_addr = i2c_address, \
.initialized = false, \
.hw_init = hwinit, \
.clock_offset = offset, \
.order = reg_order, \
◆ I2C_RTC_TBL_ENTRY
#define I2C_RTC_TBL_ENTRY (   dev_name,
  i2c_rtc_ctx
Value:
.sDeviceName = dev_name, \
.deviceType = RTC_CUSTOM, \
.pDeviceFns = &i2c_rtc_fns, \
.deviceProbe = i2c_rtc_probe, \
.pDeviceParams = (void *)i2c_rtc_ctx, \
.ulCtrlPort1 = 0, \
.ulDataPort = 0, \
.getRegister = NULL, \
.setRegister = NULL, \
◆ i2c_rtc_read()
int i2c_rtc_read ( struct i2c_rtc_base ctx,
uint8_t  addr,
uint8_t *  buf,
size_t  len
Read bytes from the I2C RTC. Can be used in derived drivers.
Returns 0 on success or anything else on error.
◆ i2c_rtc_write()
int i2c_rtc_write ( struct i2c_rtc_base ctx,
uint8_t  addr,
const uint8_t *  buf,
size_t  len
Write bytes to the I2C RTC. Can be used in derived drivers.
