RTEMS 6.1-rc4
Files | Macros | Typedefs | Functions | Variables
Timecounter Handler
This group contains the Timecounter Handler implementation. More...
file  _timecounter.h
 This header file provides timecounter definitions for the kernel space (_KERNEL is defined before including <sys/time.h>) and RTEMS.
file  timecounter.h
 This header file provides interfaces of the Timecounter Handler which are used by the implementation and the API.
file  timecounterimpl.h
 This header file provides interfaces of the Timecounter Handler which are only used by the implementation.
file  _ffcounter.h
 This header file provides interfaces of the feed-forward clock counter.
file  timeffc.h
 This header file provides interfaces of the feed-back and feed-forward clock implementations.
file  timepps.h
 This header file provides interfaces of the Pulse Per Second (PPS) support.
file  timetc.h
 This header file provides interfaces of the timecounter implementation.
file  timex.h
 This header file provides interfaces of the Network Time Protocol (NTP) support.
file  kern_ntptime.c
 This source file contains the implementation of ntp_gettime(), ntp_adjtime(), adjtime(), and _Timecounter_NTP_update_second().
file  kern_tc.c
 This source file contains the definition of _Timecounter, _Timecounter_Time_second, and _Timecounter_Time_uptime and the implementation of _Timecounter_Set_NTP_update_second(), _Timecounter_Binuptime(), _Timecounter_Nanouptime(), _Timecounter_Microuptime(), _Timecounter_Bintime(), _Timecounter_Nanotime(), _Timecounter_Microtime(), _Timecounter_Getbinuptime(), _Timecounter_Getnanouptime(), _Timecounter_Getmicrouptime(), _Timecounter_Getbintime(), _Timecounter_Getnanotime(), _Timecounter_Getmicrotime(), _Timecounter_Getboottime(), _Timecounter_Getboottimebin(), and _Timecounter_Install().
file  opt_compat.h
 This header file is provided for FreeBSD compatibility.
file  opt_ffclock.h
file  opt_ntp.h
#define _Timecounter_Acquire(lock_context)    _ISR_lock_ISR_disable_and_acquire( &_Timecounter_Lock, lock_context )
 Acquires the timecounter lock.
#define _Timecounter_Release(lock_context)    _ISR_lock_Release_and_ISR_enable(&_Timecounter_Lock, lock_context)
 Releases the timecounter lock.
typedef void(* Timecounter_NTP_update_second) (int64_t *adjustment, time_t *newsec)
 Handler doing the NTP update second processing shall have this type.
void _Timecounter_Bintime (struct bintime *bt)
 Returns the wall clock time in the bintime format.
void _Timecounter_Nanotime (struct timespec *ts)
 Returns the wall clock time in the timespec format.
void _Timecounter_Microtime (struct timeval *tv)
 Returns the wall clock time in the timeval format.
void _Timecounter_Binuptime (struct bintime *bt)
 Returns the uptime in the bintime format.
int64_t _Timecounter_Sbinuptime (void)
 Returns the uptime in the sbintime_t format.
void _Timecounter_Nanouptime (struct timespec *ts)
 Returns the uptime in the timespec format.
void _Timecounter_Microuptime (struct timeval *tv)
 Returns the uptime in the timeval format.
void _Timecounter_Getbintime (struct bintime *bt)
void _Timecounter_Getnanotime (struct timespec *ts)
void _Timecounter_Getmicrotime (struct timeval *tv)
void _Timecounter_Getbinuptime (struct bintime *bt)
void _Timecounter_Getnanouptime (struct timespec *ts)
void _Timecounter_Getmicrouptime (struct timeval *tv)
void _Timecounter_Getboottime (struct timeval *tv)
 Returns the boot time in the timeval format.
void _Timecounter_Getboottimebin (struct bintime *bt)
 Returns the boot time in the bintime format.
void _Timecounter_Install (struct timecounter *tc)
 Installs the timecounter.
void _Timecounter_Tick (void)
 Performs a timecounter tick.
void _Timecounter_Tick_simple (uint32_t delta, uint32_t offset, ISR_lock_Context *lock_context)
 Performs a simple timecounter tick.
void _Timecounter_Set_NTP_update_second (Timecounter_NTP_update_second handler)
 Sets the NTP update second handler.
void _Timecounter_NTP_update_second (int64_t *adjustment, time_t *newsec)
 Updates the time adjustment and seconds according to the NTP state.
uint64_t _Timecounter_Get_frequency (void)
 Gets the frequency in Hz of the current timecounter at some time point during the call.
void _Timecounter_Discipline (struct timespec *tsp, long nsec)
 Updates the timecounter frequency adjustment used by _Timecounter_Set_NTP_update_second().
void _Timecounter_Set_clock (const struct bintime *bt, ISR_lock_Context *lock_context)
 Sets the timecounter clock to the given value.
volatile time_t _Timecounter_Time_second
 The wall clock time in seconds.
volatile int32_t _Timecounter_Time_uptime
 The uptime in seconds.
struct timecounter_Timecounter
 The current timecounter.
◆ _Timecounter_Acquire
#define _Timecounter_Acquire (   lock_context)     _ISR_lock_ISR_disable_and_acquire( &_Timecounter_Lock, lock_context )
Parameters
lock_contextThe lock context.
See _Timecounter_Tick_simple().
◆ _Timecounter_Release
#define _Timecounter_Release (   lock_context)     _ISR_lock_Release_and_ISR_enable(&_Timecounter_Lock, lock_context)
Parameters
Typedef Documentation
◆ Timecounter_NTP_update_second
Parameters
[in,out]adjustmentis the NTP time adjustment.
[in,out]newsecis the number of seconds since Unix epoch.
◆ _Timecounter_Bintime()
void _Timecounter_Bintime ( struct bintime *  bt)
Parameters
[out]btReturns the wall clock time.
◆ _Timecounter_Binuptime()
void _Timecounter_Binuptime ( struct bintime *  bt)
Parameters
[out]btReturns the uptime.
◆ _Timecounter_Discipline()
void _Timecounter_Discipline ( struct timespec *  tsp,
long  nsec
This function is part of the time synchronization using a PPS (Pulse Per Second) signal.
When an event (a rising or falling edge of the PPS signal) occurs, the functions pps_capture() and pps_event() are executed. Only if the kernel consumer is configured to be PPS_KC_HARDPPS, the timecounter is disciplined.
Parameters
[in]tspis the time at PPS event
[i]nsec is the time in nanoseconds from the last PPS event
◆ _Timecounter_Get_frequency()
uint64_t _Timecounter_Get_frequency ( void  )
Returns
Returns the frequency in Hz.
◆ _Timecounter_Getbintime()
void _Timecounter_Getbintime ( struct bintime *  bt)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Bintime() variant.
Parameters
[out]tsReturns the wall clock time.
◆ _Timecounter_Getbinuptime()
void _Timecounter_Getbinuptime ( struct bintime *  bt)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Binuptime() variant.
Parameters
[out]tsReturns the uptime.
◆ _Timecounter_Getboottime()
void _Timecounter_Getboottime ( struct timeval *  tv)
Parameters
[out]tvReturns the boot time.
◆ _Timecounter_Getboottimebin()
void _Timecounter_Getboottimebin ( struct bintime *  bt)
Parameters
◆ _Timecounter_Getmicrotime()
void _Timecounter_Getmicrotime ( struct timeval *  tv)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Microtime() variant.
Parameters
[out]tvReturns the wall clock time.
See also
_Timecounter_Getbintime().
◆ _Timecounter_Getmicrouptime()
void _Timecounter_Getmicrouptime ( struct timeval *  tv)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Microuptime() variant.
Parameters
[out]tvReturns the uptime.
◆ _Timecounter_Getnanotime()
void _Timecounter_Getnanotime ( struct timespec *  ts)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Nanotime() variant.
Parameters
See also
◆ _Timecounter_Getnanouptime()
void _Timecounter_Getnanouptime ( struct timespec *  ts)
This function obtains the time with a lower overhead and lower accuracy compared to the _Timecounter_Nanouptime() variant.
Parameters
◆ _Timecounter_Install()
void _Timecounter_Install ( struct timecounter tc)
The timecounter structure must contain valid values in the fields tc_get_timecount, tc_counter_mask, tc_frequency and tc_quality. All other fields must be zero initialized.
Parameters
tcThe timecounter.
◆ _Timecounter_Microtime()
void _Timecounter_Microtime ( struct timeval *  tv)
Parameters
◆ _Timecounter_Microuptime()
void _Timecounter_Microuptime ( struct timeval *  tv)
Parameters
◆ _Timecounter_Nanotime()
void _Timecounter_Nanotime ( struct timespec *  ts)
Parameters
◆ _Timecounter_Nanouptime()
void _Timecounter_Nanouptime ( struct timespec *  ts)
Parameters
◆ _Timecounter_NTP_update_second()
void _Timecounter_NTP_update_second ( int64_t *  adjustment,
time_t *  newsec
Parameters
◆ _Timecounter_Sbinuptime()
int64_t _Timecounter_Sbinuptime ( void  )
Returns
Returns the uptime.
◆ _Timecounter_Set_clock()
void _Timecounter_Set_clock ( const struct bintime *  bt,
ISR_lock_Context lock_context
Parameters
btThe value to set the clock to.
lock_contextThe interrupt lock context.
◆ _Timecounter_Set_NTP_update_second()
void _Timecounter_Set_NTP_update_second ( Timecounter_NTP_update_second  handler)
Parameters
handleris the new NTP update second handler used to carry out the NTP update second processing.
◆ _Timecounter_Tick_simple()
void _Timecounter_Tick_simple ( uint32_t  delta,
uint32_t  offset,
This is a special purpose tick function for simple timecounter to support legacy clock drivers.
Parameters
deltaThe time in timecounter ticks elapsed since the last call to _Timecounter_Tick_simple().
offsetThe current value of the timecounter.
]lock_context The lock context of the corresponding _Timecounter_Acquire().
Variable Documentation
◆ _Timecounter_Time_uptime
extern
For compatibility with the FreeBSD network stack the initial value is one second.
