RTEMS 6.1-rc2
Files | Data Structures | Enumerations | Functions
file  tr-object-ident.c
file  tr-object-ident.h
struct  RtemsReqIdent_Entry
struct  RtemsReqIdent_Context
 Test context for spec:/rtems/req/ident test case. More...
enum  RtemsReqIdent_Pre_Name { RtemsReqIdent_Pre_Name_Invalid , RtemsReqIdent_Pre_Name_Valid , RtemsReqIdent_Pre_Name_NA }
enum  RtemsReqIdent_Pre_Node {
  RtemsReqIdent_Pre_Node_Local , RtemsReqIdent_Pre_Node_Remote , RtemsReqIdent_Pre_Node_Invalid , RtemsReqIdent_Pre_Node_SearchAll ,
  RtemsReqIdent_Pre_Node_SearchOther , RtemsReqIdent_Pre_Node_SearchLocal , RtemsReqIdent_Pre_Node_NA
enum  RtemsReqIdent_Pre_Id { RtemsReqIdent_Pre_Id_Valid , RtemsReqIdent_Pre_Id_Null , RtemsReqIdent_Pre_Id_NA }
enum  RtemsReqIdent_Post_Status {
  RtemsReqIdent_Post_Status_Ok , RtemsReqIdent_Post_Status_InvAddr , RtemsReqIdent_Post_Status_InvName , RtemsReqIdent_Post_Status_InvNode ,
  RtemsReqIdent_Post_Status_NA
enum  RtemsReqIdent_Post_Id {
  RtemsReqIdent_Post_Id_Nop , RtemsReqIdent_Post_Id_Null , RtemsReqIdent_Post_Id_LocalObj , RtemsReqIdent_Post_Id_RemoteObj ,
  RtemsReqIdent_Post_Id_NA
void RtemsReqIdent_Run (rtems_id id_local_object, rtems_name name_local_object, rtems_status_code(*action)(rtems_name, uint32_t, rtems_id *))
 Runs the parameterized test case.
◆ RtemsReqIdent_Run()
void RtemsReqIdent_Run ( rtems_id  id_local_object,
rtems_status_code(*)(rtems_name, uint32_t, rtems_id *)  action
Parameters
id_local_objectis the identifier of an active object of the class under test.
name_local_objectis the name of the active object of the class under test.
actionis the action handler.
