RTEMS 6.1-rc4
Files | Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
Watchdog Handler
This group contains the Watchdog Handler implementation. More...
file  watchdog.h
 This header file provides interfaces of the Watchdog Handler which are used by the implementation and the Application Configuration.
file  watchdogimpl.h
 This header file provides interfaces of the Watchdog Handler which are only used by the implementation.
file  watchdogticks.h
 This header file provides the interfaces of the Watchdog Handler related to watchdog ticks which are used by the implementation and the Application Configuration.
file  watchdoginsert.c
 This source file contains the implementation of _Watchdog_Insert().
file  watchdogremove.c
 This source file contains the implementation of _Watchdog_Remove().
file  watchdogtick.c
 This source file contains the implementation of _Watchdog_Do_tickle() and _Watchdog_Tick().
file  watchdogtickssinceboot.c
 This source file contains the definition of _Watchdog_Ticks_since_boot.
file  watchdogtimeslicedefault.c
 This source file contains the default definition of _Watchdog_Ticks_per_timeslice.
struct  Watchdog_Header
 The watchdog header to manage scheduled watchdogs. More...
struct  Watchdog_Control
 The control block used to manage each watchdog timer. More...
#define WATCHDOG_INITIALIZER(routine)
 Watchdog initializer for static initialization.
#define _Watchdog_Tickle(header, first, now, lock, lock_context)    _Watchdog_Do_tickle( header, first, now, lock_context )
#define WATCHDOG_MAXIMUM_TICKS   UINT64_MAX
 The maximum watchdog ticks value for the far future.
#define WATCHDOG_NANOSECONDS_PER_SECOND   1000000000
#define WATCHDOG_BITS_FOR_1E9_NANOSECONDS   30
 The bits necessary to store 1000000000 (= WATCHDOG_NANOSECONDS_PER_SECOND) nanoseconds.
#define WATCHDOG_MAX_SECONDS   0x3ffffffff
 The maximum number of seconds representable in the nanoseconds watchdog format.
#define WATCHDOG_NO_TIMEOUT   0
 Special watchdog ticks value to indicate an infinite wait.
#define WATCHDOG_TICKS_PER_TIMESLICE_DEFAULT   50
 Default value for the watchdog ticks per timeslice.
typedef struct Watchdog_Control Watchdog_Control
typedef void Watchdog_Service_routine
 Return type from a Watchdog Service Routine.
typedef Watchdog_Service_routine(* Watchdog_Service_routine_entry) (Watchdog_Control *)
 Pointer to a watchdog service routine.
typedef uint32_t Watchdog_Interval
 Type is used to specify the length of intervals.
enum  Watchdog_State { WATCHDOG_SCHEDULED_BLACK , WATCHDOG_SCHEDULED_RED , WATCHDOG_INACTIVE , WATCHDOG_PENDING }
 Watchdog states. More...
void _Watchdog_Tick (struct Per_CPU_Control *cpu)
 Performs a watchdog tick.
void _Watchdog_Do_tickle (Watchdog_Header *header, Watchdog_Control *first, uint64_t now, ISR_lock_Context *lock_context)
 Calls the routine of each not expired watchdog control node.
void _Watchdog_Insert (Watchdog_Header *header, Watchdog_Control *the_watchdog, uint64_t expire)
 Inserts a watchdog into the set of scheduled watchdogs according to the specified expiration time.
void _Watchdog_Remove (Watchdog_Header *header, Watchdog_Control *the_watchdog)
 In the case the watchdog is scheduled, then it is removed from the set of scheduled watchdogs.
volatile Watchdog_Interval _Watchdog_Ticks_since_boot
 The watchdog ticks counter.
const uint32_t _Watchdog_Microseconds_per_tick
 The watchdog microseconds per tick.
const uint32_t _Watchdog_Nanoseconds_per_tick
 The watchdog nanoseconds per tick.
const uint32_t _Watchdog_Ticks_per_second
 The watchdog ticks per second.
const uint32_t _Watchdog_Ticks_per_timeslice
 The watchdog ticks per timeslice.
This handler encapsulates functionality related to the scheduling of watchdog functions to be called at specific times in the future. It provides mechanisms which can be used to initialize and manipulate watchdog timers.
Note
This handler does not have anything to do with hardware watchdog timers.
◆ WATCHDOG_BITS_FOR_1E9_NANOSECONDS
The expiration time is an unsigned 64-bit integer. To store nanoseconds timeouts we use 30 bits (2**30 == 1073741824) for the nanoseconds and 34 bits for the seconds since UNIX Epoch. This leads to a year 2514 problem.
◆ WATCHDOG_INITIALIZER
#define WATCHDOG_INITIALIZER (   routine)
Value:
{ { { NULL, NULL, NULL, WATCHDOG_INACTIVE } } }, \
( routine ), \
0 \
@ WATCHDOG_INACTIVE
The watchdog is inactive.
Definition: watchdogimpl.h:78
The processor of this watchdog is set to processor with index zero.
See also
_Watchdog_Preinitialize().
◆ WATCHDOG_MAX_SECONDS
We have 2**34 bits for the seconds part.
Typedef Documentation
◆ Watchdog_Interval
This type is used to specify the length of intervals.
◆ Watchdog_Service_routine
This type defines the return type from a Watchdog Service Routine.
◆ Watchdog_Service_routine_entry
This type define a pointer to a watchdog service routine.
◆ Watchdog_State
Watchdog states.
The watchdog is scheduled and a black node in the red-black tree.
The watchdog is scheduled and a red node in the red-black tree.
WATCHDOG_INACTIVE
WATCHDOG_PENDING
The watchdog is on a chain of pending watchdogs.
This state is used by the timer server for example.
◆ _Watchdog_Do_tickle()
void _Watchdog_Do_tickle ( Watchdog_Header header,
Watchdog_Control first,
uint64_t  now,
ISR_lock_Context lock_context
Parameters
headerThe watchdog header.
firstThe first watchdog control node.
nowThe current time to check the expiration time against.
lockThe lock that is released before calling the routine and then acquired after the call.
lock_contextThe lock context for the release before calling the routine and for the acquire after.
◆ _Watchdog_Insert()
void _Watchdog_Insert ( Watchdog_Header header,
Watchdog_Control the_watchdog,
uint64_t  expire
The watchdog must be inactive.
Parameters
[in,out]headerThe set of scheduler watchdogs to insert into.
[in,out]the_watchdogThe watchdog to insert.
expireThe expiration time for the watchdog.
◆ _Watchdog_Remove()
void _Watchdog_Remove ( Watchdog_Header header,
The watchdog must be initialized before this call.
Parameters
[in,out]headerThe scheduled watchdogs.
[in,out]the_watchdogThe watchdog to remove.
◆ _Watchdog_Tick()
void _Watchdog_Tick ( struct Per_CPU_Control cpu)
Parameters
cpuThe processor for this watchdog tick.
Variable Documentation
◆ _Watchdog_Microseconds_per_tick
extern
This constant is defined by the application configuration via <rtems/confdefs.h>.
◆ _Watchdog_Nanoseconds_per_tick
extern
◆ _Watchdog_Ticks_per_second
extern
◆ _Watchdog_Ticks_per_timeslice
extern
◆ _Watchdog_Ticks_since_boot
extern
With a 1ms watchdog tick, this counter overflows after 50 days since boot.
