RTEMS 6.1-rc4
VERID - Version ID Register | |
#define | LPUART_VERID_FEATURE_MASK (0xFFFFU) |
#define | LPUART_VERID_FEATURE_SHIFT (0U) |
#define | LPUART_VERID_FEATURE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_VERID_FEATURE_SHIFT)) & LPUART_VERID_FEATURE_MASK) |
#define | LPUART_VERID_MINOR_MASK (0xFF0000U) |
#define | LPUART_VERID_MINOR_SHIFT (16U) |
#define | LPUART_VERID_MINOR(x) (((uint32_t)(((uint32_t)(x)) << LPUART_VERID_MINOR_SHIFT)) & LPUART_VERID_MINOR_MASK) |
#define | LPUART_VERID_MAJOR_MASK (0xFF000000U) |
#define | LPUART_VERID_MAJOR_SHIFT (24U) |
#define | LPUART_VERID_MAJOR(x) (((uint32_t)(((uint32_t)(x)) << LPUART_VERID_MAJOR_SHIFT)) & LPUART_VERID_MAJOR_MASK) |
PARAM - Parameter Register | |
#define | LPUART_PARAM_TXFIFO_MASK (0xFFU) |
#define | LPUART_PARAM_TXFIFO_SHIFT (0U) |
#define | LPUART_PARAM_TXFIFO(x) (((uint32_t)(((uint32_t)(x)) << LPUART_PARAM_TXFIFO_SHIFT)) & LPUART_PARAM_TXFIFO_MASK) |
#define | LPUART_PARAM_RXFIFO_MASK (0xFF00U) |
#define | LPUART_PARAM_RXFIFO_SHIFT (8U) |
#define | LPUART_PARAM_RXFIFO(x) (((uint32_t)(((uint32_t)(x)) << LPUART_PARAM_RXFIFO_SHIFT)) & LPUART_PARAM_RXFIFO_MASK) |
GLOBAL - LPUART Global Register | |
#define | LPUART_GLOBAL_RST_MASK (0x2U) |
#define | LPUART_GLOBAL_RST_SHIFT (1U) |
#define | LPUART_GLOBAL_RST(x) (((uint32_t)(((uint32_t)(x)) << LPUART_GLOBAL_RST_SHIFT)) & LPUART_GLOBAL_RST_MASK) |
PINCFG - LPUART Pin Configuration Register | |
#define | LPUART_PINCFG_TRGSEL_MASK (0x3U) |
#define | LPUART_PINCFG_TRGSEL_SHIFT (0U) |
#define | LPUART_PINCFG_TRGSEL(x) (((uint32_t)(((uint32_t)(x)) << LPUART_PINCFG_TRGSEL_SHIFT)) & LPUART_PINCFG_TRGSEL_MASK) |
BAUD - LPUART Baud Rate Register | |
#define | LPUART_BAUD_SBR_MASK (0x1FFFU) |
#define | LPUART_BAUD_SBR_SHIFT (0U) |
#define | LPUART_BAUD_SBR(x) (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_SBR_SHIFT)) & LPUART_BAUD_SBR_MASK) |
#define | LPUART_BAUD_SBNS_MASK (0x2000U) |
#define | LPUART_BAUD_SBNS_SHIFT (13U) |
#define | LPUART_BAUD_SBNS(x) (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_SBNS_SHIFT)) & LPUART_BAUD_SBNS_MASK) |
#define | LPUART_BAUD_RXEDGIE_MASK (0x4000U) |
#define | LPUART_BAUD_RXEDGIE_SHIFT (14U) |
#define | LPUART_BAUD_RXEDGIE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_RXEDGIE_SHIFT)) & LPUART_BAUD_RXEDGIE_MASK) |
#define | LPUART_BAUD_LBKDIE_MASK (0x8000U) |
#define | LPUART_BAUD_LBKDIE_SHIFT (15U) |
#define | LPUART_BAUD_LBKDIE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_LBKDIE_SHIFT)) & LPUART_BAUD_LBKDIE_MASK) |
#define | LPUART_BAUD_RESYNCDIS_MASK (0x10000U) |
#define | LPUART_BAUD_RESYNCDIS_SHIFT (16U) |
#define | LPUART_BAUD_RESYNCDIS(x) (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_RESYNCDIS_SHIFT)) & LPUART_BAUD_RESYNCDIS_MASK) |
#define | LPUART_BAUD_BOTHEDGE_MASK (0x20000U) |
#define | LPUART_BAUD_BOTHEDGE_SHIFT (17U) |
#define | LPUART_BAUD_BOTHEDGE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_BOTHEDGE_SHIFT)) & LPUART_BAUD_BOTHEDGE_MASK) |
#define | LPUART_BAUD_MATCFG_MASK (0xC0000U) |
#define | LPUART_BAUD_MATCFG_SHIFT (18U) |
#define | LPUART_BAUD_MATCFG(x) (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_MATCFG_SHIFT)) & LPUART_BAUD_MATCFG_MASK) |
#define | LPUART_BAUD_RIDMAE_MASK (0x100000U) |
#define | LPUART_BAUD_RIDMAE_SHIFT (20U) |
#define | LPUART_BAUD_RIDMAE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_RIDMAE_SHIFT)) & LPUART_BAUD_RIDMAE_MASK) |
#define | LPUART_BAUD_RDMAE_MASK (0x200000U) |
#define | LPUART_BAUD_RDMAE_SHIFT (21U) |
#define | LPUART_BAUD_RDMAE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_RDMAE_SHIFT)) & LPUART_BAUD_RDMAE_MASK) |
#define | LPUART_BAUD_TDMAE_MASK (0x800000U) |
#define | LPUART_BAUD_TDMAE_SHIFT (23U) |
#define | LPUART_BAUD_TDMAE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_TDMAE_SHIFT)) & LPUART_BAUD_TDMAE_MASK) |
#define | LPUART_BAUD_OSR_MASK (0x1F000000U) |
#define | LPUART_BAUD_OSR_SHIFT (24U) |
#define | LPUART_BAUD_OSR(x) (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_OSR_SHIFT)) & LPUART_BAUD_OSR_MASK) |
#define | LPUART_BAUD_M10_MASK (0x20000000U) |
#define | LPUART_BAUD_M10_SHIFT (29U) |
#define | LPUART_BAUD_M10(x) (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_M10_SHIFT)) & LPUART_BAUD_M10_MASK) |
#define | LPUART_BAUD_MAEN2_MASK (0x40000000U) |
#define | LPUART_BAUD_MAEN2_SHIFT (30U) |
#define | LPUART_BAUD_MAEN2(x) (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_MAEN2_SHIFT)) & LPUART_BAUD_MAEN2_MASK) |
#define | LPUART_BAUD_MAEN1_MASK (0x80000000U) |
#define | LPUART_BAUD_MAEN1_SHIFT (31U) |
#define | LPUART_BAUD_MAEN1(x) (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_MAEN1_SHIFT)) & LPUART_BAUD_MAEN1_MASK) |
STAT - LPUART Status Register | |
#define | LPUART_STAT_MA2F_MASK (0x4000U) |
#define | LPUART_STAT_MA2F_SHIFT (14U) |
#define | LPUART_STAT_MA2F(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_MA2F_SHIFT)) & LPUART_STAT_MA2F_MASK) |
#define | LPUART_STAT_MA1F_MASK (0x8000U) |
#define | LPUART_STAT_MA1F_SHIFT (15U) |
#define | LPUART_STAT_MA1F(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_MA1F_SHIFT)) & LPUART_STAT_MA1F_MASK) |
#define | LPUART_STAT_PF_MASK (0x10000U) |
#define | LPUART_STAT_PF_SHIFT (16U) |
#define | LPUART_STAT_PF(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_PF_SHIFT)) & LPUART_STAT_PF_MASK) |
#define | LPUART_STAT_FE_MASK (0x20000U) |
#define | LPUART_STAT_FE_SHIFT (17U) |
#define | LPUART_STAT_FE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_FE_SHIFT)) & LPUART_STAT_FE_MASK) |
#define | LPUART_STAT_NF_MASK (0x40000U) |
#define | LPUART_STAT_NF_SHIFT (18U) |
#define | LPUART_STAT_NF(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_NF_SHIFT)) & LPUART_STAT_NF_MASK) |
#define | LPUART_STAT_OR_MASK (0x80000U) |
#define | LPUART_STAT_OR_SHIFT (19U) |
#define | LPUART_STAT_OR(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_OR_SHIFT)) & LPUART_STAT_OR_MASK) |
#define | LPUART_STAT_IDLE_MASK (0x100000U) |
#define | LPUART_STAT_IDLE_SHIFT (20U) |
#define | LPUART_STAT_IDLE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_IDLE_SHIFT)) & LPUART_STAT_IDLE_MASK) |
#define | LPUART_STAT_RDRF_MASK (0x200000U) |
#define | LPUART_STAT_RDRF_SHIFT (21U) |
#define | LPUART_STAT_RDRF(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_RDRF_SHIFT)) & LPUART_STAT_RDRF_MASK) |
#define | LPUART_STAT_TC_MASK (0x400000U) |
#define | LPUART_STAT_TC_SHIFT (22U) |
#define | LPUART_STAT_TC(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_TC_SHIFT)) & LPUART_STAT_TC_MASK) |
#define | LPUART_STAT_TDRE_MASK (0x800000U) |
#define | LPUART_STAT_TDRE_SHIFT (23U) |
#define | LPUART_STAT_TDRE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_TDRE_SHIFT)) & LPUART_STAT_TDRE_MASK) |
#define | LPUART_STAT_RAF_MASK (0x1000000U) |
#define | LPUART_STAT_RAF_SHIFT (24U) |
#define | LPUART_STAT_RAF(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_RAF_SHIFT)) & LPUART_STAT_RAF_MASK) |
#define | LPUART_STAT_LBKDE_MASK (0x2000000U) |
#define | LPUART_STAT_LBKDE_SHIFT (25U) |
#define | LPUART_STAT_LBKDE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_LBKDE_SHIFT)) & LPUART_STAT_LBKDE_MASK) |
#define | LPUART_STAT_BRK13_MASK (0x4000000U) |
#define | LPUART_STAT_BRK13_SHIFT (26U) |
#define | LPUART_STAT_BRK13(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_BRK13_SHIFT)) & LPUART_STAT_BRK13_MASK) |
#define | LPUART_STAT_RWUID_MASK (0x8000000U) |
#define | LPUART_STAT_RWUID_SHIFT (27U) |
#define | LPUART_STAT_RWUID(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_RWUID_SHIFT)) & LPUART_STAT_RWUID_MASK) |
#define | LPUART_STAT_RXINV_MASK (0x10000000U) |
#define | LPUART_STAT_RXINV_SHIFT (28U) |
#define | LPUART_STAT_RXINV(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_RXINV_SHIFT)) & LPUART_STAT_RXINV_MASK) |
#define | LPUART_STAT_MSBF_MASK (0x20000000U) |
#define | LPUART_STAT_MSBF_SHIFT (29U) |
#define | LPUART_STAT_MSBF(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_MSBF_SHIFT)) & LPUART_STAT_MSBF_MASK) |
#define | LPUART_STAT_RXEDGIF_MASK (0x40000000U) |
#define | LPUART_STAT_RXEDGIF_SHIFT (30U) |
#define | LPUART_STAT_RXEDGIF(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_RXEDGIF_SHIFT)) & LPUART_STAT_RXEDGIF_MASK) |
#define | LPUART_STAT_LBKDIF_MASK (0x80000000U) |
#define | LPUART_STAT_LBKDIF_SHIFT (31U) |
#define | LPUART_STAT_LBKDIF(x) (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_LBKDIF_SHIFT)) & LPUART_STAT_LBKDIF_MASK) |
CTRL - LPUART Control Register | |
#define | LPUART_CTRL_PT_MASK (0x1U) |
#define | LPUART_CTRL_PT_SHIFT (0U) |
#define | LPUART_CTRL_PT(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_PT_SHIFT)) & LPUART_CTRL_PT_MASK) |
#define | LPUART_CTRL_PE_MASK (0x2U) |
#define | LPUART_CTRL_PE_SHIFT (1U) |
#define | LPUART_CTRL_PE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_PE_SHIFT)) & LPUART_CTRL_PE_MASK) |
#define | LPUART_CTRL_ILT_MASK (0x4U) |
#define | LPUART_CTRL_ILT_SHIFT (2U) |
#define | LPUART_CTRL_ILT(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_ILT_SHIFT)) & LPUART_CTRL_ILT_MASK) |
#define | LPUART_CTRL_WAKE_MASK (0x8U) |
#define | LPUART_CTRL_WAKE_SHIFT (3U) |
#define | LPUART_CTRL_WAKE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_WAKE_SHIFT)) & LPUART_CTRL_WAKE_MASK) |
#define | LPUART_CTRL_M_MASK (0x10U) |
#define | LPUART_CTRL_M_SHIFT (4U) |
#define | LPUART_CTRL_M(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_M_SHIFT)) & LPUART_CTRL_M_MASK) |
#define | LPUART_CTRL_RSRC_MASK (0x20U) |
#define | LPUART_CTRL_RSRC_SHIFT (5U) |
#define | LPUART_CTRL_RSRC(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_RSRC_SHIFT)) & LPUART_CTRL_RSRC_MASK) |
#define | LPUART_CTRL_DOZEEN_MASK (0x40U) |
#define | LPUART_CTRL_DOZEEN_SHIFT (6U) |
#define | LPUART_CTRL_DOZEEN(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_DOZEEN_SHIFT)) & LPUART_CTRL_DOZEEN_MASK) |
#define | LPUART_CTRL_LOOPS_MASK (0x80U) |
#define | LPUART_CTRL_LOOPS_SHIFT (7U) |
#define | LPUART_CTRL_LOOPS(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_LOOPS_SHIFT)) & LPUART_CTRL_LOOPS_MASK) |
#define | LPUART_CTRL_IDLECFG_MASK (0x700U) |
#define | LPUART_CTRL_IDLECFG_SHIFT (8U) |
#define | LPUART_CTRL_IDLECFG(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_IDLECFG_SHIFT)) & LPUART_CTRL_IDLECFG_MASK) |
#define | LPUART_CTRL_M7_MASK (0x800U) |
#define | LPUART_CTRL_M7_SHIFT (11U) |
#define | LPUART_CTRL_M7(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_M7_SHIFT)) & LPUART_CTRL_M7_MASK) |
#define | LPUART_CTRL_MA2IE_MASK (0x4000U) |
#define | LPUART_CTRL_MA2IE_SHIFT (14U) |
#define | LPUART_CTRL_MA2IE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_MA2IE_SHIFT)) & LPUART_CTRL_MA2IE_MASK) |
#define | LPUART_CTRL_MA1IE_MASK (0x8000U) |
#define | LPUART_CTRL_MA1IE_SHIFT (15U) |
#define | LPUART_CTRL_MA1IE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_MA1IE_SHIFT)) & LPUART_CTRL_MA1IE_MASK) |
#define | LPUART_CTRL_SBK_MASK (0x10000U) |
#define | LPUART_CTRL_SBK_SHIFT (16U) |
#define | LPUART_CTRL_SBK(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_SBK_SHIFT)) & LPUART_CTRL_SBK_MASK) |
#define | LPUART_CTRL_RWU_MASK (0x20000U) |
#define | LPUART_CTRL_RWU_SHIFT (17U) |
#define | LPUART_CTRL_RWU(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_RWU_SHIFT)) & LPUART_CTRL_RWU_MASK) |
#define | LPUART_CTRL_RE_MASK (0x40000U) |
#define | LPUART_CTRL_RE_SHIFT (18U) |
#define | LPUART_CTRL_RE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_RE_SHIFT)) & LPUART_CTRL_RE_MASK) |
#define | LPUART_CTRL_TE_MASK (0x80000U) |
#define | LPUART_CTRL_TE_SHIFT (19U) |
#define | LPUART_CTRL_TE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_TE_SHIFT)) & LPUART_CTRL_TE_MASK) |
#define | LPUART_CTRL_ILIE_MASK (0x100000U) |
#define | LPUART_CTRL_ILIE_SHIFT (20U) |
#define | LPUART_CTRL_ILIE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_ILIE_SHIFT)) & LPUART_CTRL_ILIE_MASK) |
#define | LPUART_CTRL_RIE_MASK (0x200000U) |
#define | LPUART_CTRL_RIE_SHIFT (21U) |
#define | LPUART_CTRL_RIE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_RIE_SHIFT)) & LPUART_CTRL_RIE_MASK) |
#define | LPUART_CTRL_TCIE_MASK (0x400000U) |
#define | LPUART_CTRL_TCIE_SHIFT (22U) |
#define | LPUART_CTRL_TCIE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_TCIE_SHIFT)) & LPUART_CTRL_TCIE_MASK) |
#define | LPUART_CTRL_TIE_MASK (0x800000U) |
#define | LPUART_CTRL_TIE_SHIFT (23U) |
#define | LPUART_CTRL_TIE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_TIE_SHIFT)) & LPUART_CTRL_TIE_MASK) |
#define | LPUART_CTRL_PEIE_MASK (0x1000000U) |
#define | LPUART_CTRL_PEIE_SHIFT (24U) |
#define | LPUART_CTRL_PEIE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_PEIE_SHIFT)) & LPUART_CTRL_PEIE_MASK) |
#define | LPUART_CTRL_FEIE_MASK (0x2000000U) |
#define | LPUART_CTRL_FEIE_SHIFT (25U) |
#define | LPUART_CTRL_FEIE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_FEIE_SHIFT)) & LPUART_CTRL_FEIE_MASK) |
#define | LPUART_CTRL_NEIE_MASK (0x4000000U) |
#define | LPUART_CTRL_NEIE_SHIFT (26U) |
#define | LPUART_CTRL_NEIE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_NEIE_SHIFT)) & LPUART_CTRL_NEIE_MASK) |
#define | LPUART_CTRL_ORIE_MASK (0x8000000U) |
#define | LPUART_CTRL_ORIE_SHIFT (27U) |
#define | LPUART_CTRL_ORIE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_ORIE_SHIFT)) & LPUART_CTRL_ORIE_MASK) |
#define | LPUART_CTRL_TXINV_MASK (0x10000000U) |
#define | LPUART_CTRL_TXINV_SHIFT (28U) |
#define | LPUART_CTRL_TXINV(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_TXINV_SHIFT)) & LPUART_CTRL_TXINV_MASK) |
#define | LPUART_CTRL_TXDIR_MASK (0x20000000U) |
#define | LPUART_CTRL_TXDIR_SHIFT (29U) |
#define | LPUART_CTRL_TXDIR(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_TXDIR_SHIFT)) & LPUART_CTRL_TXDIR_MASK) |
#define | LPUART_CTRL_R9T8_MASK (0x40000000U) |
#define | LPUART_CTRL_R9T8_SHIFT (30U) |
#define | LPUART_CTRL_R9T8(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_R9T8_SHIFT)) & LPUART_CTRL_R9T8_MASK) |
#define | LPUART_CTRL_R8T9_MASK (0x80000000U) |
#define | LPUART_CTRL_R8T9_SHIFT (31U) |
#define | LPUART_CTRL_R8T9(x) (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_R8T9_SHIFT)) & LPUART_CTRL_R8T9_MASK) |
DATA - LPUART Data Register | |
#define | LPUART_DATA_R0T0_MASK (0x1U) |
#define | LPUART_DATA_R0T0_SHIFT (0U) |
#define | LPUART_DATA_R0T0(x) (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R0T0_SHIFT)) & LPUART_DATA_R0T0_MASK) |
#define | LPUART_DATA_R1T1_MASK (0x2U) |
#define | LPUART_DATA_R1T1_SHIFT (1U) |
#define | LPUART_DATA_R1T1(x) (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R1T1_SHIFT)) & LPUART_DATA_R1T1_MASK) |
#define | LPUART_DATA_R2T2_MASK (0x4U) |
#define | LPUART_DATA_R2T2_SHIFT (2U) |
#define | LPUART_DATA_R2T2(x) (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R2T2_SHIFT)) & LPUART_DATA_R2T2_MASK) |
#define | LPUART_DATA_R3T3_MASK (0x8U) |
#define | LPUART_DATA_R3T3_SHIFT (3U) |
#define | LPUART_DATA_R3T3(x) (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R3T3_SHIFT)) & LPUART_DATA_R3T3_MASK) |
#define | LPUART_DATA_R4T4_MASK (0x10U) |
#define | LPUART_DATA_R4T4_SHIFT (4U) |
#define | LPUART_DATA_R4T4(x) (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R4T4_SHIFT)) & LPUART_DATA_R4T4_MASK) |
#define | LPUART_DATA_R5T5_MASK (0x20U) |
#define | LPUART_DATA_R5T5_SHIFT (5U) |
#define | LPUART_DATA_R5T5(x) (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R5T5_SHIFT)) & LPUART_DATA_R5T5_MASK) |
#define | LPUART_DATA_R6T6_MASK (0x40U) |
#define | LPUART_DATA_R6T6_SHIFT (6U) |
#define | LPUART_DATA_R6T6(x) (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R6T6_SHIFT)) & LPUART_DATA_R6T6_MASK) |
#define | LPUART_DATA_R7T7_MASK (0x80U) |
#define | LPUART_DATA_R7T7_SHIFT (7U) |
#define | LPUART_DATA_R7T7(x) (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R7T7_SHIFT)) & LPUART_DATA_R7T7_MASK) |
#define | LPUART_DATA_R8T8_MASK (0x100U) |
#define | LPUART_DATA_R8T8_SHIFT (8U) |
#define | LPUART_DATA_R8T8(x) (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R8T8_SHIFT)) & LPUART_DATA_R8T8_MASK) |
#define | LPUART_DATA_R9T9_MASK (0x200U) |
#define | LPUART_DATA_R9T9_SHIFT (9U) |
#define | LPUART_DATA_R9T9(x) (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R9T9_SHIFT)) & LPUART_DATA_R9T9_MASK) |
#define | LPUART_DATA_IDLINE_MASK (0x800U) |
#define | LPUART_DATA_IDLINE_SHIFT (11U) |
#define | LPUART_DATA_IDLINE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_IDLINE_SHIFT)) & LPUART_DATA_IDLINE_MASK) |
#define | LPUART_DATA_RXEMPT_MASK (0x1000U) |
#define | LPUART_DATA_RXEMPT_SHIFT (12U) |
#define | LPUART_DATA_RXEMPT(x) (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_RXEMPT_SHIFT)) & LPUART_DATA_RXEMPT_MASK) |
#define | LPUART_DATA_FRETSC_MASK (0x2000U) |
#define | LPUART_DATA_FRETSC_SHIFT (13U) |
#define | LPUART_DATA_FRETSC(x) (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_FRETSC_SHIFT)) & LPUART_DATA_FRETSC_MASK) |
#define | LPUART_DATA_PARITYE_MASK (0x4000U) |
#define | LPUART_DATA_PARITYE_SHIFT (14U) |
#define | LPUART_DATA_PARITYE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_PARITYE_SHIFT)) & LPUART_DATA_PARITYE_MASK) |
#define | LPUART_DATA_NOISY_MASK (0x8000U) |
#define | LPUART_DATA_NOISY_SHIFT (15U) |
#define | LPUART_DATA_NOISY(x) (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_NOISY_SHIFT)) & LPUART_DATA_NOISY_MASK) |
MATCH - LPUART Match Address Register | |
#define | LPUART_MATCH_MA1_MASK (0x3FFU) |
#define | LPUART_MATCH_MA1_SHIFT (0U) |
#define | LPUART_MATCH_MA1(x) (((uint32_t)(((uint32_t)(x)) << LPUART_MATCH_MA1_SHIFT)) & LPUART_MATCH_MA1_MASK) |
#define | LPUART_MATCH_MA2_MASK (0x3FF0000U) |
#define | LPUART_MATCH_MA2_SHIFT (16U) |
#define | LPUART_MATCH_MA2(x) (((uint32_t)(((uint32_t)(x)) << LPUART_MATCH_MA2_SHIFT)) & LPUART_MATCH_MA2_MASK) |
MODIR - LPUART Modem IrDA Register | |
#define | LPUART_MODIR_TXCTSE_MASK (0x1U) |
#define | LPUART_MODIR_TXCTSE_SHIFT (0U) |
#define | LPUART_MODIR_TXCTSE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_TXCTSE_SHIFT)) & LPUART_MODIR_TXCTSE_MASK) |
#define | LPUART_MODIR_TXRTSE_MASK (0x2U) |
#define | LPUART_MODIR_TXRTSE_SHIFT (1U) |
#define | LPUART_MODIR_TXRTSE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_TXRTSE_SHIFT)) & LPUART_MODIR_TXRTSE_MASK) |
#define | LPUART_MODIR_TXRTSPOL_MASK (0x4U) |
#define | LPUART_MODIR_TXRTSPOL_SHIFT (2U) |
#define | LPUART_MODIR_TXRTSPOL(x) (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_TXRTSPOL_SHIFT)) & LPUART_MODIR_TXRTSPOL_MASK) |
#define | LPUART_MODIR_RXRTSE_MASK (0x8U) |
#define | LPUART_MODIR_RXRTSE_SHIFT (3U) |
#define | LPUART_MODIR_RXRTSE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_RXRTSE_SHIFT)) & LPUART_MODIR_RXRTSE_MASK) |
#define | LPUART_MODIR_TXCTSC_MASK (0x10U) |
#define | LPUART_MODIR_TXCTSC_SHIFT (4U) |
#define | LPUART_MODIR_TXCTSC(x) (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_TXCTSC_SHIFT)) & LPUART_MODIR_TXCTSC_MASK) |
#define | LPUART_MODIR_TXCTSSRC_MASK (0x20U) |
#define | LPUART_MODIR_TXCTSSRC_SHIFT (5U) |
#define | LPUART_MODIR_TXCTSSRC(x) (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_TXCTSSRC_SHIFT)) & LPUART_MODIR_TXCTSSRC_MASK) |
#define | LPUART_MODIR_RTSWATER_MASK (0x300U) |
#define | LPUART_MODIR_RTSWATER_SHIFT (8U) |
#define | LPUART_MODIR_RTSWATER(x) (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_RTSWATER_SHIFT)) & LPUART_MODIR_RTSWATER_MASK) |
#define | LPUART_MODIR_TNP_MASK (0x30000U) |
#define | LPUART_MODIR_TNP_SHIFT (16U) |
#define | LPUART_MODIR_TNP(x) (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_TNP_SHIFT)) & LPUART_MODIR_TNP_MASK) |
#define | LPUART_MODIR_IREN_MASK (0x40000U) |
#define | LPUART_MODIR_IREN_SHIFT (18U) |
#define | LPUART_MODIR_IREN(x) (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_IREN_SHIFT)) & LPUART_MODIR_IREN_MASK) |
FIFO - LPUART FIFO Register | |
#define | LPUART_FIFO_RXFIFOSIZE_MASK (0x7U) |
#define | LPUART_FIFO_RXFIFOSIZE_SHIFT (0U) |
#define | LPUART_FIFO_RXFIFOSIZE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_RXFIFOSIZE_SHIFT)) & LPUART_FIFO_RXFIFOSIZE_MASK) |
#define | LPUART_FIFO_RXFE_MASK (0x8U) |
#define | LPUART_FIFO_RXFE_SHIFT (3U) |
#define | LPUART_FIFO_RXFE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_RXFE_SHIFT)) & LPUART_FIFO_RXFE_MASK) |
#define | LPUART_FIFO_TXFIFOSIZE_MASK (0x70U) |
#define | LPUART_FIFO_TXFIFOSIZE_SHIFT (4U) |
#define | LPUART_FIFO_TXFIFOSIZE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_TXFIFOSIZE_SHIFT)) & LPUART_FIFO_TXFIFOSIZE_MASK) |
#define | LPUART_FIFO_TXFE_MASK (0x80U) |
#define | LPUART_FIFO_TXFE_SHIFT (7U) |
#define | LPUART_FIFO_TXFE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_TXFE_SHIFT)) & LPUART_FIFO_TXFE_MASK) |
#define | LPUART_FIFO_RXUFE_MASK (0x100U) |
#define | LPUART_FIFO_RXUFE_SHIFT (8U) |
#define | LPUART_FIFO_RXUFE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_RXUFE_SHIFT)) & LPUART_FIFO_RXUFE_MASK) |
#define | LPUART_FIFO_TXOFE_MASK (0x200U) |
#define | LPUART_FIFO_TXOFE_SHIFT (9U) |
#define | LPUART_FIFO_TXOFE(x) (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_TXOFE_SHIFT)) & LPUART_FIFO_TXOFE_MASK) |
#define | LPUART_FIFO_RXIDEN_MASK (0x1C00U) |
#define | LPUART_FIFO_RXIDEN_SHIFT (10U) |
#define | LPUART_FIFO_RXIDEN(x) (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_RXIDEN_SHIFT)) & LPUART_FIFO_RXIDEN_MASK) |
#define | LPUART_FIFO_RXFLUSH_MASK (0x4000U) |
#define | LPUART_FIFO_RXFLUSH_SHIFT (14U) |
#define | LPUART_FIFO_RXFLUSH(x) (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_RXFLUSH_SHIFT)) & LPUART_FIFO_RXFLUSH_MASK) |
#define | LPUART_FIFO_TXFLUSH_MASK (0x8000U) |
#define | LPUART_FIFO_TXFLUSH_SHIFT (15U) |
#define | LPUART_FIFO_TXFLUSH(x) (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_TXFLUSH_SHIFT)) & LPUART_FIFO_TXFLUSH_MASK) |
#define | LPUART_FIFO_RXUF_MASK (0x10000U) |
#define | LPUART_FIFO_RXUF_SHIFT (16U) |
#define | LPUART_FIFO_RXUF(x) (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_RXUF_SHIFT)) & LPUART_FIFO_RXUF_MASK) |
#define | LPUART_FIFO_TXOF_MASK (0x20000U) |
#define | LPUART_FIFO_TXOF_SHIFT (17U) |
#define | LPUART_FIFO_TXOF(x) (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_TXOF_SHIFT)) & LPUART_FIFO_TXOF_MASK) |
#define | LPUART_FIFO_RXEMPT_MASK (0x400000U) |
#define | LPUART_FIFO_RXEMPT_SHIFT (22U) |
#define | LPUART_FIFO_RXEMPT(x) (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_RXEMPT_SHIFT)) & LPUART_FIFO_RXEMPT_MASK) |
#define | LPUART_FIFO_TXEMPT_MASK (0x800000U) |
#define | LPUART_FIFO_TXEMPT_SHIFT (23U) |
#define | LPUART_FIFO_TXEMPT(x) (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_TXEMPT_SHIFT)) & LPUART_FIFO_TXEMPT_MASK) |
WATER - LPUART Watermark Register | |
#define | LPUART_WATER_TXWATER_MASK (0x3U) |
#define | LPUART_WATER_TXWATER_SHIFT (0U) |
#define | LPUART_WATER_TXWATER(x) (((uint32_t)(((uint32_t)(x)) << LPUART_WATER_TXWATER_SHIFT)) & LPUART_WATER_TXWATER_MASK) |
#define | LPUART_WATER_TXCOUNT_MASK (0x700U) |
#define | LPUART_WATER_TXCOUNT_SHIFT (8U) |
#define | LPUART_WATER_TXCOUNT(x) (((uint32_t)(((uint32_t)(x)) << LPUART_WATER_TXCOUNT_SHIFT)) & LPUART_WATER_TXCOUNT_MASK) |
#define | LPUART_WATER_RXWATER_MASK (0x30000U) |
#define | LPUART_WATER_RXWATER_SHIFT (16U) |
#define | LPUART_WATER_RXWATER(x) (((uint32_t)(((uint32_t)(x)) << LPUART_WATER_RXWATER_SHIFT)) & LPUART_WATER_RXWATER_MASK) |
#define | LPUART_WATER_RXCOUNT_MASK (0x7000000U) |
#define | LPUART_WATER_RXCOUNT_SHIFT (24U) |
#define | LPUART_WATER_RXCOUNT(x) (((uint32_t)(((uint32_t)(x)) << LPUART_WATER_RXCOUNT_SHIFT)) & LPUART_WATER_RXCOUNT_MASK) |
#define LPUART_BAUD_BOTHEDGE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_BOTHEDGE_SHIFT)) & LPUART_BAUD_BOTHEDGE_MASK) |
BOTHEDGE - Both Edge Sampling 0b0..Receiver samples input data using the rising edge of the baud rate clock. 0b1..Receiver samples input data using the rising and falling edge of the baud rate clock.
#define LPUART_BAUD_LBKDIE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_LBKDIE_SHIFT)) & LPUART_BAUD_LBKDIE_MASK) |
LBKDIE - LIN Break Detect Interrupt Enable 0b0..Hardware interrupts from STAT[LBKDIF] flag are disabled (use polling). 0b1..Hardware interrupt requested when STAT[LBKDIF] flag is 1.
LBKDIE - LIN Break Detect Interrupt Enable 0b0..Hardware interrupts from STAT[LBKDIF] flag are disabled (use polling). 0b1..Hardware interrupt is requested when STAT[LBKDIF] flag is 1.
#define LPUART_BAUD_M10 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_M10_SHIFT)) & LPUART_BAUD_M10_MASK) |
M10 - 10-bit Mode select 0b0..Receiver and transmitter use 7-bit to 9-bit data characters. 0b1..Receiver and transmitter use 10-bit data characters.
#define LPUART_BAUD_MAEN1 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_MAEN1_SHIFT)) & LPUART_BAUD_MAEN1_MASK) |
MAEN1 - Match Address Mode Enable 1 0b0..Normal operation. 0b1..Enables automatic address matching or data matching mode for MATCH[MA1].
#define LPUART_BAUD_MAEN2 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_MAEN2_SHIFT)) & LPUART_BAUD_MAEN2_MASK) |
MAEN2 - Match Address Mode Enable 2 0b0..Normal operation. 0b1..Enables automatic address matching or data matching mode for MATCH[MA2].
#define LPUART_BAUD_MATCFG | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_MATCFG_SHIFT)) & LPUART_BAUD_MATCFG_MASK) |
MATCFG - Match Configuration 0b00..Address Match Wakeup 0b01..Idle Match Wakeup 0b10..Match On and Match Off 0b11..Enables RWU on Data Match and Match On/Off for transmitter CTS input
#define LPUART_BAUD_OSR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_OSR_SHIFT)) & LPUART_BAUD_OSR_MASK) |
OSR - Oversampling Ratio 0b00000..Writing 0 to this field results in an oversampling ratio of 16 0b00001..Reserved 0b00010..Reserved 0b00011..Oversampling ratio of 4, requires BOTHEDGE to be set. 0b00100..Oversampling ratio of 5, requires BOTHEDGE to be set. 0b00101..Oversampling ratio of 6, requires BOTHEDGE to be set. 0b00110..Oversampling ratio of 7, requires BOTHEDGE to be set. 0b00111..Oversampling ratio of 8. 0b01000..Oversampling ratio of 9. 0b01001..Oversampling ratio of 10. 0b01010..Oversampling ratio of 11. 0b01011..Oversampling ratio of 12. 0b01100..Oversampling ratio of 13. 0b01101..Oversampling ratio of 14. 0b01110..Oversampling ratio of 15. 0b01111..Oversampling ratio of 16. 0b10000..Oversampling ratio of 17. 0b10001..Oversampling ratio of 18. 0b10010..Oversampling ratio of 19. 0b10011..Oversampling ratio of 20. 0b10100..Oversampling ratio of 21. 0b10101..Oversampling ratio of 22. 0b10110..Oversampling ratio of 23. 0b10111..Oversampling ratio of 24. 0b11000..Oversampling ratio of 25. 0b11001..Oversampling ratio of 26. 0b11010..Oversampling ratio of 27. 0b11011..Oversampling ratio of 28. 0b11100..Oversampling ratio of 29. 0b11101..Oversampling ratio of 30. 0b11110..Oversampling ratio of 31. 0b11111..Oversampling ratio of 32.
#define LPUART_BAUD_RDMAE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_RDMAE_SHIFT)) & LPUART_BAUD_RDMAE_MASK) |
RDMAE - Receiver Full DMA Enable 0b0..DMA request disabled. 0b1..DMA request enabled.
#define LPUART_BAUD_RESYNCDIS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_RESYNCDIS_SHIFT)) & LPUART_BAUD_RESYNCDIS_MASK) |
RESYNCDIS - Resynchronization Disable 0b0..Resynchronization during received data word is supported 0b1..Resynchronization during received data word is disabled
RESYNCDIS - Resynchronization Disable 0b0..Resynchronization during received data word is supported. 0b1..Resynchronization during received data word is disabled.
#define LPUART_BAUD_RIDMAE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_RIDMAE_SHIFT)) & LPUART_BAUD_RIDMAE_MASK) |
RIDMAE - Receiver Idle DMA Enable 0b0..DMA request disabled. 0b1..DMA request enabled.
#define LPUART_BAUD_RXEDGIE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_RXEDGIE_SHIFT)) & LPUART_BAUD_RXEDGIE_MASK) |
RXEDGIE - RX Input Active Edge Interrupt Enable 0b0..Hardware interrupts from STAT[RXEDGIF] are disabled. 0b1..Hardware interrupt is requested when STAT[RXEDGIF] flag is 1.
#define LPUART_BAUD_SBNS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_SBNS_SHIFT)) & LPUART_BAUD_SBNS_MASK) |
SBNS - Stop Bit Number Select 0b0..One stop bit. 0b1..Two stop bits.
#define LPUART_BAUD_SBR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_SBR_SHIFT)) & LPUART_BAUD_SBR_MASK) |
SBR - Baud Rate Modulo Divisor.
#define LPUART_BAUD_TDMAE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_BAUD_TDMAE_SHIFT)) & LPUART_BAUD_TDMAE_MASK) |
TDMAE - Transmitter DMA Enable 0b0..DMA request disabled. 0b1..DMA request enabled.
#define LPUART_CTRL_DOZEEN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_DOZEEN_SHIFT)) & LPUART_CTRL_DOZEEN_MASK) |
DOZEEN - Doze Enable 0b0..LPUART is enabled in Doze mode. 0b1..LPUART is disabled in Doze mode.
DOZEEN - Doze Enable 0b0..LPUART is enabled in Doze mode. 0b1..LPUART is disabled in Doze mode .
#define LPUART_CTRL_FEIE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_FEIE_SHIFT)) & LPUART_CTRL_FEIE_MASK) |
FEIE - Framing Error Interrupt Enable 0b0..FE interrupts disabled; use polling. 0b1..Hardware interrupt requested when FE is set.
FEIE - Framing Error Interrupt Enable 0b0..FE interrupts disabled; use polling. 0b1..Hardware interrupt is requested when FE is set.
#define LPUART_CTRL_IDLECFG | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_IDLECFG_SHIFT)) & LPUART_CTRL_IDLECFG_MASK) |
IDLECFG - Idle Configuration 0b000..1 idle character 0b001..2 idle characters 0b010..4 idle characters 0b011..8 idle characters 0b100..16 idle characters 0b101..32 idle characters 0b110..64 idle characters 0b111..128 idle characters
#define LPUART_CTRL_ILIE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_ILIE_SHIFT)) & LPUART_CTRL_ILIE_MASK) |
ILIE - Idle Line Interrupt Enable 0b0..Hardware interrupts from IDLE disabled; use polling. 0b1..Hardware interrupt requested when IDLE flag is 1.
ILIE - Idle Line Interrupt Enable 0b0..Hardware interrupts from IDLE disabled; use polling. 0b1..Hardware interrupt is requested when IDLE flag is 1.
#define LPUART_CTRL_ILT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_ILT_SHIFT)) & LPUART_CTRL_ILT_MASK) |
ILT - Idle Line Type Select 0b0..Idle character bit count starts after start bit. 0b1..Idle character bit count starts after stop bit.
#define LPUART_CTRL_LOOPS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_LOOPS_SHIFT)) & LPUART_CTRL_LOOPS_MASK) |
LOOPS - Loop Mode Select 0b0..Normal operation - RXD and TXD use separate pins. 0b1..Loop mode or single-wire mode where transmitter outputs are internally connected to receiver input (see RSRC bit).
#define LPUART_CTRL_M | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_M_SHIFT)) & LPUART_CTRL_M_MASK) |
M - 9-Bit or 8-Bit Mode Select 0b0..Receiver and transmitter use 8-bit data characters. 0b1..Receiver and transmitter use 9-bit data characters.
#define LPUART_CTRL_M7 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_M7_SHIFT)) & LPUART_CTRL_M7_MASK) |
M7 - 7-Bit Mode Select 0b0..Receiver and transmitter use 8-bit to 10-bit data characters. 0b1..Receiver and transmitter use 7-bit data characters.
#define LPUART_CTRL_MA1IE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_MA1IE_SHIFT)) & LPUART_CTRL_MA1IE_MASK) |
MA1IE - Match 1 Interrupt Enable 0b0..MA1F interrupt disabled 0b1..MA1F interrupt enabled
#define LPUART_CTRL_MA2IE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_MA2IE_SHIFT)) & LPUART_CTRL_MA2IE_MASK) |
MA2IE - Match 2 Interrupt Enable 0b0..MA2F interrupt disabled 0b1..MA2F interrupt enabled
#define LPUART_CTRL_NEIE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_NEIE_SHIFT)) & LPUART_CTRL_NEIE_MASK) |
NEIE - Noise Error Interrupt Enable 0b0..NF interrupts disabled; use polling. 0b1..Hardware interrupt requested when NF is set.
NEIE - Noise Error Interrupt Enable 0b0..NF interrupts disabled; use polling. 0b1..Hardware interrupt is requested when NF is set.
#define LPUART_CTRL_ORIE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_ORIE_SHIFT)) & LPUART_CTRL_ORIE_MASK) |
ORIE - Overrun Interrupt Enable 0b0..OR interrupts disabled; use polling. 0b1..Hardware interrupt requested when OR is set.
ORIE - Overrun Interrupt Enable 0b0..OR interrupts disabled; use polling. 0b1..Hardware interrupt is requested when OR is set.
#define LPUART_CTRL_PE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_PE_SHIFT)) & LPUART_CTRL_PE_MASK) |
PE - Parity Enable 0b0..No hardware parity generation or checking. 0b1..Parity enabled.
#define LPUART_CTRL_PEIE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_PEIE_SHIFT)) & LPUART_CTRL_PEIE_MASK) |
PEIE - Parity Error Interrupt Enable 0b0..PF interrupts disabled; use polling). 0b1..Hardware interrupt requested when PF is set.
PEIE - Parity Error Interrupt Enable 0b0..PF interrupts disabled; use polling). 0b1..Hardware interrupt is requested when PF is set.
#define LPUART_CTRL_PT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_PT_SHIFT)) & LPUART_CTRL_PT_MASK) |
PT - Parity Type 0b0..Even parity. 0b1..Odd parity.
#define LPUART_CTRL_R8T9 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_R8T9_SHIFT)) & LPUART_CTRL_R8T9_MASK) |
R8T9 - Receive Bit 8 / Transmit Bit 9
#define LPUART_CTRL_R9T8 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_R9T8_SHIFT)) & LPUART_CTRL_R9T8_MASK) |
R9T8 - Receive Bit 9 / Transmit Bit 8
#define LPUART_CTRL_RE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_RE_SHIFT)) & LPUART_CTRL_RE_MASK) |
RE - Receiver Enable 0b0..Receiver disabled. 0b1..Receiver enabled.
#define LPUART_CTRL_RIE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_RIE_SHIFT)) & LPUART_CTRL_RIE_MASK) |
RIE - Receiver Interrupt Enable 0b0..Hardware interrupts from RDRF disabled; use polling. 0b1..Hardware interrupt requested when RDRF flag is 1.
RIE - Receiver Interrupt Enable 0b0..Hardware interrupts from RDRF disabled. 0b1..Hardware interrupt is requested when RDRF flag is 1.
#define LPUART_CTRL_RSRC | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_RSRC_SHIFT)) & LPUART_CTRL_RSRC_MASK) |
RSRC - Receiver Source Select 0b0..Provided LOOPS is set, RSRC is cleared, selects internal loop back mode and the LPUART does not use the RXD pin. 0b1..Single-wire LPUART mode where the TXD pin is connected to the transmitter output and receiver input.
#define LPUART_CTRL_RWU | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_RWU_SHIFT)) & LPUART_CTRL_RWU_MASK) |
RWU - Receiver Wakeup Control 0b0..Normal receiver operation. 0b1..LPUART receiver in standby waiting for wakeup condition.
#define LPUART_CTRL_SBK | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_SBK_SHIFT)) & LPUART_CTRL_SBK_MASK) |
SBK - Send Break 0b0..Normal transmitter operation. 0b1..Queue break character(s) to be sent.
#define LPUART_CTRL_TCIE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_TCIE_SHIFT)) & LPUART_CTRL_TCIE_MASK) |
TCIE - Transmission Complete Interrupt Enable for 0b0..Hardware interrupts from TC disabled; use polling. 0b1..Hardware interrupt requested when TC flag is 1.
TCIE - Transmission Complete Interrupt Enable for 0b0..Hardware interrupts from TC disabled. 0b1..Hardware interrupt is requested when TC flag is 1.
#define LPUART_CTRL_TE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_TE_SHIFT)) & LPUART_CTRL_TE_MASK) |
TE - Transmitter Enable 0b0..Transmitter disabled. 0b1..Transmitter enabled.
#define LPUART_CTRL_TIE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_TIE_SHIFT)) & LPUART_CTRL_TIE_MASK) |
TIE - Transmit Interrupt Enable 0b0..Hardware interrupts from TDRE disabled; use polling. 0b1..Hardware interrupt requested when TDRE flag is 1.
TIE - Transmit Interrupt Enable 0b0..Hardware interrupts from TDRE disabled. 0b1..Hardware interrupt is requested when TDRE flag is 1.
#define LPUART_CTRL_TXDIR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_TXDIR_SHIFT)) & LPUART_CTRL_TXDIR_MASK) |
TXDIR - TXD Pin Direction in Single-Wire Mode 0b0..TXD pin is an input in single-wire mode. 0b1..TXD pin is an output in single-wire mode.
#define LPUART_CTRL_TXINV | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_TXINV_SHIFT)) & LPUART_CTRL_TXINV_MASK) |
TXINV - Transmit Data Inversion 0b0..Transmit data not inverted. 0b1..Transmit data inverted.
#define LPUART_CTRL_WAKE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_CTRL_WAKE_SHIFT)) & LPUART_CTRL_WAKE_MASK) |
WAKE - Receiver Wakeup Method Select 0b0..Configures RWU for idle-line wakeup. 0b1..Configures RWU with address-mark wakeup.
#define LPUART_DATA_FRETSC | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_FRETSC_SHIFT)) & LPUART_DATA_FRETSC_MASK) |
FRETSC - Frame Error / Transmit Special Character 0b0..The dataword was received without a frame error on read, or transmit a normal character on write. 0b1..The dataword was received with a frame error, or transmit an idle or break character on transmit.
FRETSC - Frame Error / Transmit Special Character 0b0..The dataword is received without a frame error on read, or transmit a normal character on write. 0b1..The dataword is received with a frame error, or transmit an idle or break character on transmit.
#define LPUART_DATA_IDLINE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_IDLINE_SHIFT)) & LPUART_DATA_IDLINE_MASK) |
IDLINE - Idle Line 0b0..Receiver was not idle before receiving this character. 0b1..Receiver was idle before receiving this character.
#define LPUART_DATA_NOISY | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_NOISY_SHIFT)) & LPUART_DATA_NOISY_MASK) |
NOISY - NOISY 0b0..The dataword was received without noise. 0b1..The data was received with noise.
NOISY - Noisy Data Received 0b0..The dataword is received without noise. 0b1..The data is received with noise.
#define LPUART_DATA_PARITYE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_PARITYE_SHIFT)) & LPUART_DATA_PARITYE_MASK) |
PARITYE - PARITYE 0b0..The dataword was received without a parity error. 0b1..The dataword was received with a parity error.
PARITYE - Parity Error 0b0..The dataword is received without a parity error. 0b1..The dataword is received with a parity error.
#define LPUART_DATA_R0T0 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R0T0_SHIFT)) & LPUART_DATA_R0T0_MASK) |
R0T0 - R0T0
R0T0 - R0T0
R0T0 - R0T0
#define LPUART_DATA_R1T1 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R1T1_SHIFT)) & LPUART_DATA_R1T1_MASK) |
R1T1 - R1T1
R1T1 - R1T1
R1T1 - R1T1
#define LPUART_DATA_R2T2 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R2T2_SHIFT)) & LPUART_DATA_R2T2_MASK) |
R2T2 - R2T2
R2T2 - R2T2
R2T2 - R2T2
#define LPUART_DATA_R3T3 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R3T3_SHIFT)) & LPUART_DATA_R3T3_MASK) |
R3T3 - R3T3
R3T3 - R3T3
R3T3 - R3T3
#define LPUART_DATA_R4T4 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R4T4_SHIFT)) & LPUART_DATA_R4T4_MASK) |
R4T4 - R4T4
R4T4 - R4T4
R4T4 - R4T4
#define LPUART_DATA_R5T5 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R5T5_SHIFT)) & LPUART_DATA_R5T5_MASK) |
R5T5 - R5T5
R5T5 - R5T5
R5T5 - R5T5
#define LPUART_DATA_R6T6 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R6T6_SHIFT)) & LPUART_DATA_R6T6_MASK) |
R6T6 - R6T6
R6T6 - R6T6
R6T6 - R6T6
#define LPUART_DATA_R7T7 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R7T7_SHIFT)) & LPUART_DATA_R7T7_MASK) |
R7T7 - R7T7
R7T7 - R7T7
R7T7 - R7T7
#define LPUART_DATA_R8T8 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R8T8_SHIFT)) & LPUART_DATA_R8T8_MASK) |
R8T8 - R8T8
R8T8 - R8T8
R8T8 - R8T8
#define LPUART_DATA_R9T9 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_R9T9_SHIFT)) & LPUART_DATA_R9T9_MASK) |
R9T9 - R9T9
R9T9 - R9T9
R9T9 - R9T9
#define LPUART_DATA_RXEMPT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_DATA_RXEMPT_SHIFT)) & LPUART_DATA_RXEMPT_MASK) |
RXEMPT - Receive Buffer Empty 0b0..Receive buffer contains valid data. 0b1..Receive buffer is empty, data returned on read is not valid.
#define LPUART_FIFO_RXEMPT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_RXEMPT_SHIFT)) & LPUART_FIFO_RXEMPT_MASK) |
RXEMPT - Receive Buffer/FIFO Empty 0b0..Receive buffer is not empty. 0b1..Receive buffer is empty.
RXEMPT - Receive FIFO/Buffer Empty 0b0..Receive buffer is not empty. 0b1..Receive buffer is empty.
#define LPUART_FIFO_RXFE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_RXFE_SHIFT)) & LPUART_FIFO_RXFE_MASK) |
RXFE - Receive FIFO Enable 0b0..Receive FIFO is not enabled. Buffer is depth 1. 0b1..Receive FIFO is enabled. Buffer is depth indicted by RXFIFOSIZE.
RXFE - Receive FIFO Enable 0b0..Receive FIFO is not enabled. Buffer depth is 1. 0b1..Receive FIFO is enabled. Buffer depth is indicted by RXFIFOSIZE.
#define LPUART_FIFO_RXFIFOSIZE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_RXFIFOSIZE_SHIFT)) & LPUART_FIFO_RXFIFOSIZE_MASK) |
RXFIFOSIZE - Receive FIFO Buffer Depth 0b000..Receive FIFO/Buffer depth = 1 dataword. 0b001..Receive FIFO/Buffer depth = 4 datawords. 0b010..Receive FIFO/Buffer depth = 8 datawords. 0b011..Receive FIFO/Buffer depth = 16 datawords. 0b100..Receive FIFO/Buffer depth = 32 datawords. 0b101..Receive FIFO/Buffer depth = 64 datawords. 0b110..Receive FIFO/Buffer depth = 128 datawords. 0b111..Receive FIFO/Buffer depth = 256 datawords.
#define LPUART_FIFO_RXFLUSH | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_RXFLUSH_SHIFT)) & LPUART_FIFO_RXFLUSH_MASK) |
RXFLUSH - Receive FIFO/Buffer Flush 0b0..No flush operation occurs. 0b1..All data in the receive FIFO/buffer is cleared out.
RXFLUSH - Receive FIFO Flush 0b0..No flush operation occurs. 0b1..All data in the receive FIFO/buffer is cleared out.
#define LPUART_FIFO_RXIDEN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_RXIDEN_SHIFT)) & LPUART_FIFO_RXIDEN_MASK) |
RXIDEN - Receiver Idle Empty Enable 0b000..Disable RDRF assertion due to partially filled FIFO when receiver is idle. 0b001..Enable RDRF assertion due to partially filled FIFO when receiver is idle for 1 character. 0b010..Enable RDRF assertion due to partially filled FIFO when receiver is idle for 2 characters. 0b011..Enable RDRF assertion due to partially filled FIFO when receiver is idle for 4 characters. 0b100..Enable RDRF assertion due to partially filled FIFO when receiver is idle for 8 characters. 0b101..Enable RDRF assertion due to partially filled FIFO when receiver is idle for 16 characters. 0b110..Enable RDRF assertion due to partially filled FIFO when receiver is idle for 32 characters. 0b111..Enable RDRF assertion due to partially filled FIFO when receiver is idle for 64 characters.
#define LPUART_FIFO_RXUF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_RXUF_SHIFT)) & LPUART_FIFO_RXUF_MASK) |
RXUF - Receiver Buffer Underflow Flag 0b0..No receive buffer underflow has occurred since the last time the flag was cleared. 0b1..At least one receive buffer underflow has occurred since the last time the flag was cleared.
RXUF - Receiver FIFO Underflow Flag 0b0..No receive FIFO underflow has occurred since the last time the flag was cleared. 0b1..At least one receive FIFO underflow has occurred since the last time the flag was cleared.
#define LPUART_FIFO_RXUFE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_RXUFE_SHIFT)) & LPUART_FIFO_RXUFE_MASK) |
RXUFE - Receive FIFO Underflow Interrupt Enable 0b0..RXUF flag does not generate an interrupt to the host. 0b1..RXUF flag generates an interrupt to the host.
#define LPUART_FIFO_TXEMPT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_TXEMPT_SHIFT)) & LPUART_FIFO_TXEMPT_MASK) |
TXEMPT - Transmit Buffer/FIFO Empty 0b0..Transmit buffer is not empty. 0b1..Transmit buffer is empty.
TXEMPT - Transmit FIFO/Buffer Empty 0b0..Transmit buffer is not empty. 0b1..Transmit buffer is empty.
#define LPUART_FIFO_TXFE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_TXFE_SHIFT)) & LPUART_FIFO_TXFE_MASK) |
TXFE - Transmit FIFO Enable 0b0..Transmit FIFO is not enabled. Buffer is depth 1. 0b1..Transmit FIFO is enabled. Buffer is depth indicated by TXFIFOSIZE.
TXFE - Transmit FIFO Enable 0b0..Transmit FIFO is not enabled. Buffer depth is 1. 0b1..Transmit FIFO is enabled. Buffer depth is indicated by TXFIFOSIZE.
#define LPUART_FIFO_TXFIFOSIZE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_TXFIFOSIZE_SHIFT)) & LPUART_FIFO_TXFIFOSIZE_MASK) |
TXFIFOSIZE - Transmit FIFO Buffer Depth 0b000..Transmit FIFO/Buffer depth = 1 dataword. 0b001..Transmit FIFO/Buffer depth = 4 datawords. 0b010..Transmit FIFO/Buffer depth = 8 datawords. 0b011..Transmit FIFO/Buffer depth = 16 datawords. 0b100..Transmit FIFO/Buffer depth = 32 datawords. 0b101..Transmit FIFO/Buffer depth = 64 datawords. 0b110..Transmit FIFO/Buffer depth = 128 datawords. 0b111..Transmit FIFO/Buffer depth = 256 datawords
#define LPUART_FIFO_TXFLUSH | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_TXFLUSH_SHIFT)) & LPUART_FIFO_TXFLUSH_MASK) |
TXFLUSH - Transmit FIFO/Buffer Flush 0b0..No flush operation occurs. 0b1..All data in the transmit FIFO/Buffer is cleared out.
TXFLUSH - Transmit FIFO Flush 0b0..No flush operation occurs. 0b1..All data in the transmit FIFO is cleared out.
#define LPUART_FIFO_TXOF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_TXOF_SHIFT)) & LPUART_FIFO_TXOF_MASK) |
TXOF - Transmitter Buffer Overflow Flag 0b0..No transmit buffer overflow has occurred since the last time the flag was cleared. 0b1..At least one transmit buffer overflow has occurred since the last time the flag was cleared.
TXOF - Transmitter FIFO Overflow Flag 0b0..No transmit FIFO overflow has occurred since the last time the flag was cleared. 0b1..At least one transmit FIFO overflow has occurred since the last time the flag was cleared.
#define LPUART_FIFO_TXOFE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_FIFO_TXOFE_SHIFT)) & LPUART_FIFO_TXOFE_MASK) |
TXOFE - Transmit FIFO Overflow Interrupt Enable 0b0..TXOF flag does not generate an interrupt to the host. 0b1..TXOF flag generates an interrupt to the host.
#define LPUART_GLOBAL_RST | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_GLOBAL_RST_SHIFT)) & LPUART_GLOBAL_RST_MASK) |
RST - Software Reset 0b0..Module is not reset. 0b1..Module is reset.
#define LPUART_MATCH_MA1 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_MATCH_MA1_SHIFT)) & LPUART_MATCH_MA1_MASK) |
MA1 - Match Address 1
#define LPUART_MATCH_MA2 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_MATCH_MA2_SHIFT)) & LPUART_MATCH_MA2_MASK) |
MA2 - Match Address 2
#define LPUART_MODIR_IREN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_IREN_SHIFT)) & LPUART_MODIR_IREN_MASK) |
IREN - Infrared enable 0b0..IR disabled. 0b1..IR enabled.
#define LPUART_MODIR_RTSWATER | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_RTSWATER_SHIFT)) & LPUART_MODIR_RTSWATER_MASK) |
RTSWATER - Receive RTS Configuration
#define LPUART_MODIR_RXRTSE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_RXRTSE_SHIFT)) & LPUART_MODIR_RXRTSE_MASK) |
RXRTSE - Receiver request-to-send enable 0b0..The receiver has no effect on RTS. 0b1..RTS is deasserted if the receiver data register is full or a start bit has been detected that would cause the receiver data register to become full. RTS is asserted if the receiver data register is not full and has not detected a start bit that would cause the receiver data register to become full.
#define LPUART_MODIR_TNP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_TNP_SHIFT)) & LPUART_MODIR_TNP_MASK) |
TNP - Transmitter narrow pulse 0b00..1/OSR. 0b01..2/OSR. 0b10..3/OSR. 0b11..4/OSR.
#define LPUART_MODIR_TXCTSC | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_TXCTSC_SHIFT)) & LPUART_MODIR_TXCTSC_MASK) |
TXCTSC - Transmit CTS Configuration 0b0..CTS input is sampled at the start of each character. 0b1..CTS input is sampled when the transmitter is idle.
#define LPUART_MODIR_TXCTSE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_TXCTSE_SHIFT)) & LPUART_MODIR_TXCTSE_MASK) |
TXCTSE - Transmitter clear-to-send enable 0b0..CTS has no effect on the transmitter. 0b1..Enables clear-to-send operation. The transmitter checks the state of CTS each time it is ready to send a character. If CTS is asserted, the character is sent. If CTS is deasserted, the signal TXD remains in the mark state and transmission is delayed until CTS is asserted. Changes in CTS as a character is being sent do not affect its transmission.
#define LPUART_MODIR_TXCTSSRC | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_TXCTSSRC_SHIFT)) & LPUART_MODIR_TXCTSSRC_MASK) |
TXCTSSRC - Transmit CTS Source 0b0..CTS input is the CTS_B pin. 0b1..CTS input is the inverted Receiver Match result.
TXCTSSRC - Transmit CTS Source 0b0..CTS input is the CTS_B pin. 0b1..CTS input is an internal connection to the receiver address match result.
#define LPUART_MODIR_TXRTSE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_TXRTSE_SHIFT)) & LPUART_MODIR_TXRTSE_MASK) |
TXRTSE - Transmitter request-to-send enable 0b0..The transmitter has no effect on RTS. 0b1..When a character is placed into an empty transmitter data buffer , RTS asserts one bit time before the start bit is transmitted. RTS deasserts one bit time after all characters in the transmitter data buffer and shift register are completely sent, including the last stop bit.
TXRTSE - Transmitter request-to-send enable 0b0..The transmitter has no effect on RTS. 0b1..When a character is placed into an empty transmit shift register, RTS asserts one bit time before the start bit is transmitted. RTS deasserts one bit time after all characters in the transmitter FIFO and shift register are completely sent, including the last stop bit.
#define LPUART_MODIR_TXRTSPOL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_MODIR_TXRTSPOL_SHIFT)) & LPUART_MODIR_TXRTSPOL_MASK) |
TXRTSPOL - Transmitter request-to-send polarity 0b0..Transmitter RTS is active low. 0b1..Transmitter RTS is active high.
#define LPUART_PARAM_RXFIFO | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_PARAM_RXFIFO_SHIFT)) & LPUART_PARAM_RXFIFO_MASK) |
RXFIFO - Receive FIFO Size
#define LPUART_PARAM_TXFIFO | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_PARAM_TXFIFO_SHIFT)) & LPUART_PARAM_TXFIFO_MASK) |
TXFIFO - Transmit FIFO Size
#define LPUART_PINCFG_TRGSEL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_PINCFG_TRGSEL_SHIFT)) & LPUART_PINCFG_TRGSEL_MASK) |
TRGSEL - Trigger Select 0b00..Input trigger is disabled. 0b01..Input trigger is used instead of RXD pin input. 0b10..Input trigger is used instead of CTS_B pin input. 0b11..Input trigger is used to modulate the TXD pin output. The TXD pin output (after TXINV configuration) is ANDed with the input trigger.
TRGSEL - Trigger Select 0b00..Input trigger is disabled. 0b01..Input trigger is used instead of RXD pin input. 0b10..Input trigger is used instead of CTS_B pin input. 0b11..Input trigger is used to modulate the TXD pin output. The TXD pin output (after TXINV configuration) is internally ANDed with the input trigger.
#define LPUART_STAT_BRK13 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_BRK13_SHIFT)) & LPUART_STAT_BRK13_MASK) |
BRK13 - Break Character Generation Length 0b0..Break character is transmitted with length of 9 to 13 bit times. 0b1..Break character is transmitted with length of 12 to 15 bit times.
#define LPUART_STAT_FE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_FE_SHIFT)) & LPUART_STAT_FE_MASK) |
FE - Framing Error Flag 0b0..No framing error detected. This does not guarantee the framing is correct. 0b1..Framing error.
#define LPUART_STAT_IDLE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_IDLE_SHIFT)) & LPUART_STAT_IDLE_MASK) |
IDLE - Idle Line Flag 0b0..No idle line detected. 0b1..Idle line was detected.
IDLE - Idle Line Flag 0b0..No idle line detected. 0b1..Idle line is detected.
#define LPUART_STAT_LBKDE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_LBKDE_SHIFT)) & LPUART_STAT_LBKDE_MASK) |
LBKDE - LIN Break Detection Enable 0b0..LIN break detect is disabled, normal break character can be detected. 0b1..LIN break detect is enabled. LIN break character is detected at length of 11 bit times (if M = 0) or 12 (if M = 1) or 13 (M10 = 1).
#define LPUART_STAT_LBKDIF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_LBKDIF_SHIFT)) & LPUART_STAT_LBKDIF_MASK) |
LBKDIF - LIN Break Detect Interrupt Flag 0b0..No LIN break character has been detected. 0b1..LIN break character has been detected.
#define LPUART_STAT_MA1F | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_MA1F_SHIFT)) & LPUART_STAT_MA1F_MASK) |
MA1F - Match 1 Flag 0b0..Received data is not equal to MA1 0b1..Received data is equal to MA1
#define LPUART_STAT_MA2F | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_MA2F_SHIFT)) & LPUART_STAT_MA2F_MASK) |
MA2F - Match 2 Flag 0b0..Received data is not equal to MA2 0b1..Received data is equal to MA2
#define LPUART_STAT_MSBF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_MSBF_SHIFT)) & LPUART_STAT_MSBF_MASK) |
MSBF - MSB First 0b0..LSB (bit0) is the first bit that is transmitted following the start bit. Further, the first bit received after the start bit is identified as bit0. 0b1..MSB (bit9, bit8, bit7 or bit6) is the first bit that is transmitted following the start bit depending on the setting of CTRL[M], CTRL[PE] and BAUD[M10]. Further, the first bit received after the start bit is identified as bit9, bit8, bit7 or bit6 depending on the setting of CTRL[M] and CTRL[PE].
MSBF - MSB First 0b0..LSB (bit0) is the first bit that is transmitted following the start bit. Further, the first bit received after the start bit is identified as bit0. 0b1..MSB (identified as bit9, bit8, bit7 or bit6) is the first bit that is transmitted following the start bit depending on the setting of CTRL[M], CTRL[PE] and BAUD[M10]. .
#define LPUART_STAT_NF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_NF_SHIFT)) & LPUART_STAT_NF_MASK) |
NF - Noise Flag 0b0..No noise detected. 0b1..Noise detected in the received character in the DATA register.
#define LPUART_STAT_OR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_OR_SHIFT)) & LPUART_STAT_OR_MASK) |
OR - Receiver Overrun Flag 0b0..No overrun. 0b1..Receive overrun (new LPUART data lost).
#define LPUART_STAT_PF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_PF_SHIFT)) & LPUART_STAT_PF_MASK) |
PF - Parity Error Flag 0b0..No parity error. 0b1..Parity error.
#define LPUART_STAT_RAF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_RAF_SHIFT)) & LPUART_STAT_RAF_MASK) |
RAF - Receiver Active Flag 0b0..LPUART receiver idle waiting for a start bit. 0b1..LPUART receiver active (RXD input not idle).
#define LPUART_STAT_RDRF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_RDRF_SHIFT)) & LPUART_STAT_RDRF_MASK) |
RDRF - Receive Data Register Full Flag 0b0..Receive data buffer empty. 0b1..Receive data buffer full.
RDRF - Receive Data Register Full Flag 0b0..Receive FIFO level is less than watermark. 0b1..Receive FIFO level is equal or greater than watermark.
#define LPUART_STAT_RWUID | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_RWUID_SHIFT)) & LPUART_STAT_RWUID_MASK) |
RWUID - Receive Wake Up Idle Detect 0b0..During receive standby state (RWU = 1), the IDLE bit does not get set upon detection of an idle character. During address match wakeup, the IDLE bit does not set when an address does not match. 0b1..During receive standby state (RWU = 1), the IDLE bit gets set upon detection of an idle character. During address match wakeup, the IDLE bit does set when an address does not match.
#define LPUART_STAT_RXEDGIF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_RXEDGIF_SHIFT)) & LPUART_STAT_RXEDGIF_MASK) |
RXEDGIF - RXD Pin Active Edge Interrupt Flag 0b0..No active edge on the receive pin has occurred. 0b1..An active edge on the receive pin has occurred.
#define LPUART_STAT_RXINV | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_RXINV_SHIFT)) & LPUART_STAT_RXINV_MASK) |
RXINV - Receive Data Inversion 0b0..Receive data not inverted. 0b1..Receive data inverted.
#define LPUART_STAT_TC | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_TC_SHIFT)) & LPUART_STAT_TC_MASK) |
TC - Transmission Complete Flag 0b0..Transmitter active (sending data, a preamble, or a break). 0b1..Transmitter idle (transmission activity complete).
#define LPUART_STAT_TDRE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_STAT_TDRE_SHIFT)) & LPUART_STAT_TDRE_MASK) |
TDRE - Transmit Data Register Empty Flag 0b0..Transmit data buffer full. 0b1..Transmit data buffer empty.
TDRE - Transmit Data Register Empty Flag 0b0..Transmit FIFO level is greater than watermark. 0b1..Transmit FIFO level is equal or less than watermark.
#define LPUART_VERID_FEATURE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_VERID_FEATURE_SHIFT)) & LPUART_VERID_FEATURE_MASK) |
FEATURE - Feature Identification Number 0b0000000000000001..Standard feature set. 0b0000000000000011..Standard feature set with MODEM/IrDA support.
#define LPUART_VERID_MAJOR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_VERID_MAJOR_SHIFT)) & LPUART_VERID_MAJOR_MASK) |
MAJOR - Major Version Number
#define LPUART_VERID_MINOR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_VERID_MINOR_SHIFT)) & LPUART_VERID_MINOR_MASK) |
MINOR - Minor Version Number
#define LPUART_WATER_RXCOUNT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_WATER_RXCOUNT_SHIFT)) & LPUART_WATER_RXCOUNT_MASK) |
RXCOUNT - Receive Counter
#define LPUART_WATER_RXWATER | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_WATER_RXWATER_SHIFT)) & LPUART_WATER_RXWATER_MASK) |
RXWATER - Receive Watermark
#define LPUART_WATER_TXCOUNT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_WATER_TXCOUNT_SHIFT)) & LPUART_WATER_TXCOUNT_MASK) |
TXCOUNT - Transmit Counter
#define LPUART_WATER_TXWATER | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << LPUART_WATER_TXWATER_SHIFT)) & LPUART_WATER_TXWATER_MASK) |
TXWATER - Transmit Watermark
