RTEMS 6.1-rc4
score Directory Reference
file  aarch32-pmsa.h [code]
 This header file provides the API to manage an Arm PMSAv8-32 based Memory Protection Unit (MPU).
file  aarch32-system-registers.h [code]
 This header file provides the API to read and write the AArch32 system registers.
file  arm.h [code]
 This header file provides defines derived from ARM multilib defines.
file  armv4.h [code]
 This header file provides interfaces of the ARMv4 architecture support.
file  armv7-pmsa.h [code]
 This header file provides the API to manage an Arm PMSAv7 based Memory Protection Unit (MPU).
file  armv7m.h [code]
 This header file provides interfaces of the ARMv7-M architecture support.
file  cpu.h [code]
 This header file defines implementation interfaces pertaining to the port of the executive to the ARM architecture.
file  cpu_asm.h [code]
 ARM Assembler Support API.
file  cpuimpl.h [code]
file  paravirt.h [code]
 This header file provides definitions pertaining to paravirtualization of the ARM port.
